    Re: [Plugin] Flatten to Plane v1.2 20101023
    77 Posts 27 Posters 87.0k Views 27 Watching
      Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=281320#p281320
      The correct Plane of a 'WorkPlane' is now used even if it has been Transformed inside its own Group.
        manamana
        sorry for the stupid question, but I can't test this at the moment.
        does this script take geometry and lay it flat, or does it create a projection onto the work plane?
        I'm looking for a script that will take a bunch of randomly oriented faces and lay them out nice and flat on the ground plane. For lasercutting, so I don't want them projected/distorted.
        Thanks,
        C
          I'm looking for a script that will take a bunch of randomly oriented faces and lay them out nice and flat on the ground plane. For laser-cutting, so I don't want them projected/distorted.
          Thanks,
          C
          This tool makes a 'projection' of the vertices in a shape to the nearest points on a plane.
          Therefore if the object is skewed relative to the plane its projection will be distorted compared to its 'parent'.
          This tool and its sibling 'SilhouetteToPlane' are very similar - this one projects vertices into new lines and keeps grouping etc whilst the other makes a cardboard-cutout silhouette of the 'profile' and faces it.
          To lay the faces in objects flat onto the ground I suggest you try Jim Foltz's 'unfold.rb' - it's not 'automatic' but it's easy enough to use...
          Are your faces individually grouped?
          If so it might be easy enough to script a tool to transform them all 'flat' [normal=[0,0,1]] and all moved to be on the ground - z=0 - you might need to do some tidying if they overlapped etc... but another algorithm to shift them around once they were 'flat' so their bounds didn't intersect would also be feasible...
          Adding text-tags to the grouped faces and their 'flattened' counterparts would also be helpful to keep track of them?
          • W Offline
            watkins
            Could someone provide a few worked examples where this tool, and Silouette to plane, prove useful? I am still not clear on function.
            Bob
              • W Offline
                watkins
                Dear TIG,
                Many thanks for the illustration. So, am I right in thinking that this tool could be used to create third angle projects? Presumably, after using the flattening to plane/keep all edges tool, one could then delete unwanted lines and/or change lines to construction lines to show hidden detail?
                Kind regards,
                Bob
                  @watkins said:
                  Dear TIG,
                  Kind regards,
                  Bob
                  That's the idea 😉
                  • gillesG Offline
                    gilles
                    works great now.
                    thanks a lot
                      gude
                      Dear TIG.
                      I'm using this script to project elevations from a model. Its working flawless. Now I wanted to project a 2d of the model that is just visible from a plane And this requires me to select faces with visibility criteria from a given view.
                      I am doing this with a the following method but I hope there will be a better of doing it.
                      ** Give a colour to my elevations for different views. For example faces that qualify to project on front be coloured red, side views colored yellow etc. then select by similar material and project selection to the working plane.
                      Faces that are visible on more than one elevation will be given another color and included in selection. **
                      As faces that are perpendicular to my working plane do not need to project these may be selected and hidden on projection just to refine the criteria.
                      Is there any criteria that evaluates faces in the model according to their visibility from the working plane?
                      Assuming that our model is opaque and rays from my working plane get reflected to the projection plane.
                      I.e for Not projecting rear side view on the front one etc ...
                      Thanks lot again.
                      PROJECTION-CRITERIA
                        It projects all selected faces - so to not include the rear don't select it ?
                        • demD Offline
                          dem
                          got some strange trouble 😢
                            Dem
                            What's the problem ?
                            Are you saying that the new 'flat' lines cross each other and they don't 'break' ?
                            If so, then that is how it should be - the 3D edges are projected flat onto the plane.
                            If you want the new lines to intersect, then select all of the geometry inside its group and 'Intersect with Context', so that they all split themselves where they cross... It's a quick fix if you are looking to erase some bits later...
                            • demD Offline
                              dem
                              oh thanks!!! 👍
                              • Bob JamesB Offline
                                Bob James
                                @gude
                                Have you checked out cubicpanout.rb?
                                  Soundtracker
                                  TIG, is there a way to combine this with your Axo + Iso View plugin to export a 2D isometric view?
                                  I thought of Work Plane but I can't seem to get it right 😒
                                    Soundtracker
                                    how stupid...I just need to export a 2d graphic of course 😳
                                    • W Offline
                                      Wildchild
                                      Hi, I was trying to find a good and painless way to export from skp to autocad to add 2D details, maintaining groups/components and layers while exporting and I came across this usefull plugin. The problem is that it works only with edges ignoring the faces and this makes it unusable in the 3D-->2D workflow because it projects even the edges behind faces as shown in the images.
                                      TIG do you think there's any workaround for this? I'd be thankful for the rest of my life 👊
                                      3D model
                                      Eternity is very long, especially towards the end. Woody Allen
                                        It's function is to project edges...
                                        Find my CADup script beta, that makes projections with hidden lines etc... it's a w.i.p...
                                        • W Offline
                                          Wildchild
                                          Alright, thanks TIG I'll try it out! By the way in the meantime I came up with, I believe, the perfect way to export 3D into 2D CAD drawings maintaining geometry separated into layers without flattening or anything (that's why I was trying to use this plug before) just by using colors. In case someone is interested I can make a tutorial off of it.
                                            dbalex
                                            @Wildchild: I'm really interested in your technique as I'm always going from sketchup to 2d cad and it's a real pain.. It would be great if you could make a very short tuto on that as I don't really understand what you mean by colors? Thanks!
                                            http://www.bocostudio.com
                                            • 2 / 4
