Plugin Request? Copy Along Path with Orientation.
5 Posts 5 Posters 1.1k Views 5 Watching
    Krisidious
    I have tried the current copy along a path plugins (the 1001bit pro & power bar) neither seem to hold orientation and what's more require a continuous line.
    I would like to use this for copying symbols like electrical outlets and such among other things.
    is it possible to do this already?
    By: Kristoff Rand
      +1
        Component Stringer by Chris Fullmer?
        Just draw number of segments where components needing
        And you can resize, move , rotate all after drawing 😉
          I haven't tried this and don't have time to at the moment but if the symbol component was made to glue to a face, would that help? I've not tried that with Copy Along Path or Component Stringer. Do you have raised walls on which you could place such a component?
          • W Offline
            Wo3Dan
            I have tried the current copy along a path plugins (the 1001bit pro & power bar)neither seem to hold orientationand what's more require a continuous line.
            %(#008000)[I would like to use this for copying symbols like electrical outlets and such among other things.
            (image)...is it possible to do this already?]
            I haven't used the plugin mentioned but...
            'Face Me' components keep their orientation in copy operations, although related to your view/screen. (try rotate/copy array)
            %(#008000)[Use a dummy 'Face Me' component to 'copy along path' or whatever copy plugin/workflow you think suites you best.
            Next select them all and replace with 'NON-face me' symbol component of your choice.
            They now have the same orientation.(*)
            (*) you may need to orbit/tweak your view to get the dummy aligned correct in your model.
            A preset little dummy face that you can select and 'Align View' to helps you to do so in a split second.
            It's all just a few steps extra.]
            Although a choice to keep orientation in a plugin is usefull, no doubt.
