    [req] tracing bitmaps?
    39 Posts 9 Posters 5.3k Views 9 Watching
    • charly2008C Offline
      charly2008
      After I had optimized a bit the image in PS , the plan now looks like this. I do not know whether this is helpful.
      Charly
      Grundriss.skp
      • jo-keJ Offline
        jo-ke
        the first one looks quite good. I don't have SU8 yet, so I'm not able to open the file.
        I think the problem will be after the push/pull function, the walls won't look plane.
        But this could be a solution for my carpet problem
        http://www.zz7.de
        • 3 Offline
          3eighty
          Inkscape.org .....Check out this great FREE program...Does what you want and lots more....
          • mitcorbM Offline
            mitcorb
            I thought there were size limitations in Inkscape, ie pixels/ resolution? Has this improved? I will check if I can.
              charly2008
              Hi 3eighty,
              I have Inkscape for a while, but I have not worked much with it. But it seems to also not bad and it is free. The problem in both programs the result depends on the quality of the bitmap.
              Charly
                museummaker
                Bookmarked 👍 +1
                  charly2008
                  Hi to Everyone,
                  I have drawn a simple rectangle in SketchUp and this exported as BMP. With this BMP I experimented in both programs. From Vector Magic I received a double rectangle instead a single rectangle and from Inkscape I received a very different result. While the image edges are represented as single line or vectors.
                  I have less experience in vectorization of objects and I do not know if I'm doing something wrong. Are here in the forum experts who are familiar with this procedures? I would be very happy if someone could help and explain.
                  Charly
                  • jo-keJ Offline
                    jo-ke
                    OK here is my rug-problem! It's a different situation but the same problem:
                    I am drawing the designs of my rugs with photoshop or coreldraw. If the design is a bitmap I can trace it with coreldraw and I can save it as a dwg file. unfortunately the vectors are not filled when I import it to SU so I can't use the pushpull function
                    coreldraw:
                    SU after import
                    real rug
                    http://www.doerr-lu.de/nmweb//_actions/nmweb_action_getfile.php?field_fileid=537
                    trace.skp
                    http://www.zz7.de
                    • jo-keJ Offline
                      jo-ke
                      I used the same method with the floorplan
                      vectorising in corel X3. it was a quite good result, the tracing function in corel is very good. no postprocess, export as dwg, import in SU and no filled fields...
                      grundriss-trace.skp
                      http://www.zz7.de
                        charly2008
                        Hi jo-ke,
                        there are many stray lines (plugin) . they have to be corrected manually.
                        Charly
                        trace.skp
                        • jo-keJ Offline
                          jo-ke
                          wow charly, this looks better. how did you fill the fileds?
                          http://www.zz7.de
                            charly2008
                            it is the same in this drawing stray lines and open contours.
                              charly2008
                              With the plugin "make faces 1.4"
                                @charly2008 said:
                                I removed all the stray lines but you can see some of the contour lines are not closed. This finding is hard work.
                                And surely that isn't usable as a working model, is it? There isn't a single straight line there...
                                  charly2008
                                  I removed all the stray lines but you can see some of the contour lines are not closed. This finding is hard work. Oh I remembered there is a trouble shooting style.
                                  • jo-keJ Offline
                                    jo-ke
                                    I can't find the make faces plugin...
                                    at the moment I'm trying the plan tools http://forums.sketchucation.com/viewtopic.php?f=323&t=30512&start=0&hilit=make+faces
                                    http://www.zz7.de
                                      charly2008
                                      Hi Thomas,
                                      [/quote]
                                      And surely that isn't usable as a working model, is it? There isn't a single straight line there...[/quote]
                                      that seems to be the Problem!
                                      Charly
                                        charly2008
                                        Jo-ke,
                                        if it is not in your Tools menu, have a look here:
                                        Smustard(TM) - the Companion to Sketchup(TM) - Plugins and Scripts
                                        List of Smustard plugins and ruby scripts for Sketchup
                                        (www.smustard.com)
                                        • jo-keJ Offline
                                          jo-ke
                                          @charly2008 said:
                                          Jo-ke,
                                          (www.smustard.com)
                                          Ah thank you. now of course I've found it.
                                          http://www.zz7.de
                                            charly2008
                                            Thomas,
                                            I have found now a plan with a resolution of 3335 x 4151 pixels. The result is good. But what I still do not understand is that double lines are generated.
                                            Loft.skp
                                            • 2 / 2
