    [Plugin] C of G Reporter 1.3
    41 Posts 8 Posters 86.8k Views 8 Watching
      So speedy as usual 😎
      http://www.podisticasolidarieta.it/podistica/home.nsf/EBAB48606D097712C125768700589224/$FILE/bipbip.jpg
        @Tig : Can you write result with a little Offset?
        Result are always in front of something even we rotate or scale the object 😄
          You need to use another tool 'Center of Gravity' to make the CofG tags first.
          It's here http://forums.sketchucation.com/viewtopic.php?p=229401#p229401
          I wrote this 'Reporter' for Bertier who wants to be able to report weights of objects etc after tagging them with CofG data...
            Use Xray mode...
            The tool is a utility not a presentation aid.
            You can always move the text-tag by editing the CofG group...
              • W
                watkins
                Dear TIG,
                Thanks for the explanation.
                Regards,
                Bob
                  Thanks, Pilou
                  ...Comme toujours, je peut te faire confiance...
                  Aucun problème !
                  • KrisidiousK
                    Krisidious
                    does this do Imperial Weights too?
                    By: Kristoff Rand
                      @Tig 😄
                      Je peut no, Je peux yes
                      a very useful thing for French verbs and conjugation ☀
                      (on left top page: enter the verb, press ok ..and scroll )
                        If you use the 'imperial' measurements for the CogG volumes and density...
                        Possible units are "kg/m3", "tonnes/m3", "g/cm3", "tons/yd3", "lbs/ft3"
                        If others were preferred they could be added...
                          @Tig 😄
                          Pilou 😞
                          I know!
                          I can..., thou canst..., he/she/it can..., we can..., you can... they can...? [can!]
                          My French is rubbish [but, so is your English! 😉 ]
                          Je le sais!
                          Je peux..., tu peux...,il/elle peut..., nous pouvons..., vous pouvez... ils/elles peuvent? [pu!]
                          Mon Français est des déchets [mais c'est que t'anglais! 😉 ]
                          In good humour...
                          Dans la bonne humeur ...
                          l'eau is water
                          la peau is skin
                          Both of these nouns are considered male, there is no reason behind this it is just the way the language works!
                          Similarly there are rules for female nouns such as:
                          un périphérique is a peripheral
                          un graphique is a graph........................ 😕
                          • KrisidiousK
                            Krisidious
                            excellente' sorry wrong language...
                            now another question... I know this is kinda off subject. what is the implication of this plugin, does this allude to a future where these weights could be transfered through shear force or straight line force?
                            the reason I ask is that I look forward to a time when I can build roofs, beams or arches and have their loads followed and measured.
                            SketchyPhysics got me excited about the possibility... that a model could have gravity and therefore transfer weight and force towards a central point.
                            thanks for another great plugin...
                            By: Kristoff Rand
                              Kristoff
                              No reason why not... BUT we just haven't written it yet... 🤓
                                @ Tig
                                The big mystery is why so much languages? 😉
                                • B
                                  Bertier
                                  MERCI / THANK YOU / Danke !
                                  that is awsome !
                                  • B
                                    Bertier
                                    Hello TIG
                                    tryed it, got this :
                                    cofgreporter
                                    Error: #<TypeError: C:/Program Files/Google/Google SketchUp 8/Plugins/cofgreporter.rb:81:in +': can't convert nil into String> C:/Program Files/Google/Google SketchUp 8/Plugins/cofgreporter.rb:81 C:/Program Files/Google/Google SketchUp 8/Plugins/cofgreporter.rb:81:in cofgreporter'
                                    (eval):0
                                      Bertier
                                      Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=278046#p278046
                                      The error in the error message is fixed!
                                      Please retry...
                                      To be on the safe site please ensure your file_path/skp_name contains no accented characters - SUp's Ruby is not happy with unicoded characters 😞
                                      • B
                                        Bertier
                                        will do now;
                                        thank you
                                        • B
                                          Bertier
                                          new error message :
                                          cofreporter
                                          Error: #<NameError: undefined local variable or method `cofreporter' for main:Object>
                                          (eval)
                                            @bertier said:
                                            new error message :
                                            cofreporter
                                            (eval)
                                            It's cof****g****reporter - you mistyped! 😒
                                            • 1 / 3
