    [req] tracing bitmaps?
    39 Posts 9 Posters 5.8k Views 9 Watching
      If you turn on edge colour by axis?
      • charly2008C Offline
        charly2008
        You think so?
        Lines by colors.skp
          Not bad... I get DWGs from AutoCAD worse than that...
          • jo-keJ Offline
            jo-ke
            Oh thank you for your help.
            I've attached a typical florplan, that I usually use.
            I can trace that with corel trace, export it as a dwg, import it to sketchup, but the result isn't as good as I need to have.
            charly, I will check your link, sounds usefull.
            http://www.zz7.de
              hmmm... the lines there aren't even. the fold distorted them.
              Would be interesting to see the results you get.
              Though I think I'd personally trace that by hand in order to ensure clean geometry.
              • jeff hammondJ Offline
                wow, that's pretty sloppy (as far as precision is concerned)
                i'm thinking the best approach for that file is manually tracing /redrawing in sketchup or another type of cad app.
                • FrederikF Offline
                  Frederik
                  i'm thinking the best approach for that file is manually tracing in sketchup.
                  I agree...
                  Whenever I've got drawings/plans like this, I import them to SU, scale accordingly and trace it in SU...
                  I don't believe you'll experience any shortcut in this case...
                  Cheers
                  Kim Frederik
                  • jo-keJ Offline
                    jo-ke
                    You're right, the quality of the plan is terrible. But this is often the quality I get from the customers.
                    Tracing it by hand in sketchup is normaly the way I'm doing it. I thought that there may be a special tracing plugin to do that job.
                    Another usefull part for me of this funktion would be designing rugs. I usually do that in corel draw, then I export that as a bitmap and texture a poly in SU. In that case I'm not able to change single colors of the pattern. If I export the bitmap to su as a dwg, the result isn't usable. In the next days I'm going to upload some examples.
                    http://www.zz7.de
                    • kenK Offline
                      ken
                      So I am reading these post, go back to my email and find this program notice. Note, I haven't tried this program, however, I do have their PDF 2 DXF program and it works OK.
                      So I am not endorsing this program, but just showing another possible solution.
                      Paper/Picture 2 DXF
                      Convert paper drawings or pictures into DXF files with the software CAD-KAS Paper-Picture 2 DXF. You can download the free trial version here.
                      (www.cadkas.com)
                      Ken
                        charly2008
                        I've tried different options with the plan. This was the best thing I could achieve so far. A professional may be able to get even more.
                        Charly
                        Grundriss.skp
                          charly2008
                          After I had optimized a bit the image in PS , the plan now looks like this. I do not know whether this is helpful.
                          Charly
                          Grundriss.skp
                          • jo-keJ Offline
                            jo-ke
                            the first one looks quite good. I don't have SU8 yet, so I'm not able to open the file.
                            I think the problem will be after the push/pull function, the walls won't look plane.
                            But this could be a solution for my carpet problem
                            http://www.zz7.de
                            • 3 Offline
                              3eighty
                              Inkscape.org .....Check out this great FREE program...Does what you want and lots more....
                              • mitcorbM Offline
                                mitcorb
                                I thought there were size limitations in Inkscape, ie pixels/ resolution? Has this improved? I will check if I can.
                                  charly2008
                                  Hi 3eighty,
                                  I have Inkscape for a while, but I have not worked much with it. But it seems to also not bad and it is free. The problem in both programs the result depends on the quality of the bitmap.
                                  Charly
                                    museummaker
                                    Bookmarked 👍 +1
                                      charly2008
                                      Hi to Everyone,
                                      I have drawn a simple rectangle in SketchUp and this exported as BMP. With this BMP I experimented in both programs. From Vector Magic I received a double rectangle instead a single rectangle and from Inkscape I received a very different result. While the image edges are represented as single line or vectors.
                                      I have less experience in vectorization of objects and I do not know if I'm doing something wrong. Are here in the forum experts who are familiar with this procedures? I would be very happy if someone could help and explain.
                                      Charly
                                      • jo-keJ Offline
                                        jo-ke
                                        OK here is my rug-problem! It's a different situation but the same problem:
                                        I am drawing the designs of my rugs with photoshop or coreldraw. If the design is a bitmap I can trace it with coreldraw and I can save it as a dwg file. unfortunately the vectors are not filled when I import it to SU so I can't use the pushpull function
                                        coreldraw:
                                        SU after import
                                        real rug
                                        http://www.doerr-lu.de/nmweb//_actions/nmweb_action_getfile.php?field_fileid=537
                                        trace.skp
                                        http://www.zz7.de
                                        • jo-keJ Offline
                                          jo-ke
                                          I used the same method with the floorplan
                                          vectorising in corel X3. it was a quite good result, the tracing function in corel is very good. no postprocess, export as dwg, import in SU and no filled fields...
                                          grundriss-trace.skp
                                          http://www.zz7.de
                                            charly2008
                                            Hi jo-ke,
                                            there are many stray lines (plugin) . they have to be corrected manually.
                                            Charly
                                            trace.skp
