    [Plugin] Silhouette to Plane v1.1
    32 Posts 17 Posters 32.8k Views 17 Watching
      1 a week?
      1 a day is more appropriated πŸ˜‰
      • Didier BurD Offline
        Didier Bur
        Hi TIG,
        I suggest you change line #63 to: @model.start_operation("Silhouette to Plane") 😎
        Thanks for all your hard work !
        DB
        • TIGT Online
          Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=281445#p281445
          The correct Plane of a 'WorkPlane' is now used even if it has been Transformed inside its own Group.
          Speed and reliability improved.
          Title fixed.
          • EarthMoverE Offline
            EarthMover
            Great Script! πŸ‘ Perfect for sorting out faces that have trouble closing. Could you possibly have it so that if no work plane is selected, that it will default to a placing the silhouette on the 0 z plane? Similar to ThomThoms Flatten script in his "Plan Tools", except yours automagically creates the face and groups it.
            Content Creator at Skapeup
            • TIGT Online
              You could always make a quick WorkPlane on the ground...
              • shuraS Offline
                shura
                Just great! You are a hero, hats off to thee!
                • TIGT Online
                    This sort of image must be at each first post πŸ˜„
                      EarthMover
                      Here's another example.
                      Silhouette to plane is also great for flattening a set of looped edges you want to be planar to form a face, but cant seem to find the vert that's out of whack.
                      • X Offline
                        xrok1
                        this could be great for making face me components! render the 3d version then apply as texture to the 2d. πŸ˜„
                          Ben Ritter
                          TIG, fabulous! Thank you for the flatten to plane script as well. You are very generous, and gifted.
                            caleidos4d
                            TIG!!!
                            http://www.caleidos4d.it
                              danbig
                              Thanks, TIG. Amazing script.
                              Does this plugin do the flatten to plane, or is that a separate plugin? I can't seem to find the command for flatten to plane. (Silhouette to Plane is working great)
                              • shuraS Offline
                                shura
                                Flatten to Plane:
                                http://forums.sketchucation.com/viewtopic.php?f=323&t=31895
                                • shuraS Offline
                                  shura
                                  Just to point out again what Adam already said, Silhouette to Workplane makes closing difficult outlines sooo easy. Brought back the faith in freehand tool to me.
                                  with freehand tool quickly drawn outlines often do not close. solved with silhouettes to workplane.
                                  Rocky, that is a pretty smart idea. I am having thoughts about this kind of matte painting tricks all the time.
                                  (like here: http://forums.sketchucation.com/viewtopic.php?f=79&t=31069)
                                  thanks again for your generosity TIG!
                                  • JClementsJ Offline
                                    JClements
                                    TIG:
                                    When I click on the script's download button the #SilhoutteTpoPlane.rb downloads. I put the script in the plugins directory of SU8. When I open SU8 I get the following error:
                                    %(#FF0000)[Error Loading File #SilhouetteToPlane.rb
                                    no such file to load -- #WorkPlane.rb
                                    Should #WorkPlane.rb also have been downloaded?
                                    Regards, John
                                    • TIGT Online
                                      @jclements said:
                                      TIG:
                                      Regards, John
                                      John
                                      IF you had read the notes you'd see that you need 'WorkPlane.rb'... because you must first make and then select a 'WorkPlane' with your other parts you want to project - that's how it knows what plane to project its result on to... πŸ˜’
                                      • CAntonisC Offline
                                        CAntonis
                                        Working great as always
                                        Thank U TIG
                                          Bertier
                                          sweet
                                          • H Offline
                                            Heven7_floor
                                            Thanks 😍 , it is great script for mechanic model favour, this plug-in shall mostly advance to project 3d model in STD plan,
                                            but I found some error happen, when I test by simple cylinder ,which was rotated a bit from origin , there are 1 error time of total 4 time
                                            I love this script , and hope it could been tune-up ,but I am begin to learn for SU plugin codding , shame to less helping 😳
                                            rotate cylinder model testing
