    Roundcorner toolbar
    18 Posts 6 Posters 1.8k Views 6 Watching
    • jeff hammondJ
      have you tried to turn the toolbar on as shown in gaieus' screenshot?
      View -> Tool Palettes -> Round Corner
      [edit] oops.. on windows, i guess it says Toolbars instead of tool palettes.
        rhots
        Thanks for the reply Jeff, but it's not on the toolbar list. If I knew how to post a screen shot I would show you.
        Thanks,
        Rick
          It sounds to me as if there's an installation error. You should have a folder in the Plugins folder called RoundCorner... And some files inside that. Just a stab in the dark but I wonder if at least one of those files is missing or is wandering around loose in the Plugins folder.
            rhots
            These are my folders, thanks
            http://i596.photobucket.com/albums/tt43/Rhots/junk/roundcornerfolder.jpg
            http://i596.photobucket.com/albums/tt43/Rhots/junk/pluginfolder.jpg
            http://i596.photobucket.com/albums/tt43/Rhots/junk/fredo6folder.jpg
              Jim
              Oops, good catch Jeff.
                Jim
                I am not sure if this is the problem, but there is a newer version of LibFred6 - the latest is version 3.4c
                @Dave, you're RoundCorner is out of date also.
                • jeff hammondJ
                  those png files are supposed to be inside a folder called IMAGES_Standard
                  (same thing with the libfredo folder.. the icons should be in a subfolder)
                  you might want to redownload and reinstall or just fix it manually..
                  [of course, this is on a mac but i don't see why it would be different on windows.. it's the same download for both]
                    rhots
                    Okay I created the Images folder in the MAIN plugin folder, and moved ALL image files from BOTH fredo6 and roundcorner to it. Still nothing. Should I have made separate SUB folders for EACH of the fredo6 and roundcorner folders?
                    Thanks for all of your help and patients.
                    Rick
                      Thanks Jim, I'll update. It's my work computer and I rarely use that plugin here.
                      Rhots, I think instead of mucking around with trying to fix the locations of the the files for the plugins in question, I would just delete them from the Plugins folder and reinstall them properly.
                        rhots
                        Well, when I downloaded the zip files and opened them to extract the files there was only all the random files. No install or setup files, no instructions other than Fredo's at the download site for the folder hierarchy. So all I could do was create the folders, and extract the files manually.
                        I would LOVE to do a "normal" install or setup.
                        If anyone can point me in the right direction that would be marvy.
                        Thanks again,
                        Rick
                          Perhaps you should reread the original post in the thread. It seems to me there are instructions right there.
                          And when I open the ZIP file, it is all nicely organized.
                          It should have the same organization in the Plugins folder.
                          What are you using to open the ZIP file in the first place?
                            rhots
                            As my Father inlaw would say "I got 'er boys". I went back to winzip and noticed the check boxes for "use folder names" and overwrite older files. There were no folders showing so I didn't have them checked. Well that's what I get for NOT thinking...It works perfectly now.
                            THANK YOU FOR ALL OF YOUR HELP!!!!!!!!!
                            I'm sure you will hear from me again as I just started using Sketchup a few days ago.
                            MERRY CHRISTMAS FOLKS!!
                            Rick
