    Interface for plugins.
    38 Posts 8 Posters 4.8k Views 8 Watching
    • JD HillJ
      JD Hill
      Ah, I really should have inferred that. It's basically just a runtime for running Flash out-of-browser, isn't it?
      Developer - Bella Render
        I've not used it - but I was under the impression it also had a framework with pre-made UI widgets... ?
        • JD HillJ
          JD Hill
          Just a guess, as I'm in no way a Flash guy, but I think you may be thinking of Flex, rather than AIR.
            Quite possibly I've gotten them two mixed up. 😳 I'm not a Flash guy myself.
              JD - your Silverlight UI - do you use a ready made framework? Skinned? Or did you build one yourself?
              • AdamBA
                AdamB
                Looks cool but you've stopped any possibility of doing this on non-Windows platforms.
                No?
                • JD HillJ
                  JD Hill
                  I did write this myself.
                  No?
                  No, Silverlight runs fine run on Windows or OSX. There is spotty support for it in linux, but it lags the official SL version by a point or two. But linux was not an issue here anyway.
                    Microsoft made something OSX compatible...? 😲
                    • JD HillJ
                      JD Hill
                      The official SL support list is, I believe: IE 6/7/8, FF 2/3, Safari 3/4, and Chrome. Maybe Opera now too, or in the near future.
                        What I'd like to experiment with now - that IE9b is out - is using SVG and canvas for the UI. Make a big fat canvas in the HTML page where I draw everything - attaching CSS and JS.
                          DIEGO-RODRIGUEZ
                          other questions
                          it posibility add toolbars to the ownership of floating windows "Auto-couple" , similar to (components, layer, material etc)?
                          http://img835.imageshack.us/img835/1812/windowsi.jpg
                            Not via Ruby API.
                              DIEGO-RODRIGUEZ
                              mm. a shame. 😞
                              would be good to ask the google team to enable this option. no?
                              thanks for replying
                              • JD HillJ
                                JD Hill
                                Better than that would be if both those and WebDialogs were able to be docked into the SketchUp window frame. This is the part of SketchUp that makes me feel like I'm using Win95.
                                  Someone was here - posted examples of how he'd managed to embedd SU toolwindows into the SU window frame - by using the Win32API. But unfortunately it was his first and last post.. 😞
                                  • JD HillJ
                                    JD Hill
                                    I don't know if it's really too unfortunate -- even if you could manage to do that, it's way too much of a hack to consider for any production plugin. And even then, it would be Win32-only.
                                      DIEGO-RODRIGUEZ
                                      I meant it.
                                      attach a new window or html window. would be very good
                                      out of curiosity. user who was achieving this. Thom?
                                        Yea - but it was an interesting project he had going. Shortlived as it was.
                                        Don't remember - I lost the link to the thread. 😞
                                          mac1
                                          ref ????? http://www.alexschreyer.net/projects/plugin-loader-for-sketchup/
                                          • T
                                            tomasz
                                            I have done it with Flex.
                                            Flex inside WD
                                            It does work very well under Windows. New versions of Action Script have security problem on Mac. Simply there was no communication between AS and JS inside WebDialog under OSX. I have reported it to Google, they taken this onboard.
                                            It was taking too long to wait for them so I have abandoned this road and have done HTML+JS+CSS+DBS+FTE+HTE+KLM πŸ˜‰
                                            The Flex solution was very nice and I regret that Google didn't help. The Flex has some nice build-in widgets, produces a single SWF file that contains whole GUI and controlling scripts. It also gives guarantee that it will look exactly same on both platforms. So many benefits.. almost everyone has Flash player installed nowadays.
                                            • 2 / 2
