    Corrugated Roof problem
    9 Posts 6 Posters 2.9k Views 6 Watching
    • gascatG Offline
      gascat
      Hi all, this is my first post. I have searched but cannot seem to find a solution to this.
      I am probably an "intermediate" user of sketchup. I do ok but not great (but i'm counting on getting better!)
      I have learned quite a bit by browsing this forum and now need some help.
      I need to create a roof of corrugated iron for a new house design. I am using the ROOF ruby to create the roof it's self and to replace roof panels with corrugated iron I make a large piece of corrugated iron, copy and paste a roof panel on to the iron, explode both and do an "Intersct Selected" then erase the material that is remaining. This works fine but is a very drawn out process.
      I have attached some pics of the result I am after.
      I'm hoping someone has had experience in creating iron roofs like this or can suggest a plugin or a more simplified method of acheiving what I want.
      cheers...Wayne
      • mitcorbM Offline
        mitcorb
        I do not use the roof ruby, so I cannot comment on that.
        My approach would be, as I "understand" your post:
        1. Consider using a texture for the roof plane. Sk6 had an extended materials selection that included corrugated aluminum, brown?, and rust. I think you can modify color attributes of these to create a unique texture.
          Or:
        2. Make a simple component consisting of the "sine wave" shape repeated. Where you have to trim the panel, make it unique, use a circle as a cutting plane perpendicular to the panel plane, intersect with selected, erase unwanted.
        As I said this would be my approach, maybe not yours or others who may advise you.
          mac1
          Making the corrugated roof a component then installing a possible approach. See this TUT which may help you http://forums.sketchucation.com/viewtopic.php?f=18&t=11042
          • daleD Offline
            dale
            I also like to model the actual roofing rather than use a texture, and I find Gaeius's tutorial works well until I get into complex roofs, and then it is back to the intersect technique.
            I have actually though about trying to learn how to Ruby script for this process alone, to see if I could develop a script that would take a roof plane and replace it with a standing seam or corrugated component etc. Unfortunately this is just not in the cards for me at the moment, so I'm watching this thread with interest.
            • wind-borneW Offline
              wind-borne
              1001bit pro plugin
              "To read between the lines was easier than to follow the text."OSX 10.11.6
              %(#BF80BF)[SU 8 pro
              • KrisidiousK Offline
                Krisidious
                yeah the 1001bit Pro is the tool for you... may cost $40.00 but how much time have you wasted so far? and how much is your time worth?
                By: Kristoff Rand
                • daleD Offline
                  dale
                  I own it now, I didn't realize all it could do. Thanks
                  • gascatG Offline
                    gascat
                    Yeah...$40 is a small price to pay when I look at the bigger picture.
                    Thanks for the advice.
                    Cheers...Wayne
                      Krisidious
                      yes it's very powerful... already saved me many hours. be sure to come back and show us what you've done.
                      By: Kristoff Rand
