    Interface for plugins.
    38 Posts 8 Posters 4.8k Views 8 Watching
      DIEGO-RODRIGUEZ
      if it works well. but for me.
      one good thing about sketchup is its graphical interface.
      if plugin interfaces are similar, "believe" would be better.
      nice and better integrated.
      • JD HillJ
        JD Hill
        @thomthom said:
        Ok - modifying the image is something one can not do in pure HTML+JS+CSS...
        While it's nice to be able to use HLSL to manipulate images in the browser, there are other reasons as well.
        The UI part of the project is about 70K lines at the moment, supports undo/redo for absolutely all actions, and operates in a fully modeless fashion within SketchUp. Imho, it would be much more difficult and error-prone to try to do this in JS than in C#. Also, the UI works exactly the same on SU6/7/8/Win/OSX.
        For projects smaller than this, of course I agree that HTML/CSS/JS would often make much more sense.
        Developer - Bella Render
        • tbdT
          tbd
          JD: so the user needs the Silverlight installed on the machine ?
          http://plugins.ro
          • JD HillJ
            JD Hill
            Yes, they do.
              Anyone tried the Flash FIR framework?
              • JD HillJ
                JD Hill
                I'm not familiar with that, do you have any links?
                  Sorry, my bad - typo - AIR.
                  http://www.adobe.com/products/air/
                  • JD HillJ
                    JD Hill
                    Ah, I really should have inferred that. It's basically just a runtime for running Flash out-of-browser, isn't it?
                      I've not used it - but I was under the impression it also had a framework with pre-made UI widgets... ?
                      • JD HillJ
                        JD Hill
                        Just a guess, as I'm in no way a Flash guy, but I think you may be thinking of Flex, rather than AIR.
                          Quite possibly I've gotten them two mixed up. 😳 I'm not a Flash guy myself.
                            JD - your Silverlight UI - do you use a ready made framework? Skinned? Or did you build one yourself?
                            • AdamBA
                              AdamB
                              Looks cool but you've stopped any possibility of doing this on non-Windows platforms.
                              No?
                              • JD HillJ
                                JD Hill
                                I did write this myself.
                                No?
                                No, Silverlight runs fine run on Windows or OSX. There is spotty support for it in linux, but it lags the official SL version by a point or two. But linux was not an issue here anyway.
                                  Microsoft made something OSX compatible...? 😲
                                  • JD HillJ
                                    JD Hill
                                    The official SL support list is, I believe: IE 6/7/8, FF 2/3, Safari 3/4, and Chrome. Maybe Opera now too, or in the near future.
                                      What I'd like to experiment with now - that IE9b is out - is using SVG and canvas for the UI. Make a big fat canvas in the HTML page where I draw everything - attaching CSS and JS.
                                        DIEGO-RODRIGUEZ
                                        other questions
                                        it posibility add toolbars to the ownership of floating windows "Auto-couple" , similar to (components, layer, material etc)?
                                        http://img835.imageshack.us/img835/1812/windowsi.jpg
                                          Not via Ruby API.
                                            DIEGO-RODRIGUEZ
                                            mm. a shame. 😞
                                            would be good to ask the google team to enable this option. no?
                                            thanks for replying
