    Windows 7 Issues
    21 Posts 5 Posters 2.1k Views 5 Watching
    • honoluludesktopH
      honoluludesktop
      I too have both 7 and 8 installed on my system, and which ever SU v? was opened last, will run when clicking on a skp. To change the preference, start the SU v? from its icon.
      • boofredlayB
        boofredlay
        No Icon View with a 64 Bit Install !!!??? Ludicrous.
        Thanks for the link Thomas. I just might get that one. Does it thumbnail HDRI's as well? I did not see it listed but they said "... and many other formats..."
        Box and honoluludesktop, I attempted to do this last night but it only gives me one option; "SketchUp Application". I even navigated to the .exe file under the SU8 folder but it still opens with SU7. Meh...
        @honoluludesktop said:
        ...which ever SU v? was opened last, will run when clicking on a skp.
        ...even if I open SU8 and save a file then close. If I double click that model it tries to open with SU7.
          I requested it a few weeks ago. Not sure if it's out yet, but it was apparently "on the list".
          It already do .exr
          • K
            Khai
            1. I have SU7 and SU8 installed and when I double click on a .skp file it always wants to open with SU7, even if I open SU8 and save a file then close. If I double click that model it tries to open with SU7.
            Start
            in the search box type "Set Associations"
            select "Make a file type always open in a specific program"
            you can then set which Sketchup has priority over Skp files.
            you can also Right Click a Skp and select "Open With" and set a Default Program there, and have a list of programs that can open said file.
            • boofredlayB
              boofredlay
              Start
              Thanks, I will try that when I get home.
              As I said before, when I do that I only get one option, "SketchUp Application". No choice between 7 or 8.
              Cheers.
              • K
                Khai
                Cheers.
                strange.. when I do it, I have "Choose Default Program" at the bottom of whatever list I get...
                • boofredlayB
                  boofredlay
                  No luck for either option
                  http://www.msnhiddenemoticons.com/Library/extra_large/worms/default/frown.png
                  I think I am just going to uninstall SU7 altogether as the only reason I needed it was for a plugin that does not work in SU8 and come to find out last night won't work on Window's 7 either. I am starting to dislike Win7 for the folder permission issues.
                  http://www.msnhiddenemoticons.com/Library/extra_large/hawki/default/angry.gif
                  • K
                    Khai
                    hold on
                    you are changing the option and not just looking at it and seeing it says Sketchup?
                    you can change the location it's looking at and therefore which Sketchup EXE....
                    if you choose "Browse" in the 2nd pic you can change which Sketchup you want it to use....
                    to clarify
                    hit browse to get to the folders.
                    you'll find Su 7 for example in \Google\Sketchup 7 - you'd select the EXE there for 7.
                    for 8, you'd find it in \Google\Sketchup 8 - you select the EXE there for 8.
                    both report as you've seen as "Sketchup Application"
                    • boofredlayB
                      boofredlay
                      I did that about 5 times last night and a couple more times this afternoon. No go.
                      • K
                        Khai
                        then I'm not sure what's wrong with your setup. you are logged in as Admin or have Admin Rights? you could try shutting UAC off or installing Sketchup outside of Program Files (Program Files is protected by UAC and since UAC is designed to stop on the fly writing to files/folders .....)
                        • boofredlayB
                          boofredlay
                          Well that is what I am trying to find out, what is wrong with the setup. Granted I just received this computer about 2 weeks ago and plugged it in this past weekend. I am logged in as Administrator. Our home is not yet networked (which I fear will screw things up worse).
                          • K
                            Khai
                            User Account Control
                            it's designed to restrict access to important files to cut down on possible system damage.
                            the flip side is, the permissions can get very very annoying. personally I don't install anything to program files I know I'll be tinkering with a lot - poser, modeling apps like Sketchup, etc.
                            I'm thinking that could be your issue here.
                            • boofredlayB
                              boofredlay
                              Shutting off UAC (setting to Never Notify) did not work either.
                              • boofredlayB
                                boofredlay
                                Sounds like it.
                                What happens to any other linked folders etc. to SketchUp if I install outside Program Files? I really suck at this 😳 πŸ˜†
                                • K
                                  Khai
                                  I had no problems here... I just told 'em where everything was again...
                                  • boofredlayB
                                    boofredlay
                                    Thanks. I will try that soon.
                                    I appreciate the help.
                                    http://www.msnhiddenemoticons.com/Library/extra_large/blacky/default/victory.png
                                    • boofredlayB
                                      boofredlay
                                      Again thanks.
                                      Installing SU7 outside the Program files allowed me to set SU8 as the program to double click open. πŸ‘
                                      • K
                                        Khai
                                        no problems, glad to help πŸ’š
