    [Plugin] Selection Toys
    594 Posts 121 Posters 381.2k Views 121 Watching
      Khai
      thank you that really helps πŸ˜„
      tho somethings not working right - selecting N-gons does not work at all... and I know there is some.. I can see them...!
        What function are you trying to use?
          Khai
          Select Ngon
            Select Only -> Polygons ?
            Note that Select Only and Deselect modifies your current selection - doesn't add to it.
              Khai
              that's exactly what I'm doing.
              select the model, then Select Only -> N-Gons and nothing is selected, even tho I can see Ngon's.
              to clarify :Stoys.jpg
                Better if you post your SKP file πŸ˜‰
                  Khai
                  sorry cannot do that, it's copyrighted work that will be for sale, and it's not just the mesh in the image above.
                    Polygon and N-Gon refer to entities where the Entity Info display Polygon.
                      Khai
                      erm... pardon?
                      ok I must be being dense... that made no sense at all?
                        In fact i believe this N Gon function shown only figures who are made with the tool "Polygon" πŸ˜‰
                        And not geometric figures that you can see as Ngons πŸ˜‰
                          Exactly - the selection tool doesn't look at the shape of the geometry, but filters the selection based on the types of entities SketchUp reports.
                          When you select something in SU, the Entity Info window will say what type it is - all the filtering is based on these types.
                            Khai
                            ah. thanks for your help then.. this explains all my problems with this Ruby. we're not compatible.. but thats ok.
                            • N3TON Offline
                              N3TO
                              @thomthom said:
                              I can make so sense why you would not have a Selection Toys menu item under tools and various Context Menu entries (which depend on what you right-click)
                              I was about to ask if you'd checked the Preferences for Selection Toys, but if you have not menu... I'm really stomped.
                              Can you post a screenshot of your Tools menu?
                              Hello Thomas!
                              It happens with me also! You can see a screenshot here
                              http://www.netcond.net/N3TO/Screenshot_toolsmenu.jpg
                              I see all posts but I can't resolve the trouble.
                              apologies for my bad english...
                                Check the Tools menu.
                                Tools -> Selection Toys -> Enable Toolbar
                                then after you do that - check the menu you showed in the screenshot.
                                  Version 2.2.1
                                  • Fixed Select DC Instances
                                    Sorry - I forgot to include a file. Redownload.
                                    • brookefoxB Offline
                                      brookefox
                                      It was working in V7, but I can't get Sel Toys working in V8. Feeling stupid for a number of reasons.
                                      My configurtion of Sel Toys:
                                      C:\Program Files (x86)\Google\Google SketchUp 8\Plugins\TT_Lib
                                      C:\Program Files (x86)\Google\Google SketchUp 8\Tools\TT_Select_Toys
                                      After SU8 re-start:
                                      no context picks for Sel Toys
                                      no pick for Sel Toys in Tools menu drop down
                                      ~ Brooke
                                        Don't put plugins in the Tools folder.
                                        There should be
                                        C:\Program Files (x86)\Google\Google SketchUp 8\Plugins\TT_Lib\ - (inside, lots of .rb files)
                                        C:\Program Files (x86)\Google\Google SketchUp 8\Plugins\tt_selection_toys.rb
                                        C:\Program Files (x86)\Google\Google SketchUp 8\Plugins\TT_Select_Toys\
                                          brookefox
                                          OK. Thank you. I thought that since it is accessed by the tools menu..., but thinking is not my strong suite.
                                          You must enable it from Tools->Selection Toys->Enable Toolbar before it appears under View->Toolbars->Selection Toys.
                                          While the install didn't seem that clear to me, I didn't notice many install problems in the thread, so likely I am being thick. Perhaps because I assumed it was different than the norm when it is not. (Is the download count related to this, only 141 for such a useful tool? Or is that count only since the last update or somehow not reliable?)
                                          Thanks, again.
                                          ~ Brooke
                                            Since last update - there's been thousands of downloads all together of the previous versions.
                                            With my more recent plugins I've started to add more detailed descriptions of how they should be installed.
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 27 / 30
