    Valiarchitects - plugins
    94 Posts 42 Posters 30.6k Views 42 Watching
      jaxcoffee
      @chuck vali said:
      @jaxcoffee said:
      I seem to be having problems access your site. Something I should be aware of?
      Hi jaxcoffee,
      I am not experiencing any problems, so please try again http://www.valiarchitects.com
      What browser are you using? We are still trying to figure out this website stuff --- the different web browsers, different languages, different operating systems... Any feedback is welcome, so we can get our interface working without glitches.
      Thanks,
      Chuck
      I use Chrome, and the error message I was getting was a server or host error. I just don't recall what it said. Sorry, but all is well now. Thanks Great plug-in's.
        jaxcoffee
        Seem to be getting nothing but bug splats when trying to use the instant roof plugin. I'm on version 8 pro. Am I missing something here?
        • C
          chuck vali
          I don't know it this is the issue in your case, but it's very important to close the 'Outliner' window prior to running Instant Roof. If not, the script will crash.
          Another possible reason for a crash is when the geometry in the model is slightly off, say out-of-square by a small fraction of a degree. This can happen when geometry is imported from another cad program. Not likely if geometry is drawn in SketchUp.
          View this tutorial on Instant Roof http://www.valiarchitects.com/tutorials/some-simple-roofs
          More advance tutorials at: http://www.valiarchitects.com/sketchup_scripts/tutorials
          Thanks for giving the plugin a try,
          Chuck
            rpaul
            Hi Chuck
            I thought it might be a good idea to ask you a question here as it may help others using this plugin. I'm using the pro version, and need some help. I'm trying to create an open beam trellis, with the rafters at 2' oc. The trellis as created does not correctly place the rafters directly opposite each other at the ridge where they should be, but instead offsets their placement somewhat haphazardly. I would think that the rafter spacing should be derived by establishing the centerlines of the structure, both x and y, and then calculating the rafter spacing from there.
            Is there a way to adjust this, other than manually?
              manamana
              I'm having some trouble with instant road.
              crunches for a few hours and then says it can't triangulate the mesh, reduce max road length. I've gone down to 5' and it still bonks out. Anyone have any ideas?
              roadfail.skp
              • C
                chuck vali
                [attachment=1:3iccghc2]<!-- ia1 -->roadfail.skp<!-- ia1 -->[/attachment:3iccghc2]
                The script says to be patient. But more than a few minutes is too much patience.
                Please accept my apologies. Looped roads are not allowed in InstantRoad. I thought I had this documented: but realize I only mentioned this in the "road from centerline" method docs.
                So for this model, I cut the outline into 2 separate groups and generated the road sections separately. Each road section took around a minute on my machine. I then filled in the missing sections manually (in red).
                BTW, the terrain had some extra lines in the area of the road that I erased before executing.
                It isn't the issue here, but I'd like to stress that it's important to have a virgin group when using InstantRoad. This means: if you scale; make a copy of; or rotate the group, you need to explode and regroup prior to running the script. Otherwise strange things may happen.
                Chuck
                [attachment=0:3iccghc2]<!-- ia0 -->roadfail doesnt allow closed loops.skp<!-- ia0 -->[/attachment:3iccghc2]
                  darth666
                  same here... if I choose to create new roof (not predefined) sketchup crashes. All defined roofs work until I choose options to edit slope...or hips...during roof creation, then sketchup crashes.
                  SK8PRO, Windows 7
                  • C
                    chuck vali
                    @rpaul said:
                    Hi Chuck
                    Ron[attachment=0:36sostdm]<!-- ia0 -->Trellis.jpg<!-- ia0 -->[/attachment:36sostdm]
                    When writing the script, I simplified a few things to make it easier for me to write it: one was to work on each eave section independently and place rafter tails from right on that section. This hugely simplified the script for dealing with multi-level buildings, but created some issues as you show with this trellis.
                    The result is that, in a simple symmetrical building, such as this trellis, the opposite sides are rotated copies, rather than mirrored.
