    Autocad to sketchup
    8 Posts 4 Posters 1.2k Views 4 Watching
      kertif
      hi everyone,
      when exporting a autocad file containing contour lines to sketchup,
      sketchup displays it in 3d,
      is there any way to be able to have all the lines in a 2d plane,
      i hope i could explain my problem,
      thanks all you
        You can use flatten whilst in the AutoCAD file.
        Or use the Sketchup Sandbox 'Drape' / 'Stamp' tools with the imported 3D contours onto a flat 2D Rectangle - they will then make a 2D outline...
        • KrisidiousK Offline
          Krisidious
          I think smustard has a flatten ruby...
          you could also use the extension plugin to extend contours to one plane.
          or of course Tig's advice with the drape and stamp.
          By: Kristoff Rand
            kertif
            thanks for replies,
            i tried to do this with drape/stamp
            but when i choose sandbox from scratch tool,
            a crush happens,
            so i tried also mover plugin to drop on 2d surface
            but it doesnt exactly drop all the elements of the dwg drawing correctly
              'Drop' won't affect vertices - only the z of the whole object.
              Look for the 'flatten' script on Smustard.com...
                kertif
                i finally found a way
                in autocad i saved the file as pdf,
                then by a pdf-to-dwg converter program i created a dwg file again,
                when i import this dwg to sketchup it is already in 2d
                thanks again for all your help
                  Krisidious
                  good thinking...
                  By: Kristoff Rand
                  • AnssiA Offline
                    Anssi
                    There is also a "flatten" command in AutoCad, it is part of the optional Express tools set.
                    Anssi
