    Re: [Plugin] Flatten to Plane v1.2 20101023
    77 Posts 27 Posters 93.0k Views 27 Watching
      Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=281320#p281320
      Nested groups/instances now included.
        jsteacy
        ThomThom's Cleanup script works pretty well to delete all the co-planar lines once the face exist. I tried creating the large circle around the geometry to get the faces but it doesn't always create all the necessary faces, so maybe you could look into just create the faces for the resultant geometry. But that's just a suggestion.
        • G
          gude
          I have no words to thank for your quick response. Your speed to make the solution is amazing.
          I just got the script and was playing with it for a while. I created a work plane i selected my group and run it.
          The result was the model got unfolded on the working plane. Or is it my problem I've attached the model.
          And One more thing, If i have my section plane on, does it flatten only the visible geometry.
          Again thank you so much. πŸ‘
          Project_edges_on_plane.skp
          • P
            Powerwall
            Ok, I must be doing something wrong. I am building a model wind turbine and want to cut out blades for the model. The blades wrap around a frame in a helical design. I want to flatten the helical shape so that I can get the 2d curve that best approximates the shape of the blade. So I download both plugins and select a plane and select my model. I run the flatten plugin and I now have a blue box around my model blade, but it is still in 3 dimensions. Any ideas as to what I am doing incorrectly? This looks like a great plugin and is just what I need to get my new business started if I can make it work! Thanks in advance for your help.
              Gude
              I can see the problem...
              I can't see see what's causing it [yet] πŸ˜’
              I think perhaps you need Jim Foltz's 'unfold.rb'..............
                This tool only 'projects' a form onto a plane [when it's working!] - if you want to 'unfold' a form use Jim Foltz's 'unfold.rb'..........
                There is is also 'flatten.rb' from Smustard ?
                  Here's an alternative 'Silhouette to Plane' Tool http://forums.sketchucation.com/viewtopic.php?p=281445#p281445
                  • P
                    Powerwall
                    Thanks so much for the info on the unfold tool. This is exactly what I need to convert the 3d curve to a 2d shape that I can have manufactured. I have my first customer for my wind turbine design but the blade design has been a hangup as my manufacturer was unable to determine the curves to cut for the blades. Not knowing CAD, I was at a loss. I can't put into words how great it is to have a solution. Thanks a million!
                    Keith Tully
                    Power Wall Systems
                    http://www.powerwallsystems.net
                    • gillesG
                      gilles
                      SU 8 versionHello,
                      first I must thank you for your marvelous plugins.
                      so I try this one and exept for the workplane coplanar to the ground the result is not coplanar with is workplane but seems to be perpendicular.
                      SU 8 on mac 10.6
                      see attatchment.
                      SU 7 version
                        I think the problem lies with the transformations of the WorkPlanes...
                        If you simply move / rotate the WorkPlane group then the tool will use its 'plane' correctly - as the WorkPlane is effectively 2D and its bounds are not orthogonal to the main axes.
                        You seem to have unlocked and edited the internal contents of the WorkPlane group so that they are then angled within the group and therefore whilst the group is 'orthogonal' to the axes the plane's face is not: because the tool takes the WorkPlanes group's transformation to place the 'flattened' version it appears 'orthogonal' matching the WorkPlane group's alignment and not the internal 'face'...
                        I can probably trap for this too... ❓
                          Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=281320#p281320
                          The correct Plane of a 'WorkPlane' is now used even if it has been Transformed inside its own Group.
                            manamana
                            sorry for the stupid question, but I can't test this at the moment.
                            does this script take geometry and lay it flat, or does it create a projection onto the work plane?
                            I'm looking for a script that will take a bunch of randomly oriented faces and lay them out nice and flat on the ground plane. For lasercutting, so I don't want them projected/distorted.
                            Thanks,
                            C
                              I'm looking for a script that will take a bunch of randomly oriented faces and lay them out nice and flat on the ground plane. For laser-cutting, so I don't want them projected/distorted.
                              Thanks,
                              C
                              This tool makes a 'projection' of the vertices in a shape to the nearest points on a plane.
                              Therefore if the object is skewed relative to the plane its projection will be distorted compared to its 'parent'.
                              This tool and its sibling 'SilhouetteToPlane' are very similar - this one projects vertices into new lines and keeps grouping etc whilst the other makes a cardboard-cutout silhouette of the 'profile' and faces it.
                              To lay the faces in objects flat onto the ground I suggest you try Jim Foltz's 'unfold.rb' - it's not 'automatic' but it's easy enough to use...
                              Are your faces individually grouped?
                              If so it might be easy enough to script a tool to transform them all 'flat' [normal=[0,0,1]] and all moved to be on the ground - z=0 - you might need to do some tidying if they overlapped etc... but another algorithm to shift them around once they were 'flat' so their bounds didn't intersect would also be feasible...
                              Adding text-tags to the grouped faces and their 'flattened' counterparts would also be helpful to keep track of them?
                              πŸ€“
                              • W
                                watkins
                                Could someone provide a few worked examples where this tool, and Silouette to plane, prove useful? I am still not clear on function.
                                Bob
                                  • W
                                    watkins
                                    Dear TIG,
                                    Many thanks for the illustration. So, am I right in thinking that this tool could be used to create third angle projects? Presumably, after using the flattening to plane/keep all edges tool, one could then delete unwanted lines and/or change lines to construction lines to show hidden detail?
                                    Kind regards,
                                    Bob
                                      @watkins said:
                                      Dear TIG,
                                      Kind regards,
                                      Bob
                                      That's the idea πŸ˜‰
                                      • gillesG
                                        gilles
                                        works great now.
                                        πŸ‘ πŸ‘
                                        thanks a lot
                                        • G
                                          gude
                                          Dear TIG.
                                          I'm using this script to project elevations from a model. Its working flawless. Now I wanted to project a 2d of the model that is just visible from a plane And this requires me to select faces with visibility criteria from a given view.
                                          I am doing this with a the following method but I hope there will be a better of doing it.
                                          ** Give a colour to my elevations for different views. For example faces that qualify to project on front be coloured red, side views colored yellow etc. then select by similar material and project selection to the working plane.
                                          Faces that are visible on more than one elevation will be given another color and included in selection. **
                                          As faces that are perpendicular to my working plane do not need to project these may be selected and hidden on projection just to refine the criteria.
                                          Is there any criteria that evaluates faces in the model according to their visibility from the working plane?
                                          Assuming that our model is opaque and rays from my working plane get reflected to the projection plane.
                                          I.e for Not projecting rear side view on the front one etc ...
                                          Thanks lot again.
                                          PROJECTION-CRITERIA
                                            It projects all selected faces - so to not include the rear don't select it ?
                                            • 1 / 4
