    Problem with displacementmap
    renderpluginsextensions
    9 Posts 2 Posters 1.1k Views 2 Watching
    • 3 Offline
      3D-kreativ
      Despite that grass with displacement map looks like spikes, I like to use it sometimes. But it doesn't always work! I always have to load the diffuse map, and when I make a preview in the texture editor is either gray(nothing) or the image of a pice of grass and then it often works. Sometimes it's impossible to make a preview in the material editor, due to some loading problem with the diffuse, despite that you do it manually. Why is it like this? Preciate some help, because it's so irritating that it only works sometimes! Thanks!
        hm.. what version of VfSU are you using?
        Does it depend on the diffuse map you use?
          Is it the editor preview that fails? Or the render?
          • 3 Offline
            3D-kreativ
            The strange thing is that it is like random. Sometimes the preview is OK in the material editor, but not when render. Sometimes preview is totally flat, but green, in the material editor preview. Sometimes the preview in the texture editor fails, just gray, despite that I load the diffuse image at the ... !?
            My version is 1.48.
              @3d-kreativ said:
              My version is 1.48.
              Full version please. Latest public? (1.48.89) Or are you one of the beta testers?
              Got a sample model? Sample textures displacements?
              • 3 Offline
                3D-kreativ
                I use the latest public version and the grass displacement I use is GRASS 1 from this place:
                http://luzindirecta.luxisessentia.com/index.php?option=com_tpshowcase&view=list&layout=tags&id=vismat&limitstart=720
                  I tried to register so I could download - but I keep getting 404 messages and no email....
                    Does this scene work for you: http://forums.sketchucation.com/viewtopic.php?f=322&t=28593#p248278 ?
                    • 3 Offline
                      3D-kreativ
                      I'm going to take a look at that later.
