    Importing Floor Plan Image Files
    7 Posts 4 Posters 605 Views 4 Watching
      Ben Ritter
      What is the trick to importing a clear image of a floor plan for tracing? I have a large .tif file that becomes fuzzy when imported as a texture. Is there another method I should be using?
      Thanks. Ben
        It's a common problem. Well not a problem, more a limitation. See this for a little more info...
        Error 404 (Not Found)!!1
        (sketchup.google.com)
        • jeff hammondJ Offline
          i think that's old info because SU can now support up to 2048x2048 if you have 'use maximum texture size' enabled via preferences>open GL
          [how's my bling looking ? πŸ˜„]
          • KrisidiousK Offline
            Krisidious
            you shouldn't have any issues with Tiff if you have max texture size selected.
            By: Kristoff Rand
              @Jeff
              Now your rolling on 22's πŸ˜‰
                Ben Ritter
                Thank you everyone, I will make sure the max texture size is checked and will try to downsize the image first.
                  Ben Ritter
                  Thanks again. I set max texture size and was able to use an image of 4000 pixels with no problems. Using SU8.
