    [Plugin] Contour Maker v1.6
    64 Posts 24 Posters 72.6k Views 24 Watching
      Here's Contour Maker updated.
      After ~5 years someone pointed out that it doesn't make contours <z=0...
      It now does... AND it's had a general tidy up - it was 5yrs old!
      [flash=600,338:vctzpnpv]http://www.youtube.com/v/I1VOMjDNeZs[/flash:vctzpnpv]
      **Usage:
      First select a Group or Component Instance that has faces that could have
      Contours added, then use the Plugins Menu Item 'Contours'.
      A dialog asks for the vertical spacing (Z-blue) in current units.
      The Contours always start their vertical spacing from Z=0 UP & DOWN.
      It then makes a new layer for the contour-group. The layer is
      named CONT-nnnnnnnn (where nnnnnnnn is based on the date/time).
      It then calculates a series of horizontal slices through the
      selection's faces to make the Contours as specified.**PayPalButton
      Get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=ContourMaker
      • mitcorbM Offline
        mitcorb
        TIG:
        Where do we find the original instructions for use, if any?
          @mitcorb said:
          TIG:
          Added them to the first post 😒
          • mitcorbM Offline
            mitcorb
            Thanks, TIG:
            Watch out, someday they will have you bronzed. 💚
            • KrisidiousK Offline
              Krisidious
              thanks Tig...
              By: Kristoff Rand
                Susy
                Add Contour Maker on Axis (x) and (y)...
                Already in the race the mouse... (Local Expression)
                • massimoM Offline
                  massimo Moderator
                  Thanks TIG, seems to work fine. 😄
                  It's possible to get rid of that mesh grid on the Z=0 level? Perhaps an option?
                    I see the problem.
                    Can you post the example SKP before Contouring...
                    So I can play with it...
                    I suspect some sort of 'Erase Coplanar Edges' is needed within the tool - but it will occur at any z-level if you have a mesh that you haven't used 'Erase Coplanar Edges' on and there are multiple faces - It simply uses what it's given... 😉
                    For now use an 'Erase Coplanar Edges' tool [there are several available] [i]before you make the Contours and the problem will vanish with the coplanar edges...[/i]
                    • massimoM Offline
                      massimo Moderator
                      It was only a quick test and i don't have the file anymore. Anyway you can replicate that easily. It was a terrain mesh generated with the sandbox tools: from scratch+smoove and then smoothened.
                      For now use an 'Erase Coplanar Edges' tool [there are several available] before you make the Contours and the problem will vanish with the coplanar edges...
                      Sure. Thanks 😄
                        ThomThom's CleanUp plugin will get rid of those edges, too (and many more...)
                        • massimoM Offline
                          massimo Moderator
                          Already used that. 😉 Thanks Gaieus.
                          • simon le bonS Offline
                            simon le bon
                            I see the problem.
                            For now use an 'Erase Coplanar Edges' tool [there are several available] before you make the Contours and the problem will vanish with the coplanar edges...[/i]
                            Hi Tig and Massimo and Gaieus 😄 ,
                            Here are 'Erase Coplanar Edges' tools:
                            thomthom_[Plugin] Cleanup (2.0.0)
                            For SU7.1 Doesn't work on my SU6 free.
                            a4chitect_ cleanup.rb
                            J.H. Aughey_CleanUP Model
                            Well! I have tried Tig's solution:
                            For now use an 'Erase Coplanar Edges' tool before you make the Contours and the problem will vanish with the coplanar edges...
                            but that doesn't work very well.
                            The simple working solution I have found is to avoid z=0. Moving the group up (or down), activate Contour Maker, Move the group back to the initial position.
                            Cheers, simon.
                            • MALAISEM Offline
                              MALAISE
                              Very useful for geological drawings
                              Thanks TIG 👍 👍
                                Simon...
                                When you use the erase coplanar edges tool do you have hidden-geometry 'on'.
                                Then when you have the simplest mesh possible make the contours... ❓
                                  simon le bon
                                  Hi Tig, 😉
                                  I had tried only with all edges unsmoothed.
                                  So I just have tried with hidden geometry "on" as you say. The result is not bad but seems not the best.
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thContourMaker001.jpg
                                  ++simon
                                    It does exactly what you tell it to do...
                                    If you move the mesh up in the Z by 1mm the result will change... 😒
                                    The contours are 'true' - the mesh might not be exactly as you hope BUT the 'contours' represent what is there...
                                      simon le bon
                                      Ah OK!
                                      I think I began to understand how Contour maker works.
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thContourMaker002.jpg
                                      😕 simon
                                        Here's v1.6 - http://forums.sketchucation.com/viewtopic.php?p=273795#p273795
                                        Minor corrections to syntax [arguments all inside () ] that has no affect on results but covers possible future deprecation...
                                        • mitcorbM Offline
                                          mitcorb
                                          Hi,TIG:
                                          Could you explain what you mean by possible future deprecation?
                                          It suggests to me that other tools may not tolerate the use of this one?
                                            A method's 'deprecation' is when a method or a part of a method is no longer 'used' or 'works'.
                                            For example in many API examples in the guides it will say for things like:
                                            entities.add_cline point1, point2
                                            this works fine in past and current versions...
                                            BUT the 'standard' way recommended in Ruby and guaranteed to stop faults is to use 'parenthesizes' to enclose all arguments, like this
                                            entities.add_cline(point1, point2)
                                            [Note NO space between the method and opening ( and the arguments are separated by ',']
                                            This also gets over the occasional glitch that occurred in existing code with the new PC version of Ruby shipped with v8, for example in v7 this [probably] worked
                                            my_command (x+y/2), z
                                            in v8 it will fail because the first set of stuff inside the '()' is taken as all the arguments there are and the following ', z' throws an error, but changed to
                                            my_command((x+y/2), z)
                                            it then works for both versions and is also 'future-proof' as all of the arguments are now encapsulated inside the ()...
                                            • 1 / 4
