    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    Saving an reloading a material from an attribut
    18 Posts 3 Posters 988 Views 3 Watching
      kiesewetter
      hallo!
      i tried to save the current material of an entity object in an attribute to be able to assign the material to the entity later in the skript with the following code which isn't working so far:
      <span class="syntaxdefault"></span><span class="syntaxcomment">#to&nbsp;savi&nbsp;it&nbsp;in&nbsp;an&nbsp;attribute<br /></span><span class="syntaxdefault">mod&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />ents&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mod</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities&nbsp;<br />mats&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mod</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">materials<br /><br />ents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">typename&nbsp;</span><span class="syntaxkeyword">==&nbsp;</span><span class="syntaxstring">"Face"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;(</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material</span><span class="syntaxkeyword">)&nbsp;</span><span class="syntaxcomment">#checks&nbsp;wheter&nbsp;a&nbsp;material&nbsp;is&nbsp;assigned&nbsp;to&nbsp;the&nbsp;face<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">mat_prev&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">name<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set_attribute&nbsp;</span><span class="syntaxstring">"time"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"material"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">mat_prev<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">}<br /><br /></span><span class="syntaxcomment">#to&nbsp;reassign&nbsp;it&nbsp;later<br /><br /></span><span class="syntaxdefault">mod&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />ents&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mod</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities&nbsp;<br />mats&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mod</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">materials<br />ents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">typename&nbsp;</span><span class="syntaxkeyword">==&nbsp;</span><span class="syntaxstring">"Face"&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">mat_temp</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute&nbsp;</span><span class="syntaxstring">"time"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"material"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">mats</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">mat_temp</span><span class="syntaxkeyword">]&nbsp;</span><span class="syntaxcomment">#before&nbsp;that&nbsp;should&nbsp;be&nbsp;checked&nbsp;wether&nbsp;the&nbsp;attribute&nbsp;isn't&nbsp;nil<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">}&nbsp;</span><span class="syntaxdefault"></span>
      thanks for your time.
      tim
        You can only save certain types of classesas attributes - integer, float, string, array and boolean.
        Other types like ' Sketchup::material' are not usable.
        Also don't think to use its ID. if these are useless across sessions - they change between session as the model loads...
        BUT you could simply use material.display_name [which is always unique] and save that string as the attribute... as mat_name=nil; mat_name=e.material.display_name if e.material; e.set_attribute("time", "material", mat_name)...
        then when you want to get it back simply use e.material = e.get_attribute("time", "material", nil) - this even allows for 'nil' material so no need to make extra tests... You can assign a material by 'name'.
          btw comparing strings to find a entity tyep e.typename == "Face" is very slow.
          Instead use compare the actuall classes - like e.is_a?(Sketchup::Face)
            he did in fact try that - material.name. so it should work. unless .name returned some bogus data.
            The API docs doesn't say for .name that .display_name should be used - and it never explains what the difference is.
              But the API does say for material.display_name use it instead of material.name šŸ˜’ http://code.google.com/apis/sketchup/docs/ourdoc/material.html#display_name ...
                kiesewetter
                ok, i assigned a material to a face with the tool in sketchup that is invoken by the icon with the color bucket. after that i loaded a script with the following code (only the face with the material was selected)
                <span class="syntaxdefault">mod&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />ents&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mod</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities&nbsp;<br />sel&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mod</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection<br />mats&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mod</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">materials<br />mat</span><span class="syntaxkeyword">=</span><span class="syntaxstring">""<br /><br /></span><span class="syntaxdefault">sel</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">mat</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">display_name<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">}<br /><br /><br /></span><span class="syntaxdefault">ents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mats</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">mat</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;}&nbsp;</span><span class="syntaxdefault"></span>
                the debugger says: #<NoMethodError: undefined method `display_name' for nil:NilClass>
                somehow the material doesn't seem to stored in the materials array...
                that can't be true, or?
