    [Plugin] Selection Toys
    594 Posts 121 Posters 381.3k Views 121 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      I see a general issue. There's is a unins000.dat and unins000.exe in his plugins folder. What plugin is this for ?
      These files should be in the specificplugin subfolder, or else the installer will be overwriting these files for subsequently installed plugins, and the original plugin can no longer uninstalled with these files.
      I'm not here much anymore.
        Jim
        Twilight Render, I assume. I mentioned the issue on the Twilight support forum, was told it's not a problem, and didn't follow-up.
        Their installer need work anyway because when you install to a folder that is not the default - SketchUp 7 - none of the preset locations use the custom location and you need to change them manually. 😠
          Dan Rathbun
          It wouldn't be a problem if the file names were say, uninsTLR.dat and uninsTLR.exe; anything but the installer's defaults.
            Khai
            can someone give me a step by step idiots guide on how to actually use this?
            I can get it to light an edge up orange. that's all. how do you select things with it?
              Dan Rathbun
              See the first post for basic use.
              Thomas has a link to a Command Cheatsheet also in the first post.
              (ThomThom is in Norway, so it was the middle of his night when you posted... he'll answer... be patient. He's an SCF moderator, and checks in several times a day.)
                Khai
                erm. I did?
                and I don't see how to use it. sorry.. I mean, do I select the group then...what? the most I've got is an orange outline and nothing selected. so I'm doing something wrong...
                this is what I mean by step by step and ... be patient? I asked once and waited...?
                  d12dozr
                  Khai, what are you trying to select? What function are you trying to use?
                  http://goo.gl/f7ooYh
                    Khai
                    well I want to use it.... and I don't get any selections whatever I try.. so I thought I'd ask for help..
                    I did read the first post and sorry guys. there are no instructions there. you may see 'em but I don't..
                    just boil it down for the terminally bewildered? so I select a group and say I want to select a row of faces I....? or I want to select a ring of edges I....?
                      d12dozr
                      Quick video below, you can enable/disable context-click options from the UI Settings in the Selection Toys menu.
                      HTH
                      [flash=853,505:3vn20087]http://www.youtube.com/v/bemMh3gpLVI&fs=1[/flash:3vn20087]
                        Thanks Marcus! Great video - I should put that in the original post.
                        Khai: in addition to Marcus' video that showed the menu items, you can also enable the toolbar Tools->Selection Toys->Enable Toolbar
                          d12dozr
                          Glad to help, sir...its a great plugin, feel free to use the video in your top post if you think its good enough.
                          http://www.youtube.com/watch?v=bemMh3gpLVI
                            Khai
                            thank you that really helps πŸ˜„
                            tho somethings not working right - selecting N-gons does not work at all... and I know there is some.. I can see them...!
                                Khai
                                Select Ngon
                                  Select Only -> Polygons ?
                                  Note that Select Only and Deselect modifies your current selection - doesn't add to it.
                                    Khai
                                    that's exactly what I'm doing.
                                    select the model, then Select Only -> N-Gons and nothing is selected, even tho I can see Ngon's.
                                    to clarify :Stoys.jpg
                                      Better if you post your SKP file πŸ˜‰
                                        Khai
                                        sorry cannot do that, it's copyrighted work that will be for sale, and it's not just the mesh in the image above.
                                          Polygon and N-Gon refer to entities where the Entity Info display Polygon.
                                            Khai
                                            erm... pardon?
                                            ok I must be being dense... that made no sense at all?
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 29
                                            • 30
                                            • 22 / 30
