๐Ÿ”Œ Quick Selection | Try Didier Bur's reworked classic extension that supercharges selections in SketchUp Download
[Plugin] C of G Reporter 1.3
41 Posts 8 Posters 82.0k Views 8 Watching
    (c) TIG 2010
    Permission to use, copy, modify, and distribute this software for
    any purpose and without fee is hereby granted, provided that the above
    copyright notice appear in all copies.
    THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
    IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
    WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
    cofgreporter.rb >>> ../Plugins/ folder
    Usage:
    Use this after adding some CofG's [i.e. 'Center of Gravity' tags]
    Type 'cofgreporter' in the Ruby Console.
    If the Model SKP is new and has not yet been saved you will get an error.
    If there are no CofG's to Report you will get an error.
    If the destination CofG Report cannot be written -
    e.g. it's already open in Excel - you will get an error.
    Otherwise a CofG Report is written into the Model's folder.
    It is named to match the Model -
    e.g. 'MyModel.skp' and 'MyModel_CofG_Report.csv'
    A '.csv' file can be opened in Excel etc.
    Link the .csv into a pre-formated .xls file with additional 'sums' etc, so
    that it auto-updates.
    It is sorted alphanumerically and reports
    'ID' 'Weight' 'Volume' - the final two are in the units used in the CofG's.
    The 'ID' is the CofG name-tag based on the original Instance's name, but
    remember that you might have adjusted this in the dialogs during the making
    of the CofG's - i.e. it is as displayed in the CofG's text-tag, not
    necessarily the Instance's name.
    Donations:
    by PayPal to info @ revitrev.org PayPalButton___________________________________________________________________________
    Version:
    1.0 20101009 First release.
    1.1 20101010 csv defined outside of begin/rescue.
    1.2 20101010 Extra rescue error messages added.
    1.3 20101010 Glitch with some users' "group.definition" fixed.
    cofgreporter.rb
    • W Offline
      watkins
      Dear TIG,
      Sorry for being dense, but does this plugin calculate the C_of_G of a shape? I do not understand the reference to adding CofGs.
      Kind regards,
      Bob
        So speedy as usual ๐Ÿ˜Ž
        http://www.podisticasolidarieta.it/podistica/home.nsf/EBAB48606D097712C125768700589224/$FILE/bipbip.jpg
          @Tig : Can you write result with a little Offset?
          Result are always in front of something even we rotate or scale the object ๐Ÿ˜„
            You need to use another tool 'Center of Gravity' to make the CofG tags first.
            It's here http://forums.sketchucation.com/viewtopic.php?p=229401#p229401
            I wrote this 'Reporter' for Bertier who wants to be able to report weights of objects etc after tagging them with CofG data...
              Use Xray mode...
              The tool is a utility not a presentation aid.
              You can always move the text-tag by editing the CofG group...
              ๐Ÿ˜•
                ๐Ÿ’ญ ๐Ÿ‘ ๐Ÿ˜ณ
                • W Offline
                  watkins
                  Dear TIG,
                  Thanks for the explanation.
                  Regards,
                  Bob
                    Thanks, Pilou
                    ...Comme toujours, je peut te faire confiance...
                    Aucun problรจme !
                    ๐Ÿ˜‰
                      Krisidious
                      does this do Imperial Weights too?
                      By: Kristoff Rand
                        @Tig ๐Ÿ˜„
                        Je peut no, Je peux yes
                        a very useful thing for French verbs and conjugation โ˜€
                        (on left top page: enter the verb, press ok ..and scroll )
                          If you use the 'imperial' measurements for the CogG volumes and density...
                          Possible units are "kg/m3", "tonnes/m3", "g/cm3", "tons/yd3", "lbs/ft3"
                          If others were preferred they could be added...
                            @Tig ๐Ÿ˜„
                            Pilou ๐Ÿ˜ž
                            I know!
                            I can..., thou canst..., he/she/it can..., we can..., you can... they can...? [can!]
                            My French is rubbish [but, so is your English! ๐Ÿ˜‰ ]
                            Je le sais!
                            Je peux..., tu peux...,il/elle peut..., nous pouvons..., vous pouvez... ils/elles peuvent? [pu!]
                            Mon Franรงais est des dรฉchets [mais c'est que t'anglais! ๐Ÿ˜‰ ]
                            In good humour...
                            Dans la bonne humeur ...
                            ๐Ÿ˜„
                            l'eau is water
                            la peau is skin
                            Both of these nouns are considered male, there is no reason behind this it is just the way the language works!
                            Similarly there are rules for female nouns such as:
                            un pรฉriphรฉrique is a peripheral
                            un graphique is a graph........................ ๐Ÿ˜•
                              Krisidious
                              excellente' sorry wrong language...
                              now another question... I know this is kinda off subject. what is the implication of this plugin, does this allude to a future where these weights could be transfered through shear force or straight line force?
                              the reason I ask is that I look forward to a time when I can build roofs, beams or arches and have their loads followed and measured.
                              SketchyPhysics got me excited about the possibility... that a model could have gravity and therefore transfer weight and force towards a central point.
                              thanks for another great plugin...
                              By: Kristoff Rand
                                Kristoff
                                No reason why not... BUT we just haven't written it yet... ๐Ÿค“
                                  @ Tig
                                  The big mystery is why so much languages? ๐Ÿ˜‰
                                    Bertier
                                    MERCI / THANK YOU / Danke !
                                    that is awsome !
                                      Bertier
                                      Hello TIG
                                      tryed it, got this :
                                      cofgreporter
                                      Error: #<TypeError: C:/Program Files/Google/Google SketchUp 8/Plugins/cofgreporter.rb:81:in +': can't convert nil into String> C:/Program Files/Google/Google SketchUp 8/Plugins/cofgreporter.rb:81 C:/Program Files/Google/Google SketchUp 8/Plugins/cofgreporter.rb:81:in cofgreporter'
                                      (eval):0
                                        Bertier
                                        Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=278046#p278046
                                        The error in the error message is fixed!
                                        Please retry...
                                        To be on the safe site please ensure your file_path/skp_name contains no accented characters - SUp's Ruby is not happy with unicoded characters ๐Ÿ˜ž
                                          Bertier
                                          will do now;
                                          thank you
                                          • 1 / 3
                                          1 / 3