                  Sounds like you've tried to store the material of an entity with the Default material. Entities with default material return nil for entity.material .
                    kiesewetter
                    i used some of the materials looking like wood. do they belong to the default materials that return nil?
                    another opportunity could be to save the whole model in the script, then to do something in the script an after that to load the old version that was saved before.
                      Ok - I'm looking at your snippet again:
                      <span class="syntaxdefault"><br />mod&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />ents&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mod</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities&nbsp;<br />sel&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mod</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection<br />mats&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mod</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">materials<br />mat</span><span class="syntaxkeyword">=</span><span class="syntaxstring">""<br /><br /></span><span class="syntaxdefault">sel</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;</span><span class="syntaxdefault">mat</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">display_name<br /></span><span class="syntaxkeyword">}<br /><br /><br /></span><span class="syntaxdefault">ents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mats</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">mat</span><span class="syntaxkeyword">]<br />}&nbsp;<br />&nbsp;</span><span class="syntaxdefault"></span>
                      What are you trying to do with this?
                      <span class="syntaxdefault"><br />sel</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;</span><span class="syntaxdefault">mat</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">display_name<br /></span><span class="syntaxkeyword">}<br />&nbsp;</span><span class="syntaxdefault"></span>
                      You're assigning the variable mat a material name - which in effect you'll only have the name of the material of the last entity in the selection you just iterated over.
                      And I also don't understand what you try to do next:
                      <span class="syntaxdefault"><br />ents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mats</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">mat</span><span class="syntaxkeyword">]<br />}&nbsp;<br />&nbsp;</span><span class="syntaxdefault"></span>
                      No. But at least one of the entities you iterate over in the selection has no material (returns nil) - so you need to inspect the data you have at hand. (Maybe you have an edge in the selection without any materials?)
                        You current snippets will only set 'mat' to the last value founs as you aren't doing anything with it in side the {} block ??
                        Your original example ought to work with set attrib' e.material.display_name... IF you use the iteration loops to set/set the attributes
                        e.material=mat_temp
                        by name [NOT by finding it in the materials list] then if it's '=nil' then the default material is used anyway ?
                          I looked at your original code and made some smaller rewrites:
                          <span class="syntaxdefault"><br /></span><span class="syntaxcomment">#&nbsp;Store&nbsp;face's&nbsp;material&nbsp;name&nbsp;as&nbsp;attributes<br /></span><span class="syntaxdefault">model&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each&nbsp;</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;</span><span class="syntaxdefault">next&nbsp;unless&nbsp;e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;if&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material<br />&nbsp;&nbsp;&nbsp;&nbsp;e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set_attribute</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"time"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"material"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">name</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">end<br /></span><span class="syntaxkeyword">}<br /><br /><br /></span><span class="syntaxcomment">#&nbsp;Read&nbsp;face's&nbsp;material&nbsp;name&nbsp;from&nbsp;attributes<br /></span><span class="syntaxdefault">model&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />materials&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">materials<br />model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each&nbsp;</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;</span><span class="syntaxdefault">next&nbsp;unless&nbsp;e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">material&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"time"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"material"</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;if&nbsp;</span><span class="syntaxdefault">material&nbsp;</span><span class="syntaxkeyword">&&&nbsp;</span><span class="syntaxdefault">materials</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">material</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">materials</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">material</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;</span><span class="syntaxdefault">end<br /></span><span class="syntaxkeyword">}<br />&nbsp;</span><span class="syntaxdefault"></span>
                          Note
                          I did in fact have to use material.name as oppose to material.display_name.
                          I did some testing on the default metric template in SU8 with the Susan character. When I used .display_name I could not restore the material for her hair.
                          SketchUp's material editor lists the material as "Color_B24" and so do .display_name.
                          However, model.materials['Color_B24'] returns nil.
                          When I used .name I got "[Color_B24]" - and when I used model.materials['[Color_B24]'] I got the correct material.
                          So for some reason SU decides to hide start and end brackets.
                          Once again the API docs fail to provide accurate data.
