    Permanent Window Cut Plugin?
    34 Posts 10 Posters 7.0k Views 10 Watching
      dtrarch
      hi EM
      Tried with no other script installed on SU 8 pro on desktop (XP Pro) and SU 8 free on my laptop.(Win 7 family pro)
      (made sure that sketchup.rb was there too per script req)
      The sketchup.rb is a copy of the one on version 7.1 that works like a charm.
      version info:for script
      Author : Bill Wood at wh.wood@ntlworld.com
      Usage : Select component(s) on faces and run
      Date : April 2006 - May 2009
      Test made on hole cutout.skp
      Script shows up on plugin menu but no luck on select/execute.?
      Too bad to not have this one work for sure.
      Thanks for taking another look too.
      dtr
        Jim
        It should not work for anyone. It tries to call the .entities method on a ComponentInstance.
        So for the folks where it does work, you have some other plugin installed that is defining a .entities method for ComponentInstances.
        Here is the corrected version.
        componentpunch.rb
          dtrarch
          Jim
          Thanks a bunch.
          A real bread and butter app and now works as advertised.
          Good of you to intercede. ๐Ÿ˜„
          dtr
          • mitcorbM Offline
            mitcorb
            Jim: 2 questions
            Will this be listed in the Extensions Index?
            Should this thread be retitled?
            And thank you for the revision.
            • EarthMoverE Offline
              EarthMover
              It's nice to rediscover these obscure and rare plugins and find them so useful. This one in particular as it was buried in a thread and never even got it's own post. If it were still in development, I would ask that a one step undo be added.
              Content Creator at Skapeup
                Crazzy plug ๐Ÿ˜Ž
                Just a note if you copy move the component after one use of Component Punch
                this one don't work again with this component moved! ๐Ÿ˜ฎ
                Seems component "Glue" state is losted โ“
                  EarthMover
                  Pilou,
                  Seems you have to reglue the window (ThomThom's Superglue plugin) and then choose "make unique" and the window will punch properly after that. Although it does still lose it's orientation to glue to other horizontal planes.
                    Thx I will see that ๐Ÿ˜„
                      That's works ๐Ÿ˜‰
                      http://forums.sketchucation.com/download/file.php?id=54431
                        You can modify the code so that if does retain the hole punching property of the component - but the punched hole doesn't move with it...
                        Line #186... add a # so it reads #comp.glued_to = nil - from now on after a restart of SUp any newly punched-component will continue to make a hole in the same face as before.
                        This very tool actually forms the basis of a hole-puncher I have had on a back-burner for many months...
                        Imaging a variant of this tool with a few tweaks, such as -
                        Operated from the right-click context-menu if the selection contains suitable components that punch a hole in a 2D face...
                        Retaining the component's hole-punching properties in the original face.
                        Ability to limit the punched hole's "depth" [say 500mm/20" - adjustable perhaps by right-click dialog], so that if it's a component placed on a single skin wall face then there isn't a hole punched right across the room!
                        A way of linking the faces of the punched hole's "reveals" to the punching-component - using id attributes based on a time+rand id-stamp, and suitable observers attached to the component/reveal's-geometry - both at startup of tagged items if preexisting and as they are punched/made - so that then if you Move/Scale/Rotate a punching-component its associated reveal's-geometry transformation is adjusted to suit [that is, the 3D hole moves with the punching-component]; and also if you erase the punching-component the reveal's-geometry goes too [perhaps with a dialog asking if you want to keep the punched hole(?)]; and if you erase any part of the reveal's-geometry all of the reveal's-geometry erases - but perhaps with a dialog asking if you really want to do that, OR to recreate the punching-component's hole [therefore keeping the attribute linking]; if you Move the face containing the inner reveals hole then the reveals will stretch to suit automatically; if you distort [e.g. Scale] the edges forming the inner-hole of the reveal then this does not affect the rest, but if you Scale/Move the edges forming the outer-hole of the reveal [i.e. in line with the punching-component] then it does the same to the punching-component - e.g. moving it or scaling it to suit the changes - perhaps with a dialog asking if you want to do that...
                        The reveal's material etc should match those of the inner face so that the outer wall face material is not used incorrectly;...
                        Comments on this welcome... It's just I never finished tidying up my code for publication... โ˜€
                          EarthMover
                          Thanks TIG the code tweak fixed the issue with the windows retaining their cutting and gluing attributes. The plugin you are working on sounds like a winner. I like the idea of defining punching depth. This would allow punching through single surface walls without coming out the other side. I also love the idea of being able to make changes to the components and having it reflected in the hole. Another option, if doable, would be the ability to "heal" the punch and delete the component leaving no trace of a hole. Sounds similar to the double cut plugin ThomThom was working on.
                            DoubleCut ๐Ÿ˜ฒ ๐Ÿ˜•
                            walks off to a corner, huddles up rocking
                              I know that tt and I are working in parallel - and parallel lines never meet!
                              Several others - including Didier have also had ago and given up... ๐Ÿ˜’
                              • utilerU Offline
                                utiler
                                This has been a feature request for future SU releases I don't know why it hasn't been taken seriously by Google. During 3D Basecamp a few weeks ago I discussed just this with a few Googlers and pointed out that with the inclusion of solid tools in V8 it makes sense that this should be the next step.
                                I am aware we are talking about two different things in solids and components but there are similar outcomes.
                                Assume 100mm walls are modeled and grouped. chose component [door/window, DC even...] and select insertion point. Ideally the component will be created to suit 100 thick walls so when inserted both wall planes are cut at the reveals.
                                Move the window and the reveal moves with it. Edit the DC attributes to change height of the door and the reveal changes with it. Remove the door and the wall planes clean up....
                                If this could be done, it would take SketchUp into a new dimension IMO.
                                Just Curious...
                                  I have decided to work on it 'now' [rather than later]... already it's better than the 'base-tool' - e.g. the reveal faces now match the inner face's properties...
                                  Watch this space - or its sibling thread............
                                    That's great news, a much needed tool
                                      Ay yes the famous line 186 makes the trick ๐Ÿ‘
                                      http://d9.img.v4.skyrock.net/d97/stock-car-du-sud/pics/1357430234_small.jpg
                                      ๐Ÿ˜‰
                                        Edit ๐Ÿ˜ฎ
                                        Yes you can copy it on the same face, but not on another perpendicular face! ๐Ÿ˜•
                                        Glue is losted again ๐Ÿ˜’ ๐Ÿ’š
                                          EarthMover
                                          Quick vid using component punch and 1001bits to make windows with mini blinds. http://www.screencast.com/t/MTU5NDAw
                                            Edit
                                            Curious this morning all woks fine with the line 186 ๐Ÿ˜ฒ โ˜€
                                            http://forums.sketchucation.com/download/file.php?id=54488
