    Valiarchitects - plugins
    94 Posts 42 Posters 24.0k Views 42 Watching
    • Bob JamesB Offline
      Bob James
      @chuck vali said:
      Reply to Grim,
      The terrain has to be larger than the road plus the shoulder width. So I scaled up the terrain slightly to get it to work. But it made kind of a bumpy road. That's because the road precision was much tighter than the terrain spacing - which makes the road follow the coarse terrain. So in the next copy, I reduced the precision of the road by changing the "adjust number of curve segments" parameter from "3x" to "same as input" and the road was less bumpy. Try turning on hidden lines to see what I mean.
      As for "try before buy", all that pro does is let you make a few things wider - everything else is the same. So please see if you like it first. (And can figure out all my cryptic parameters)
      Chuck
      Thank you, Chuck. I had the same introductory problems as Grim: the attached revised skp reallymade it clear.
      Great tool: purchase in-work.
        jaxcoffee
        I seem to be having problems access your site. Something I should be aware of?
          chuck vali
          Hi jaxcoffee,
          I am not experiencing any problems, so please try again http://www.valiarchitects.com
          What browser are you using? We are still trying to figure out this website stuff --- the different web browsers, different languages, different operating systems... Any feedback is welcome, so we can get our interface working without glitches.
          Thanks,
          Chuck
            jaxcoffee
            @chuck vali said:
            Hi jaxcoffee,
            Thanks,
            Chuck
            I use Chrome, and the error message I was getting was a server or host error. I just don't recall what it said. Sorry, but all is well now. Thanks Great plug-in's.
              jaxcoffee
              Seem to be getting nothing but bug splats when trying to use the instant roof plugin. I'm on version 8 pro. Am I missing something here?
                chuck vali
                I don't know it this is the issue in your case, but it's very important to close the 'Outliner' window prior to running Instant Roof. If not, the script will crash.
                Another possible reason for a crash is when the geometry in the model is slightly off, say out-of-square by a small fraction of a degree. This can happen when geometry is imported from another cad program. Not likely if geometry is drawn in SketchUp.
                View this tutorial on Instant Roof http://www.valiarchitects.com/tutorials/some-simple-roofs
                More advance tutorials at: http://www.valiarchitects.com/sketchup_scripts/tutorials
                Thanks for giving the plugin a try,
                Chuck
                  rpaul
                  Hi Chuck
                  I thought it might be a good idea to ask you a question here as it may help others using this plugin. I'm using the pro version, and need some help. I'm trying to create an open beam trellis, with the rafters at 2' oc. The trellis as created does not correctly place the rafters directly opposite each other at the ridge where they should be, but instead offsets their placement somewhat haphazardly. I would think that the rafter spacing should be derived by establishing the centerlines of the structure, both x and y, and then calculating the rafter spacing from there.
                  Is there a way to adjust this, other than manually?
                    manamana
                    I'm having some trouble with instant road.
                    crunches for a few hours and then says it can't triangulate the mesh, reduce max road length. I've gone down to 5' and it still bonks out. Anyone have any ideas?
                    roadfail.skp
                      chuck vali
                      [attachment=1:3iccghc2]<!-- ia1 -->roadfail.skp<!-- ia1 -->[/attachment:3iccghc2]
                      The script says to be patient. But more than a few minutes is too much patience.
                      Please accept my apologies. Looped roads are not allowed in InstantRoad. I thought I had this documented: but realize I only mentioned this in the "road from centerline" method docs.
                      So for this model, I cut the outline into 2 separate groups and generated the road sections separately. Each road section took around a minute on my machine. I then filled in the missing sections manually (in red).
                      BTW, the terrain had some extra lines in the area of the road that I erased before executing.
                      It isn't the issue here, but I'd like to stress that it's important to have a virgin group when using InstantRoad. This means: if you scale; make a copy of; or rotate the group, you need to explode and regroup prior to running the script. Otherwise strange things may happen.
                      Chuck
                      [attachment=0:3iccghc2]<!-- ia0 -->roadfail doesnt allow closed loops.skp<!-- ia0 -->[/attachment:3iccghc2]
                        darth666
                        same here... if I choose to create new roof (not predefined) sketchup crashes. All defined roofs work until I choose options to edit slope...or hips...during roof creation, then sketchup crashes.
                        SK8PRO, Windows 7
                          chuck vali
                          @rpaul said:
                          Hi Chuck
                          Ron[attachment=0:36sostdm]<!-- ia0 -->Trellis.jpg<!-- ia0 -->[/attachment:36sostdm]
                          When writing the script, I simplified a few things to make it easier for me to write it: one was to work on each eave section independently and place rafter tails from right on that section. This hugely simplified the script for dealing with multi-level buildings, but created some issues as you show with this trellis.
                          The result is that, in a simple symmetrical building, such as this trellis, the opposite sides are rotated copies, rather than mirrored.
                          Unfortunately, the only way to obtain mirrored rafters is to erase 2 of the sides and mirror the remaining 2 sides. In a similar way, if rafters tails aren't exactly lined up either side of a gable roof, the offending rafters must be selected and moved over.
                          I'm considering changing the script name to "Sort_Of_Instant_Roof"
                          Chuck
                            chuck vali
                            @darth666 said:
                            SK8PRO, Windows 7
                            I've found a conflict with OpenStudio, which needs to be unchecked in preferences, and sketchUp restarted for InstantRoof to work. (I made a custom work-around for OpenStudio - which I can make available - but I had to disable the single undo feature to get it to work)
                            I also understand that there is a conflict with lightUp as well. But I haven't traced that problem yet.
                            If you don't have either of these other plugins, could you temporarily rename your "Plugins" folder to something else like "Plugins1", then create a new "Plugins" folder, place only InstantRoof in that folder,and restart SketchUp. If the script works then we'll know it's a conflict with some other plugin.
                            Chuck
                              Bob James
                              Chuck
                              As I recall it, there is a set of plugins that mustbe in the plugins folder: I don't believe you can, in this case, have only InstantRoof by itself.
                              Sorry that I don't recall the required minimum set.
                                jaxcoffee
                                @bob james said:
                                Chuck
                                I actually did what Chuck is instructing to do to find out the conflict with LightUp. So you can have only one plugin in the plugins folder and have SketchUp work.
                                  Even no plugins πŸ˜‰
                                  • brookefoxB Offline
                                    brookefox
                                    Solo, To me, this one is a very nice render. Pleasantly and pretty realistically unkempt, and comfortable, attractive.
                                    http://img255.imageshack.us/img255/7527/thepath.png
                                    (The micro ani is helpful also.)
                                    ~ Brooke
                                      darth666
                                      @chuck vali said:
                                      @darth666 said:
                                      SK8PRO, Windows 7
                                      Chuck
                                      I've checked all my plugins and I found one that caused crashes - it was "sunposition.rb". I've removed it and "Instant roof" is working great now
                                      • honoluludesktopH Offline
                                        honoluludesktop
                                        Very nice set of plugins.
                                          Bob James
                                          • KrisidiousK Offline
                                            Krisidious
                                            I'm getting a crash in SU8 Pro when trying to Make Roof...
                                            no sunposition.rb
                                            By: Kristoff Rand
                                            • 4 / 5
