    [Plugin] Mirror
    211 Posts 72 Posters 478.4k Views 72 Watching
      Dominance
      thanks for your sharing
      • dereiD
        derei
        @TIG: Could you make some loader for this ? I would like to have a folder with "MI.png, Mirror.rb and toggleWindows.rb" and a Mirror_loader.rb (or similar). Win32API.so I thinks it's best to stay in Plugins folder, as it is used by more plugins.
        Thanks a lot.
        DESIGNER AND ARTIST DEREI.UK
          Thanks a lot.
          If you want to move files you need to rewrite the menu/toolbar part of their code to ensure the files are found in the new sub-folder.
          A loader is a simply a file in the ../Plugins/ folder called perhaps myloader.rb containing this line of code
          load "mysubfolder/myscript.rb"
          The line can be repeated for multiple files to be loaded...
          Where mysubfolder is a folder in ../Plugins/ containing the script myscript.rb that you want loading...
            dedmin
            Today I noticed when I mirror a component the mirrored copy gets "Scale definition" active. When click to reset it rotates 180 degree, when choose to scale the original now gets "Scale definition"?
              The component instance will be scaled '-1' in the selected direction[s]. Resetting the scale should revert to the original scaling... πŸ˜•
                dedmin
                And may be this is the cause of my troubles with the components getting unique! I did a lot of models with the Mirror Selection - now I just copied instead of mirror and components don't convert to unique!
                • P
                  paddyclown
                  hello
                  maybe i've missed something, but I tried mirror 3.5 with sketchyphysics and it won't do the mirror operation... Once the sketchyphisics has been removed no problem... I had thought I had understood that 3.5 fixed this (amongst other things)... shame as it's a great tool.
                  (using v7 on a vista platform)...
                  thanks anyway to TIG for all the time & trouble.
                    This is a known bug caused by SketchyPhysics rewriting the code of some of the API's own Group class, which is used by Mirror. I'm not sure what the issue is.
                    Perhaps if you bring pressure to bear on the SketchyPhysics side they could fix their code to stop the problem!
                    AS SketchyPhysics loads after Mirror could you try renaming 'Mirror.rb' as 'zMirror.rb' so it loads afterwards -perhaps what SP breaks will stay OK this way and hopefully SP will still work... πŸ˜•
                    • P
                      paddyclown
                      Thanks for yr speedy reply... I tried the workaround, but alas to no avail ! I guess you're right, we have to ask the SP guys to fix there stuff ! Thanks anyway, & meantime their stuff is out & yours is in as totally indispensable (I don't understand why the gogol people haven't put in a mirror command as a basic standard tool like in any other cad program !).
                      • X
                        xinxin
                        Thank you!I have downloaded it.
                        • FletchF
                          Fletch
                          Hi TIG,
                          Thank you for sharing all of your wonderful talents. This + the imagetrimmer.rb 😲 are very nice.
                          I haven't had time to read this whole thread, so sorry if this issue has been mentioned before:
                          On my machine, when I have the toolbar for Mirror open, and I double-click a component or group to edit - it can take about 4-5 seconds to actually open the group or component. This was killing me until I tried just closing the mirror36.rb toolbar button. I downloaded the .rb file from this thread just tonight. I thought to close the toolbar and the problem went away. I would have no idea why. I have a shortcut assigned and don't need the toolbar anyway.
                          Fletch
                            @fletch said:
                            Hi TIG,
                            Make sure you have v3.6 installed...
                            It might be because there's a context-menu too ?
                            To stop the toolbar being made at all you can simply move the button file 'MI.png' out of the ../Plugins/ folder and then there will be no toolbar as it only gets made IF the button's png is found.
                            To stop the context-menu item appearing you can open the 'Mirror.rb' file in Notepad.exe or another equivalent plain text editor [NOT a wordprocessor] and near the end of the code around line #376 there's this block of text
                            UI.add_context_menu_handler do |menu|### v3.5 TIG
                                  #if Sketchup.active_model.selection
                                    #menu.add_separator
                                    menu.add_item("Mirror Selection"){Sketchup.active_model.select_tool(MirrorTool.new)}
                                  #end#if
                               end#do menu###
                            change it so the UI.add..., menu.add... and end#do... lines all start with a #, thus
                            #UI.add_context_menu_handler do |menu|### v3.5 TIG
                                    #menu.add_separator
                                    #menu.add_item("Mirror Selection"){Sketchup.active_model.select_tool(MirrorTool.new)}
                                  #end#if
                               #end#do menu###
                            • now there'll be no context-menu.
                              Having done this you'll only have the main Plugins menu item 'Mirror' to shortcut to.
                            Incidentally if you'd like the tool to appear in say the 'Tools' menu and be named 'Mirror' you can simply edit line #370
                            UI.menu("Plugins").add_item("Mirror Selection"){Sketchup.active_model.select_tool(MirrorTool.new)}
                            to read
                            UI.menu("Tools").add_item("Mirror"){Sketchup.active_model.select_tool(MirrorTool.new)}
                            • FletchF
                              Fletch
                              Thanks a lot TIG.
                              I was in a (rather) large file, and perhaps it was just a glitch happening with the machine/RAM/etc.
                              Everything seems fine today (with or without toolbar showing)... I do appreciate the info, however, as there are times I wish I could modify these things in some rubies. πŸ€“
                              Fletch
                              • mariochaM
                                mariocha
                                I confirm that circles get exploded in some cases.
                                Not when they are free standing, but when they are part of a face, like on top of a cube, yes. 😞
                                Pretty annoying.
                                %(#008000)[Mario C.
                                  Mario
                                  I've tested what you say and can't get a circle or arc to 'explode' after mirroring πŸ˜•
                                  Are you using the latest version?
                                  Can you supply a skp where you do get this issue, so that I can test it...
                                    Your gif doesn't auto animate ??
                                    A face with edges should copy and mirror OK, loose edges/arc == edges ?? πŸ˜•
                                      jorge2011
                                      "Your gif doesn't auto animate ??"
                                      you click on the image
                                      when the circle mirror with your face, does not exploit the circle
                                      When mirror only the circle, the circle is exploited
                                        you click on the image...
                                        I know BUT it looks just like any other image so why would I want to click on it at all πŸ˜’
                                        A gif can auto-animate... so it's obvious what it is.
                                        [<<<see my avatar πŸ˜• ]
                                          jorge2011
                                          Sr TIG, see this exampler
                                          see this example.
                                          Mirrors edge face ( copy good)/ edge mirrors only (copy explode edge)
                                            jorge2011
                                            sorry but I do not understand what you say.
                                            Posted there again animated giff
                                            http://forums.sketchucation.com/download/file.php?mode=view&id=71848
                                            • 11
                                            • 3 / 11
