    [Plugin] Caleidos4D Ribbon Pubblic Beta 1.1 (29 oct 2010)
    50 Posts 21 Posters 38.5k Views 21 Watching
    • I Offline
      iwanwidjaja
      Hi Caleidos4D,
      Its a great plug in, thanks for share it
      Just a little curiosity, will it possible to make some option to choose between portrait and landscape configuration of the ribbon? As many of us use wide screen monitor, the modeling space begin to shrink in a very wide proportion when the ribbon is active πŸ˜†
      Regards'
      Iwan
      • majidM Offline
        majid
        thanxs mates for your kind helps πŸ˜„ .the question is that it doesn't display anything ( I mean that I have installed the plugs..etc... and also created a simple qube) ... I can't see anything...any red-green-blue axes ...etc...
        • EarthMoverE Offline
          EarthMover
          Majid, I believe you Caleidos4D Ribbon is covering your Sketchup window. You have to minimize it and then resize both the Sketchup window and the Ribbon to fit on the screen together. You can put the Ribbon above the Sketchup window or below, or on a second monitor, but the ribbon does not dock within Sketchup. It is a floating web dialog that overlaps Sketchup, so some resizing is necessary for it to all fit in your monitor.
          Content Creator at Skapeup
          • majidM Offline
            majid
            thanx again.... I was thinking that it will cover my sketchup screen , so that I get rid of all plugin toolbars... 😞 (as I saw a black screen on some screenshots above) . maybe it could be an option for next update ,plz . πŸ˜„ it workes fine in way you described. thanx again
              caleidos4d
              thank to all friends for help in topic πŸ†™ my english is very bad....
              this is a .gif for usage and preview features in next release
              http://www.caleidos4d.it
              • troyhomeT Offline
                troyhome
                [attachment=0:8asf8rxq]<!-- ia0 -->Usage_and_Preview.gif<!-- ia0 -->[/attachment:8asf8rxq]
                can't wait to try this out- in English πŸ˜„
                IOviz.com
                SU Pro 2024 PC
                  Jim
                  For translate:
                  in the next version, I will translate the tooltips in English but I also accept suggestions πŸ˜„
                  Well, I appreciate this because I only know English; but I was also trying to come up with a language translation strategy in order to provide translations to any language.
                  I think JavaScript can be used to iterate over the tooltips, and set the Text according to the tooltip id (for example.)
                  • Bob JamesB Offline
                    Bob James
                    @troyhome said:
                    @khai said:
                    all I'm getting at the link is
                    "alterVista
                    La risorsa richiesta Γ¨ accessibile qui
                    you have to click "qui"
                    I'm afraid I can't even find "La risorsa richiesta è accessibile qui so I can click on "qui" 😞 😳
                    Update
                    I got it by pasting in "http://caleidos.altervista.org/Download/caleidos4d_Ribbon.zip" and it automatically downloaded.
                      caleidos4d
                      Update: 1.1 πŸ˜‰
                        EarthMover
                        Nice update. English tooltips are perfect! Any plans to add FredoScale?
                          caleidos4d
                          I wanted insert SfedoScale and BezierSpline, already in this release, but I can not find the call for the plugins in various fredo's libraries ...
                            tony bombata
                            renderplus rpedits copy selection tool bug splatted EVERY time i ran the command - so i started removing my most recent plugins - and caledios was the culprit 😞
                              kyyu
                              Caleidos4D,
                              Thanks for the plugin. Looks interesting. Got a question. When you select the major frames on the left side (Costruction[oops,btw spelling error], Projection, 2D, Modelurs,..etc), they change to a highlighted orange color. But when you select another, any previous ones are still hightlighted orange. Wondering if this is a bug?
                              Oh, and an off topic question. Is there a easy html editor for laying out buttons, like this, on a webpage? Or wondering what editor, you used? I mean, if a beginner wanted to make the html portion of a web UI, like this. I can make a simple one by hand, like a column of buttons, but not like this.
                              -Kwok
                                caleidos4d
                                EDIT 23-Sep-2011 New Download URL:
                                DOWNLOAD Caleidos4D Ribbon Pubblic Beta 1.1
                                ( http://caleidos4d.blogspot.com/2011/08/caleidos4d-ribbon-pubblic-beta-11.html )
                                • guanjinG Offline
                                  guanjin
                                  This fun, I can be free to load the new plug-in, strong
                                  • majidM Offline
                                    majid
                                    dear mate, I like your plugin , and here saw a request, that seems to be combined in your plugin:
                                    http://forums.sketchucation.com/viewtopic.php?f=10&t=46094
                                    do you mind to play with your interface please? I guess it'd be a great step forward . πŸ‘ thank you again
                                    • H Offline
                                      heglisonmarques
                                      Como faΓ§o para instalar o Caleidos4d
                                      • mitcorbM Offline
                                        mitcorb
                                        I think you are asking how to install this plugin?
                                        I believe there is a link to an external website or hosting site and you must download from there. Looks like it may be "caleidos4d.blogspot.com"
                                        • 3 / 3
