    Saving an reloading a material from an attribut
    18 Posts 3 Posters 1.5k Views 3 Watching
      Sounds like you've tried to store the material of an entity with the Default material. Entities with default material return nil for entity.material .
      • K
        kiesewetter
        i used some of the materials looking like wood. do they belong to the default materials that return nil?
        another opportunity could be to save the whole model in the script, then to do something in the script an after that to load the old version that was saved before.
          Ok - I'm looking at your snippet again:
          <span class="syntaxdefault"><br />mod&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />ents&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mod</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities&nbsp;<br />sel&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mod</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection<br />mats&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mod</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">materials<br />mat</span><span class="syntaxkeyword">=</span><span class="syntaxstring">""<br /><br /></span><span class="syntaxdefault">sel</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;</span><span class="syntaxdefault">mat</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">display_name<br /></span><span class="syntaxkeyword">}<br /><br /><br /></span><span class="syntaxdefault">ents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mats</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">mat</span><span class="syntaxkeyword">]<br />}&nbsp;<br />&nbsp;</span><span class="syntaxdefault"></span>
          What are you trying to do with this?
          <span class="syntaxdefault"><br />sel</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;</span><span class="syntaxdefault">mat</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">display_name<br /></span><span class="syntaxkeyword">}<br />&nbsp;</span><span class="syntaxdefault"></span>
          You're assigning the variable mat a material name - which in effect you'll only have the name of the material of the last entity in the selection you just iterated over.
          And I also don't understand what you try to do next:
          <span class="syntaxdefault"><br />ents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mats</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">mat</span><span class="syntaxkeyword">]<br />}&nbsp;<br />&nbsp;</span><span class="syntaxdefault"></span>
          No. But at least one of the entities you iterate over in the selection has no material (returns nil) - so you need to inspect the data you have at hand. (Maybe you have an edge in the selection without any materials?)
            You current snippets will only set 'mat' to the last value founs as you aren't doing anything with it in side the {} block ??
            Your original example ought to work with set attrib' e.material.display_name... IF you use the iteration loops to set/set the attributes
            e.material=mat_temp
            by name [NOT by finding it in the materials list] then if it's '=nil' then the default material is used anyway ?
              I looked at your original code and made some smaller rewrites:
              <span class="syntaxdefault"><br /></span><span class="syntaxcomment">#&nbsp;Store&nbsp;face's&nbsp;material&nbsp;name&nbsp;as&nbsp;attributes<br /></span><span class="syntaxdefault">model&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each&nbsp;</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;</span><span class="syntaxdefault">next&nbsp;unless&nbsp;e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;if&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material<br />&nbsp;&nbsp;&nbsp;&nbsp;e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set_attribute</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"time"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"material"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">name</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">end<br /></span><span class="syntaxkeyword">}<br /><br /><br /></span><span class="syntaxcomment">#&nbsp;Read&nbsp;face's&nbsp;material&nbsp;name&nbsp;from&nbsp;attributes<br /></span><span class="syntaxdefault">model&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />materials&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">materials<br />model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each&nbsp;</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;</span><span class="syntaxdefault">next&nbsp;unless&nbsp;e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">material&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"time"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"material"</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;if&nbsp;</span><span class="syntaxdefault">material&nbsp;</span><span class="syntaxkeyword">&&&nbsp;</span><span class="syntaxdefault">materials</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">material</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">materials</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">material</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;</span><span class="syntaxdefault">end<br /></span><span class="syntaxkeyword">}<br />&nbsp;</span><span class="syntaxdefault"></span>
              Note
              I did in fact have to use material.name as oppose to material.display_name.
              I did some testing on the default metric template in SU8 with the Susan character. When I used .display_name I could not restore the material for her hair.
              SketchUp's material editor lists the material as "Color_B24" and so do .display_name.
              However, model.materials['Color_B24'] returns nil.
              When I used .name I got "[Color_B24]" - and when I used model.materials['[Color_B24]'] I got the correct material.
              So for some reason SU decides to hide start and end brackets.
              Once again the API docs fail to provide accurate data.
              It appear that .display_name is intended to be used only as presentation to the user - while for referencing materials one should use .name. 😒 sigh
              • K
                kiesewetter
                first of all i got to thank you fpr the time youre spending.
                i wrote the last script to test wheter it is possible to assign a material to an entitiy in that way. i wanted to execute it with only one face selected that has a material (the one looking like wood). the name of the material should be saved in the variable mat.
                that should be realised with
                sel.each{|e|
                mat=e.material.display_name
                after that i wanted to assigne every entity in the model with the same material with that part of the code
                ents.each{|e|
                e.material = mats[mat]
                i still don't know how to acces a material, to save an reload it. using the diplay_name and saving it as an attribut didn't work so far.
                  Did you try the snipped I just posted?
                  (p.s. can you please wrap the code you post in code blocks? - Makes it easier to read.)
                  • K
                    kiesewetter
                    oh, ok, when i wrote my last post yours wasn't uploaded. i'll test it tommorrow because it's meanwhile hard to hold the eyes open. thanks once more for the great help.
                    good night.
                    tim
                    • K
                      kiesewetter
                      hallo again!
                      saving to an attribute and reloading works 😄
                      but now another problems appears. i only want the materials name to be stored in the attribute if it is not the name of one of the materials bau_mat, fertig_mat or inplanung.
                      i tried to realise it with the following code, but it seems to be stored every time, even the assigned material is one of the before mentioned:
                       if e.material.name != bau_mat.name && e.material.name != fertig_mat.name && e.material.name != inplanung.name
                                mat_vorher = e.material.name
                                e.set_attribute "ablauf", "material", mat_vorher
                        <span class="syntaxdefault">invalid_materials </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxstring">'bau_mat'</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">'fertig_mat'</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">'inplanung'</span><span class="syntaxkeyword">]<br /><br /></span><span class="syntaxdefault">unless invalid_materials</span><span class="syntaxkeyword">.include?(</span><span class="syntaxdefault"> e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">name </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  mat_vorher </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">name<br />  e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set_attribute</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"ablauf"</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">"material"</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> mat_vorher</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">end<br /></span>
                        • K
                          kiesewetter
                          thank you so much.
                          • K
                            kiesewetter
                            me again...
                            i don't know why, but the attribut "ablauf", "material" always receives a new value, even if the face's material is included in the array caled invalid_material. i'll post the code, because i realy don't know how to fix it.
                            ents.each{|e|
                                        if e.typename == "Face"
                                             start = e.get_attribute "ablauf", "baubeginn"
                                             ende = e.get_attribute "ablauf", "bauende"
                                             if (e.material)
                                               invalid_materials = ['bau_mat', 'fertig_mat', 'inplanung']
                                               unless invalid_materials.include?( e.material.name )
                                                 e.set_attribute("ablauf", "material", mat_vorher)
                                             if @woche.to_i >= start.to_i && @woche.to_i < ende.to_i
                                               e.material = bau_mat
                                             if @woche.to_i >= ende.to_i
                                               e.material =fertig_mat
                                             if @woche.to_i < start.to_i
                                               e.material = inplanung
                            #now the code that reloads the material
                            def mat_back
                               mod = Sketchup.active_model
                               ents = mod.entities
                               mats = mod.materials
                               default_mat = mats.add "standardwert"
                               default_mat.color = [50,250,50]
                               ents.each{|e|
                                                if (e.get_attribute "ablauf", "material")
                                                 mat_temp=e.get_attribute "ablauf", "material"
                                                 e.material=mats[mat_temp]
                                                else
                                                 e.material=default_mat
