    [Plugin] Solid Inspector
    303 Posts 99 Posters 368.3k Views 98 Watching
      ๐Ÿ˜„
      • F
        fountainhead
        I think this plug-in is long overdue...great job ThomThom! I can't tell you the number of times I've tried a boolean operation, or a volume calculation, only to get the "this ain't a real solid dude" message.
        "It isn't a real solid...well what's wrong with it?"
        "Not gonna tell ya...but it's wrong for sure. Good luck finding the problem man."
        Now instead of hunting aimlessly for the micro gapped edge, or the itty bitty hanging triangle that can only be seen under exponential magnification, you point us right to it.
        NICE.
          ๐Ÿ˜„
          • T
            tomislavm
            When can we expect this
            Future Ideas
            * Webdialog list of errors with description of each error. If possible, attempt to automatically fix.
            Automatically fix, o yes!
              I don't know. It all depends on when I get a spare moment. I'm currently looking into some UV mapping tool.
                Jim
                Hi Thom. Here's a scenario - I have a Group I'm checking for a solid. It's quite big and takes a few seconds to open and close the Group. When I use Solid Inspector on the Group to find the errors, I then need to open the Group for editing to fix them, then close it to re-check - open, close, open, close, etc.
                Would it be possible to tell the plugin to operator on the current context so we do not need to always change the context between checking and fixing?
                  Yea - I've been thinking it needs a function like that.
                  adding to the todo list
                  • B
                    Bertier
                    Hi there, would it be possible to tell solid :
                    this is (for example) : solid oak
                    solid oak is : 640 kg / cubic meter
                    solid weight : whatever volume * 640 in this case ?
                    that would be great.
                    thanx to you guys !
                      d12dozr
                      Bertier,
                      Have you seen Volume Calculator by TIG?
                      http://goo.gl/f7ooYh
                      • B
                        Bertier
                        thank, I hadnot seen it.
                        • Chris FullmerC
                          @tomislavm said:
                          Future Ideas
                          I've also written a solid checking tool about a year and a half ago here:
                          http://forums.sketchucation.com/viewtopic.php?f=323&t=17876
                          The next day TIG followed my plugin with one of his own that attempts to fix missing faces here:
                          http://forums.sketchucation.com/viewtopic.php?p=143720
                          So you might already have a script that eill help detect and cleanup non-solids. Good luck,
                          • mariochaM
                            mariocha
                            You made made day !!!
                            Works just fine.
                            This is going to be so usefull !
                            %(#008000)[Mario C.
                            • FabiazzF
                              Fabiazz
                              Why I didn't notice this plugin before. This will fix all my unsolidity problem. Great work!
                              • P
                                panpanndundu
                                nice plugin..thanx you...
                                • V
                                  vidy
                                  hmm.. this is been waited for so long too.. ๐Ÿ‘
                                  before i was count on Whaat UV tool, but i don't know, lately we can't get it to work and there is no confirmation from Whaat regarding to the problem.. ๐Ÿ˜ข
                                  i hope this one could be really solved this issue. ๐ŸŽ‰
                                  regards,
                                  still so much to learn..
                                  • P
                                    pdwyer
                                    This looks like it's going to help me a lot, (THANKS) I'm wondering about what it's telling me. In this particular group its says I have a mess but I'm not 100% sure why. So Orange is a hole and Red is an error? what kind of error? Looking at the pic below, what should I be looking to fix?
                                      Jim
                                      Check for internal faces, for a start. They are usually easier to find than small holes.
                                      Stray edges, also but they can be harder to find especially if small. Todd's StrayLines is an excellent tool for finding those.
                                        By the looks of it I'm guessing it's internal faces.
                                        I'm adding it to my todo list to update this so it gives more info to exactly what the highlight error is.
                                        • GaieusG
                                          How about a plugin that actually fixes these glitches instead?
                                          ๐Ÿ˜‰
                                          (Yes, I know, I know, we discussed it back in August already...)
                                          ๐Ÿ˜„
                                            ...yea... it's there... somewhere on the list... ...the very long list... ๐Ÿ˜ž
                                            • 15
                                            • 16
                                            • 2 / 16
