    [Plugin] Selection Toys
    594 Posts 121 Posters 397.0k Views 121 Watching
      Khai
      ah. thanks for your help then.. this explains all my problems with this Ruby. we're not compatible.. but thats ok.
      • N3TON Offline
        N3TO
        @thomthom said:
        I can make so sense why you would not have a Selection Toys menu item under tools and various Context Menu entries (which depend on what you right-click)
        I was about to ask if you'd checked the Preferences for Selection Toys, but if you have not menu... I'm really stomped.
        Can you post a screenshot of your Tools menu?
        Hello Thomas!
        It happens with me also! You can see a screenshot here
        http://www.netcond.net/N3TO/Screenshot_toolsmenu.jpg
        I see all posts but I can't resolve the trouble.
        apologies for my bad english...
          Check the Tools menu.
          Tools -> Selection Toys -> Enable Toolbar
          then after you do that - check the menu you showed in the screenshot.
            Version 2.2.1
            • Fixed Select DC Instances
              Sorry - I forgot to include a file. Redownload.
              • brookefoxB Offline
                brookefox
                It was working in V7, but I can't get Sel Toys working in V8. Feeling stupid for a number of reasons.
                My configurtion of Sel Toys:
                C:\Program Files (x86)\Google\Google SketchUp 8\Plugins\TT_Lib
                C:\Program Files (x86)\Google\Google SketchUp 8\Tools\TT_Select_Toys
                After SU8 re-start:
                no context picks for Sel Toys
                no pick for Sel Toys in Tools menu drop down
                ~ Brooke
                  Don't put plugins in the Tools folder.
                  There should be
                  C:\Program Files (x86)\Google\Google SketchUp 8\Plugins\TT_Lib\ - (inside, lots of .rb files)
                  C:\Program Files (x86)\Google\Google SketchUp 8\Plugins\tt_selection_toys.rb
                  C:\Program Files (x86)\Google\Google SketchUp 8\Plugins\TT_Select_Toys\
                    brookefox
                    OK. Thank you. I thought that since it is accessed by the tools menu..., but thinking is not my strong suite.
                    You must enable it from Tools->Selection Toys->Enable Toolbar before it appears under View->Toolbars->Selection Toys.
                    While the install didn't seem that clear to me, I didn't notice many install problems in the thread, so likely I am being thick. Perhaps because I assumed it was different than the norm when it is not. (Is the download count related to this, only 141 for such a useful tool? Or is that count only since the last update or somehow not reliable?)
                    Thanks, again.
                    ~ Brooke
                      Since last update - there's been thousands of downloads all together of the previous versions.
                      With my more recent plugins I've started to add more detailed descriptions of how they should be installed.
                        brookefox
                        I will remove and try to re-install as now for me under Tools, there is no 'Selection Toys'; and so not surprisingly, under View->Toolbars there is no 'Selection Toys'. After entity pick, context menu does not show sel toy choices.
                        Folders TT_Lib and TT_Select_Toys are both in Plugins, as is file tt_selection_toys.rb.
                        ~ Brooke
                          You need to enable the toolbar under Tools -> Selection Toys -> Enable Toolbar
                            brookefox
                            Thank you, but under Tools there is no 'Selection Toys.'
                            ~ Brooke
                              hmm.... no errors upon startup?
                                brookefox
                                Yes, a few. This is not current; I will update it soon.
                                (eval):6094: compile error
                                (eval):4921: syntax error, unexpected ',', expecting ')'
                                if (n1.between? (n2 - interval), (n2 + interval))
                                                            ^Error Loading File cd_power_extension_m.rb
                                                            ^Error Loading File cd_power_m.rb
                                                            ^no such file to load -- Projection/projection.rbError Loading File projection_extension.rb
                                no such file to load -- Projection/projection.rbError Loading File protrude.rb
                                no such file to load -- protrude/protrude.rbError Loading File vismap2_menu.rb
                                can't convert nil into String
                                ~ Brooke
                                  They refer to other plugins. You seem to have multiple issues though. You might want to consider starting from scratch..
                                    brookefox
                                    Yes, I thought they referred to other plugins, but you were kind enough to ask. I think I would much rather try to ferret out the problems with a few than mess with the score(s) that seem to be OK. After addressing the apparent issues, the current load error msg. is:
                                    Error Loading File tt_selection_toys.rb
                                    undefined method `require_version' for TT_Lib:Module
                                    ~ Brooke
                                      hm... and you have the latest TT_Lib (version 1.x) ?
                                      Can you post a screen of the content of your TT_Lib folder?
                                        brookefox
                                        Well, certainly, but I feel I have taken enough of your time and will try to re-DL and re-install in the likely event that I boobied somehow along the way...
                                        Either way I will be back.
                                        Thank you.
                                        ~ Brooke
                                          It looks like you have an old version of TT_Lib installed. The dates of the files, and the lack of many of the files from the latest version would suggest this. You can confirm by typing TT_Lib::Version into the Ruby Console and see what it returns.
                                          If you recently did download TT_Lib but did not get 1.2.0 then maybe you're getting a cached version.
                                            brookefox
                                            @thomthom said:
                                            TT_Lib::Version into the Ruby Console returns.
                                            Results:
                                            TT_Lib::Version
                                            Error: #<NameError: (eval):2537: uninitialized constant TT_Lib::Version>
                                            (eval):2537
                                            Perhaps a cached version: that may let me off the stick a little for screwing things up.
                                            I re-DLd and installed and will advise if fix fails.
                                            Many thanks.
                                            ~ Brooke
                                            • 29
                                            • 30
                                            • 6 / 30
