    [Plugin] Group PushPull 2DFaces (v0.4) Oct 20, 2010
    22 Posts 9 Posters 34.9k Views 9 Watching
    • EarthMoverE Offline
      EarthMover
      Making them into components instead of groups would be a better option. This would allow you to run ThomThom's "Replace Similar" script and have them replaced where applicable.
      Content Creator at Skapeup
        +1 on that.
          Where is this plug? 😳
            kyyu
            I don't normally use components, so don't even know how to code for it. If anyone wants to, feel free to modify this plugin for components. And I will post it above, as an alternative.
            This was just a quick writeup, that I never intended to improve on. But what I plan to do is incorporate this plugin into my PushPull & Group Plugin, which already has most of the features requested by DIEGO-RODRIGUEZ. I did try my PushPull & Group Plugin, originally, but it could not handle faces that touched (adjacent). You guys can check out this video, of the current incarnation of the PushPull & Group Plugin: http://www.youtube.com/watch?v=lQgeMuFdpKU
            -Kwok
              0.2.0 supports groups.
                Does it leave them as groups, though?
                  At the moment, yes ... I think. But Selection Toys can convert them into components.
                    razer
                    This is good for old game engines due to the fact they only work with groups and basic solids, That way I can create my walls with doors and windows in a flash πŸ˜„!
                      kyyu
                      Updated to v0.2. Input box added.
                        kyyu
                        Updated to v0.3. You now have the option to make components.
                          DIEGO-RODRIGUEZ
                          thank you very much
                            kyyu
                            Your welcome, DIEGO-RODRIGUEZ.
                            Everyone, I found a bug and have released a quick update. (from v0.3 to v0.3b ) Please, get the new version. The bug I fixed only has effect, if you chose the option not to use the input box.
                            -Kwok
                              DIEGO-RODRIGUEZ
                              thanks.
                              you can add the option to remember the last setting used?
                                kyyu
                                @diego-rodriguez said:
                                thanks.
                                Done, new version 0.4 posted. πŸ˜„
                                  DIEGO-RODRIGUEZ
                                  thank you very much
                                  • 3 Offline
                                    3dsketchupper
                                    Nice addition,Thanks for sharing. it will be good as mention to
                                    have component option.
                                      razer
                                      Hello I was wondering how could I put this in my right click menu? that way its easier to get to Thanks! I was also wondering if you could add more saved options that way I can have 2 measurements instead of going back and forth having to change it all the time
                                        kyyu
                                        Not too hard to learn a few thing, so you can customize plugins for your own needs. I just posted a few links for another beginner starting out: http://forums.sketchucation.com/viewtopic.php?f=323&t=28086&p=332294#p332294
                                        There is a link there to a pdf book, Automatic Sketchup, specifically Chapter "10.2 Menus", page 220. It's only a few pages, which will answer your 1st question about context menus. If it's still confusing, just look at another plugin that uses a context menu. It's generally the very last lines.
                                        -Kwok
                                        • W Offline
                                          wjoey
                                          It's save a lots of time. Thank you so much.
