    [req] tracing bitmaps?
    39 Posts 9 Posters 5.8k Views 9 Watching
      hmmm... the lines there aren't even. the fold distorted them.
      Would be interesting to see the results you get.
      Though I think I'd personally trace that by hand in order to ensure clean geometry.
      • jeff hammondJ Offline
        @jo-ke said:
        I've attached a typical florplan, that I usually use.
        wow, that's pretty sloppy (as far as precision is concerned)
        i'm thinking the best approach for that file is manually tracing /redrawing in sketchup or another type of cad app.
        • FrederikF Offline
          Frederik
          i'm thinking the best approach for that file is manually tracing in sketchup.
          I agree...
          Whenever I've got drawings/plans like this, I import them to SU, scale accordingly and trace it in SU...
          I don't believe you'll experience any shortcut in this case...
          Cheers
          Kim Frederik
          • jo-keJ Offline
            jo-ke
            You're right, the quality of the plan is terrible. But this is often the quality I get from the customers.
            Tracing it by hand in sketchup is normaly the way I'm doing it. I thought that there may be a special tracing plugin to do that job.
            Another usefull part for me of this funktion would be designing rugs. I usually do that in corel draw, then I export that as a bitmap and texture a poly in SU. In that case I'm not able to change single colors of the pattern. If I export the bitmap to su as a dwg, the result isn't usable. In the next days I'm going to upload some examples.
            http://www.zz7.de
            • kenK Offline
              ken
              So I am reading these post, go back to my email and find this program notice. Note, I haven't tried this program, however, I do have their PDF 2 DXF program and it works OK.
              So I am not endorsing this program, but just showing another possible solution.
              Paper/Picture 2 DXF
              Convert paper drawings or pictures into DXF files with the software CAD-KAS Paper-Picture 2 DXF. You can download the free trial version here.
              (www.cadkas.com)
              Ken
              • charly2008C Offline
                charly2008
                I've tried different options with the plan. This was the best thing I could achieve so far. A professional may be able to get even more.
                Charly
                Grundriss.skp
                  charly2008
                  After I had optimized a bit the image in PS , the plan now looks like this. I do not know whether this is helpful.
                  Charly
                  Grundriss.skp
                  • jo-keJ Offline
                    jo-ke
                    the first one looks quite good. I don't have SU8 yet, so I'm not able to open the file.
                    I think the problem will be after the push/pull function, the walls won't look plane.
                    But this could be a solution for my carpet problem
                    http://www.zz7.de
                    • 3 Offline
                      3eighty
                      Inkscape.org .....Check out this great FREE program...Does what you want and lots more....
                      • mitcorbM Offline
                        mitcorb
                        I thought there were size limitations in Inkscape, ie pixels/ resolution? Has this improved? I will check if I can.
                          charly2008
                          Hi 3eighty,
                          I have Inkscape for a while, but I have not worked much with it. But it seems to also not bad and it is free. The problem in both programs the result depends on the quality of the bitmap.
                          Charly
                            museummaker
                            Bookmarked 👍 +1
                              charly2008
                              Hi to Everyone,
                              I have drawn a simple rectangle in SketchUp and this exported as BMP. With this BMP I experimented in both programs. From Vector Magic I received a double rectangle instead a single rectangle and from Inkscape I received a very different result. While the image edges are represented as single line or vectors.
                              I have less experience in vectorization of objects and I do not know if I'm doing something wrong. Are here in the forum experts who are familiar with this procedures? I would be very happy if someone could help and explain.
                              Charly
                              • jo-keJ Offline
                                jo-ke
                                OK here is my rug-problem! It's a different situation but the same problem:
                                I am drawing the designs of my rugs with photoshop or coreldraw. If the design is a bitmap I can trace it with coreldraw and I can save it as a dwg file. unfortunately the vectors are not filled when I import it to SU so I can't use the pushpull function
                                coreldraw:
                                SU after import
                                real rug
                                http://www.doerr-lu.de/nmweb//_actions/nmweb_action_getfile.php?field_fileid=537
                                trace.skp
                                http://www.zz7.de
                                • jo-keJ Offline
                                  jo-ke
                                  I used the same method with the floorplan
                                  vectorising in corel X3. it was a quite good result, the tracing function in corel is very good. no postprocess, export as dwg, import in SU and no filled fields...
                                  grundriss-trace.skp
                                  http://www.zz7.de
                                    charly2008
                                    Hi jo-ke,
                                    there are many stray lines (plugin) . they have to be corrected manually.
                                    Charly
                                    trace.skp
                                    • jo-keJ Offline
                                      jo-ke
                                      wow charly, this looks better. how did you fill the fileds?
                                      http://www.zz7.de
                                        charly2008
                                        it is the same in this drawing stray lines and open contours.
                                          charly2008
                                          With the plugin "make faces 1.4"
                                            @charly2008 said:
                                            I removed all the stray lines but you can see some of the contour lines are not closed. This finding is hard work.
                                            And surely that isn't usable as a working model, is it? There isn't a single straight line there...