                    Unfortunately, the only way to obtain mirrored rafters is to erase 2 of the sides and mirror the remaining 2 sides. In a similar way, if rafters tails aren't exactly lined up either side of a gable roof, the offending rafters must be selected and moved over.
                    I'm considering changing the script name to "Sort_Of_Instant_Roof"
                    Chuck
                    • C
                      chuck vali
                      @darth666 said:
                      SK8PRO, Windows 7
                      I've found a conflict with OpenStudio, which needs to be unchecked in preferences, and sketchUp restarted for InstantRoof to work. (I made a custom work-around for OpenStudio - which I can make available - but I had to disable the single undo feature to get it to work)
                      I also understand that there is a conflict with lightUp as well. But I haven't traced that problem yet.
                      If you don't have either of these other plugins, could you temporarily rename your "Plugins" folder to something else like "Plugins1", then create a new "Plugins" folder, place only InstantRoof in that folder,and restart SketchUp. If the script works then we'll know it's a conflict with some other plugin.
                      Chuck
                      • Bob JamesB
                        Bob James
                        Chuck
                        As I recall it, there is a set of plugins that mustbe in the plugins folder: I don't believe you can, in this case, have only InstantRoof by itself.
                        Sorry that I don't recall the required minimum set.
                          jaxcoffee
                          @bob james said:
                          Chuck
                          I actually did what Chuck is instructing to do to find out the conflict with LightUp. So you can have only one plugin in the plugins folder and have SketchUp work.
                            Even no plugins πŸ˜‰
                            • brookefoxB
                              brookefox
                              Solo, To me, this one is a very nice render. Pleasantly and pretty realistically unkempt, and comfortable, attractive.
                              http://img255.imageshack.us/img255/7527/thepath.png
                              (The micro ani is helpful also.)
                              ~ Brooke
                                darth666
                                @chuck vali said:
                                @darth666 said:
                                SK8PRO, Windows 7
                                Chuck
                                I've checked all my plugins and I found one that caused crashes - it was "sunposition.rb". I've removed it and "Instant roof" is working great now
                                • honoluludesktopH
                                  honoluludesktop
                                  Very nice set of plugins.
                                  • Bob JamesB
                                    Bob James
                                    • KrisidiousK
                                      Krisidious
                                      I'm getting a crash in SU8 Pro when trying to Make Roof...
                                      no sunposition.rb
                                      By: Kristoff Rand
                                      • C
                                        chuck vali
                                        no sunposition.rb
                                        Does it only crash with a particular roof or just doesn't work at all? One person had drawn an outline in another cad program and imported it into SketchUp. Instant Roof would crash trying to make a hexagonal portion of the roof. When I redrew the same geometry in SketchUp the roof worked fine.
                                        If it just crashes on any outline, then I suspect a conflict with another script. The only conflicts I am aware of are LightUp (I couldn't get it to crash when I tried it on my machine), sunposition.rb, and OpenStudo. (Only the encrypted version of Instant Roof (.rbs) would crash with Open Studio, not my unencrypted source code (.rb) )
                                        I would really like to find out what the issue is. Would you mind temporarily renaming your "Plugins" folder and putting just the InstantRoofPro.rbs and InstantRoofProS.rb in a separate "Plugins" folder to find out if it's a conflict with another plugin?
                                        Chuck
                                        • pbacotP
                                          I wish to add one comment. Well two. These are great tools all around!
                                          But it seems that this roof tool, like others I have tried, uses the eave as the line for the starting plane. I don't know if it is difficult--this coding is wizardry to me--but I wish roof tools would use the plate line, which seems (to me) the logical reference point once the size of rafters and bearing details are defined.
                                          Thanks, Chuck, for these tools and your helpful responses.
                                          Peter
                                          • utilerU
                                            utiler
                                            @pbacot said:
                                            Peter
                                            Peter, that is a frustration I have also for many plugins / programs!!!! I wish one day for a program to write functions considering the known factors and variables when built.....
                                            Just Curious...
                                            • 4 / 5