                          It appear that .display_name is intended to be used only as presentation to the user - while for referencing materials one should use .name. šŸ˜’ sigh
                            kiesewetter
                            first of all i got to thank you fpr the time youre spending.
                            i wrote the last script to test wheter it is possible to assign a material to an entitiy in that way. i wanted to execute it with only one face selected that has a material (the one looking like wood). the name of the material should be saved in the variable mat.
                            that should be realised with
                            sel.each{|e|
                            mat=e.material.display_name
                            after that i wanted to assigne every entity in the model with the same material with that part of the code
                            ents.each{|e|
                            e.material = mats[mat]
                            i still don't know how to acces a material, to save an reload it. using the diplay_name and saving it as an attribut didn't work so far.
                              Did you try the snipped I just posted?
                              (p.s. can you please wrap the code you post in code blocks? - Makes it easier to read.)
                                kiesewetter
                                oh, ok, when i wrote my last post yours wasn't uploaded. i'll test it tommorrow because it's meanwhile hard to hold the eyes open. thanks once more for the great help.
                                good night.
                                tim
                                  kiesewetter
                                  hallo again!
                                  saving to an attribute and reloading works šŸ˜„
                                  but now another problems appears. i only want the materials name to be stored in the attribute if it is not the name of one of the materials bau_mat, fertig_mat or inplanung.
                                  i tried to realise it with the following code, but it seems to be stored every time, even the assigned material is one of the before mentioned:
                                   if e.material.name != bau_mat.name && e.material.name != fertig_mat.name && e.material.name != inplanung.name
                                            mat_vorher = e.material.name
                                            e.set_attribute "ablauf", "material", mat_vorher
                                    <span class="syntaxdefault">invalid_materialsĀ </span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Ā </span><span class="syntaxkeyword">[</span><span class="syntaxstring">'bau_mat'</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">Ā </span><span class="syntaxstring">'fertig_mat'</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">Ā </span><span class="syntaxstring">'inplanung'</span><span class="syntaxkeyword">]<br /><br /></span><span class="syntaxdefault">unlessĀ invalid_materials</span><span class="syntaxkeyword">.include?(</span><span class="syntaxdefault">Ā e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">nameĀ </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">Ā Ā mat_vorherĀ </span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Ā e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">name<br />Ā Ā e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set_attribute</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"ablauf"</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">Ā </span><span class="syntaxstring">"material"</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">Ā mat_vorher</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">end<br /></span>
                                      kiesewetter
                                      thank you so much.
                                        kiesewetter
                                        me again...
                                        i don't know why, but the attribut "ablauf", "material" always receives a new value, even if the face's material is included in the array caled invalid_material. i'll post the code, because i realy don't know how to fix it.
                                        ents.each{|e|
                                                    if e.typename == "Face"
                                                         start = e.get_attribute "ablauf", "baubeginn"
                                                         ende = e.get_attribute "ablauf", "bauende"
                                                         if (e.material)
                                                           invalid_materials = ['bau_mat', 'fertig_mat', 'inplanung']
                                                           unless invalid_materials.include?( e.material.name )
                                                             e.set_attribute("ablauf", "material", mat_vorher)
                                                         if @woche.to_i >= start.to_i && @woche.to_i < ende.to_i
                                                           e.material = bau_mat
                                                         if @woche.to_i >= ende.to_i
                                                           e.material =fertig_mat
                                                         if @woche.to_i < start.to_i
                                                           e.material = inplanung
                                        #now the code that reloads the material
                                        def mat_back
                                           mod = Sketchup.active_model
                                           ents = mod.entities
                                           mats = mod.materials
                                           default_mat = mats.add "standardwert"
                                           default_mat.color = [50,250,50]
                                           ents.each{|e|
                                                            if (e.get_attribute "ablauf", "material")
                                                             mat_temp=e.get_attribute "ablauf", "material"
                                                             e.material=mats[mat_temp]
                                                            else
                                                             e.material=default_mat
