    [Plugin] Selection Toys
    594 Posts 121 Posters 396.9k Views 121 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      See the first post for basic use.
      Thomas has a link to a Command Cheatsheet also in the first post.
      (ThomThom is in Norway, so it was the middle of his night when you posted... he'll answer... be patient. He's an SCF moderator, and checks in several times a day.)
      I'm not here much anymore.
        Khai
        erm. I did?
        and I don't see how to use it. sorry.. I mean, do I select the group then...what? the most I've got is an orange outline and nothing selected. so I'm doing something wrong...
        this is what I mean by step by step and ... be patient? I asked once and waited...?
          d12dozr
          Khai, what are you trying to select? What function are you trying to use?
          http://goo.gl/f7ooYh
            Khai
            well I want to use it.... and I don't get any selections whatever I try.. so I thought I'd ask for help..
            I did read the first post and sorry guys. there are no instructions there. you may see 'em but I don't..
            just boil it down for the terminally bewildered? so I select a group and say I want to select a row of faces I....? or I want to select a ring of edges I....?
              d12dozr
              Quick video below, you can enable/disable context-click options from the UI Settings in the Selection Toys menu.
              HTH
              [flash=853,505:3vn20087]http://www.youtube.com/v/bemMh3gpLVI&fs=1[/flash:3vn20087]
                Thanks Marcus! Great video - I should put that in the original post.
                Khai: in addition to Marcus' video that showed the menu items, you can also enable the toolbar Tools->Selection Toys->Enable Toolbar
                  d12dozr
                  Glad to help, sir...its a great plugin, feel free to use the video in your top post if you think its good enough.
                  http://www.youtube.com/watch?v=bemMh3gpLVI
                    Khai
                    thank you that really helps πŸ˜„
                    tho somethings not working right - selecting N-gons does not work at all... and I know there is some.. I can see them...!
                        Khai
                        Select Ngon
                          Select Only -> Polygons ?
                          Note that Select Only and Deselect modifies your current selection - doesn't add to it.
                            Khai
                            that's exactly what I'm doing.
                            select the model, then Select Only -> N-Gons and nothing is selected, even tho I can see Ngon's.
                            to clarify :Stoys.jpg
                              Better if you post your SKP file πŸ˜‰
                                Khai
                                sorry cannot do that, it's copyrighted work that will be for sale, and it's not just the mesh in the image above.
                                  Polygon and N-Gon refer to entities where the Entity Info display Polygon.
                                    Khai
                                    erm... pardon?
                                    ok I must be being dense... that made no sense at all?
                                      In fact i believe this N Gon function shown only figures who are made with the tool "Polygon" πŸ˜‰
                                      And not geometric figures that you can see as Ngons πŸ˜‰
                                        Exactly - the selection tool doesn't look at the shape of the geometry, but filters the selection based on the types of entities SketchUp reports.
                                        When you select something in SU, the Entity Info window will say what type it is - all the filtering is based on these types.
                                          Khai
                                          ah. thanks for your help then.. this explains all my problems with this Ruby. we're not compatible.. but thats ok.
                                          • N3TON Offline
                                            N3TO
                                            @thomthom said:
                                            I can make so sense why you would not have a Selection Toys menu item under tools and various Context Menu entries (which depend on what you right-click)
                                            I was about to ask if you'd checked the Preferences for Selection Toys, but if you have not menu... I'm really stomped.
                                            Can you post a screenshot of your Tools menu?
                                            Hello Thomas!
                                            It happens with me also! You can see a screenshot here
                                            http://www.netcond.net/N3TO/Screenshot_toolsmenu.jpg
                                            I see all posts but I can't resolve the trouble.
                                            apologies for my bad english...
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 29
                                            • 30
                                            • 17 / 30
