    Windows 7 Issues
    21 Posts 5 Posters 1.3k Views 5 Watching
      Khai
      1. I have SU7 and SU8 installed and when I double click on a .skp file it always wants to open with SU7, even if I open SU8 and save a file then close. If I double click that model it tries to open with SU7.
      Start
      in the search box type "Set Associations"
      select "Make a file type always open in a specific program"
      you can then set which Sketchup has priority over Skp files.
      you can also Right Click a Skp and select "Open With" and set a Default Program there, and have a list of programs that can open said file.
      • boofredlayB Offline
        boofredlay
        Start
        Thanks, I will try that when I get home.
        As I said before, when I do that I only get one option, "SketchUp Application". No choice between 7 or 8.
        Cheers.
          Khai
          Cheers.
          strange.. when I do it, I have "Choose Default Program" at the bottom of whatever list I get...
            boofredlay
            No luck for either option
            http://www.msnhiddenemoticons.com/Library/extra_large/worms/default/frown.png
            I think I am just going to uninstall SU7 altogether as the only reason I needed it was for a plugin that does not work in SU8 and come to find out last night won't work on Window's 7 either. I am starting to dislike Win7 for the folder permission issues.
            http://www.msnhiddenemoticons.com/Library/extra_large/hawki/default/angry.gif
              Khai
              hold on
              you are changing the option and not just looking at it and seeing it says Sketchup?
              you can change the location it's looking at and therefore which Sketchup EXE....
              if you choose "Browse" in the 2nd pic you can change which Sketchup you want it to use....
              to clarify
              hit browse to get to the folders.
              you'll find Su 7 for example in \Google\Sketchup 7 - you'd select the EXE there for 7.
              for 8, you'd find it in \Google\Sketchup 8 - you select the EXE there for 8.
              both report as you've seen as "Sketchup Application"
                boofredlay
                I did that about 5 times last night and a couple more times this afternoon. No go.
                  Khai
                  then I'm not sure what's wrong with your setup. you are logged in as Admin or have Admin Rights? you could try shutting UAC off or installing Sketchup outside of Program Files (Program Files is protected by UAC and since UAC is designed to stop on the fly writing to files/folders .....)
                    boofredlay
                    Well that is what I am trying to find out, what is wrong with the setup. Granted I just received this computer about 2 weeks ago and plugged it in this past weekend. I am logged in as Administrator. Our home is not yet networked (which I fear will screw things up worse).
                      Khai
                      User Account Control
                      it's designed to restrict access to important files to cut down on possible system damage.
                      the flip side is, the permissions can get very very annoying. personally I don't install anything to program files I know I'll be tinkering with a lot - poser, modeling apps like Sketchup, etc.
                      I'm thinking that could be your issue here.
                        boofredlay
                        Shutting off UAC (setting to Never Notify) did not work either.
                          boofredlay
                          Sounds like it.
                          What happens to any other linked folders etc. to SketchUp if I install outside Program Files? I really suck at this 😳 πŸ˜†
                            Khai
                            I had no problems here... I just told 'em where everything was again...
                              boofredlay
                              Thanks. I will try that soon.
                              I appreciate the help.
                              http://www.msnhiddenemoticons.com/Library/extra_large/blacky/default/victory.png
                                boofredlay
                                Again thanks.
                                Installing SU7 outside the Program files allowed me to set SU8 as the program to double click open. πŸ‘
                                  Khai
                                  no problems, glad to help πŸ’š
