    [Plugin] Hidden Manager (08.Feb.2015)
    48 Posts 19 Posters 39.2k Views 19 Watching
    • R Do not disturb
      rv1974
      @schorradt said:
      No feedback?! I am looking forward to your opinions πŸ˜‰
      Well sorry if I upset you but this manager is rather useless IMHO. Why?
      Because your model is itself a manager of your 3d elements. And if you'd turn on "show the hidden geometry" mode you can easily select\unhide\view it's properties without any additional tables.
        I don't see as a bad idea. It's like the Unhide By Name in 3dsMax. In complex models it can be easier to locate the object in a list instead of visually in the model.
        All though I normally hide/unhide objects by layer, I occasionally hide objects temporarily - and some times several. Bringing up a list without leaving the current viewport is a nice thing.
          Pherim
          I also think it's a good idea, as you can see all your hidden objects at once. The only thing I miss is that hidden objects within groups or components are displayed but I don't know whether this can be done. Maybe similar to the Outliner as a tree structure?
          • CAntonisC Offline
            CAntonis
            Its a very interesting plugin! And as it is your first I feel like congatulating you for doing work that help the rest of us , have a better workflow.
            I could really make use of it, but I am not going to download yet. You should really listen to Thom, if you don't mind me say, cause he is very experienced.
            This plugin can be "a must have" for everyone.
            Keep up the good work, and the feedback will come.
            CAntonis
              caleidos4d
              @thomthom said:
              Are you sure you extracted all the files correctly?
              (btw, for those who report it's not working, what SU version do you use? And what OS?)
              yes... as Ken' post.
              i have windows 7 and sketchup 8 pro
              http://www.caleidos4d.it
              • schorradtS Offline
                schorradt
                Thx for the feedback...
                Is there a function to the undo function to prevent
                for the undo stack? Or a code snipped?
                The error is to be here, I can not find...
                http://www.henryschorradt.de/
                  There is a way to make the previous or next transparent, but I've had bad experience with them, tricky to get right. Merging undo stack items can be unpredictable to deal with. And both would cause the wrong name to appear in the Edit>Undo menu. I'd not recommend them.
                    caleidos4d
                      schorradt
                      okay ... i looking for another solution...
                      @Caleidos4D
                      Sorry ,but in my testenvirement, i can´t see any errors 😞 . i do not understand it. maybe another plugin for a conflict?!
                      • kmeadK Offline
                        kmead
                        Honestly this was an unnecessarily rude response. It may be useless to you, but may be of great use to others whose work process is different from yours.
                        I tend to hide some geometry to work on other items, being able to toggle a specific item into visibility without having to make all of them visible and the attendant slowdown of the program because of the huge overhead increase of all the sub geometry that also turns on when I show hidden geometry is a real boon.
                        So, thanks for an interesting and I think, quite useful plugin. Great first effort, would that I were able to be able to reciprocate with a plugin of my own. In any case thank you.
                        All the best and looking forward to your future efforts.
                        Karl
                        I created Dilbertville, sorry about that...
                          poohnut
                          Thanksssss
                            schorradt
                            little change in this Plugin.
                            • CAntonisC Offline
                              CAntonis
                              17 Of january is my nameday! And this is a wonderful present!Downloaded and gonna test it!
                              Thank U very much!
                                schorradt
                                Update: 16.Feb.2011
                                • Change to start the observer on activate and remove on deaktivate now. i hope the bugsplash from other Plugins (ImageTrimmer or Slicer etc...) is removed...
                                  bdbox
                                  Error Loading File mx_hidemanager_loader.rb
                                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/mx_hidemanager_loader.rb:58: syntax error
                                  mx_hiddenmanager = SketchupExtension.new "Hidden Manager", File.join ("mx_hidemanager","mx_hidemanager.rbs")
                                    schorradt
                                    I'm sorry, but it works on my computer. I can find no error.
                                    Perhaps the pathfunctions does not feature in Sketchup 7 !?
                                      Henry:
                                      This can confuse Ruby - you have space after the method name and the brackets. ( File.join ) On top of that you have that as one of the argument of another method call ( SketchupExtension.new ) where you don't use brackets.
                                      To avoid potential errors, always use brackets. But most important of all, never leave a space between the method name and the brackets.
                                      It's a bit odd that a SU7 user should report this error, because SU8's ruby is more strict. Regardless, this should work:
                                      mx_hiddenmanager = SketchupExtension.new( "Hidden Manager", File.join("mx_hidemanager","mx_hidemanager.rbs") )
                                        bdbox
                                        @thomthom said:
                                        Henry:
                                        i got this error:
                                        No such file to load -- mx_hidemanager/mx_hidemanager.rbsError Loading File mx_hidemanager_loader.rb
                                          mac1
                                          schorradt
                                          What capability does this provide vs what the outliner has now??
                                          • N Offline
                                            nomeradona
                                            nifty tool as your hidden elements are in one place. I can see the relevance.
                                            • 2 / 3
