    [Plugin] Group PushPull 2DFaces (v0.4) Oct 20, 2010
    22 Posts 9 Posters 35.2k Views 9 Watching
    • K
      kyyu
      Updated to v0.2. Input box added.
      • K
        kyyu
        Updated to v0.3. You now have the option to make components.
          DIEGO-RODRIGUEZ
          thank you very much
          • K
            kyyu
            Your welcome, DIEGO-RODRIGUEZ.
            Everyone, I found a bug and have released a quick update. (from v0.3 to v0.3b ) Please, get the new version. The bug I fixed only has effect, if you chose the option not to use the input box.
            -Kwok
              DIEGO-RODRIGUEZ
              thanks.
              you can add the option to remember the last setting used?
              • K
                kyyu
                @diego-rodriguez said:
                thanks.
                Done, new version 0.4 posted. πŸ˜„
                  DIEGO-RODRIGUEZ
                  thank you very much
                    3dsketchupper
                    Nice addition,Thanks for sharing. it will be good as mention to
                    have component option.
                      razer
                      Hello I was wondering how could I put this in my right click menu? that way its easier to get to Thanks! I was also wondering if you could add more saved options that way I can have 2 measurements instead of going back and forth having to change it all the time
                      • K
                        kyyu
                        Not too hard to learn a few thing, so you can customize plugins for your own needs. I just posted a few links for another beginner starting out: http://forums.sketchucation.com/viewtopic.php?f=323&t=28086&p=332294#p332294
                        There is a link there to a pdf book, Automatic Sketchup, specifically Chapter "10.2 Menus", page 220. It's only a few pages, which will answer your 1st question about context menus. If it's still confusing, just look at another plugin that uses a context menu. It's generally the very last lines.
                        -Kwok
                        • W
                          wjoey
                          It's save a lots of time. Thank you so much.
                          • 2 / 2
