    [Plugin] Solid Inspector
    303 Posts 99 Posters 368.3k Views 98 Watching
      @jim said:
      Would it be possible to tell the plugin to operator on the current context so we do not need to always change the context between checking and fixing?
      Yea - I've been thinking it needs a function like that.
      adding to the todo list
      • B
        Bertier
        Hi there, would it be possible to tell solid :
        this is (for example) : solid oak
        solid oak is : 640 kg / cubic meter
        solid weight : whatever volume * 640 in this case ?
        that would be great.
        thanx to you guys !
          d12dozr
          Bertier,
          Have you seen Volume Calculator by TIG?
          http://goo.gl/f7ooYh
          • B
            Bertier
            thank, I hadnot seen it.
            • Chris FullmerC
              @tomislavm said:
              Future Ideas
              * Webdialog list of errors with description of each error. If possible, attempt to automatically fix.
              Automatically fix, o yes!
              I've also written a solid checking tool about a year and a half ago here:
              http://forums.sketchucation.com/viewtopic.php?f=323&t=17876
              The next day TIG followed my plugin with one of his own that attempts to fix missing faces here:
              http://forums.sketchucation.com/viewtopic.php?p=143720
              So you might already have a script that eill help detect and cleanup non-solids. Good luck,
              • mariochaM
                mariocha
                You made made day !!!
                Works just fine.
                This is going to be so usefull !
                %(#008000)[Mario C.
                • FabiazzF
                  Fabiazz
                  Why I didn't notice this plugin before. This will fix all my unsolidity problem. Great work!
                  • P
                    panpanndundu
                    nice plugin..thanx you...
                    • V
                      vidy
                      @thomthom said:
                      I'm currently looking into some UV mapping tool.
                      hmm.. this is been waited for so long too.. 👍
                      before i was count on Whaat UV tool, but i don't know, lately we can't get it to work and there is no confirmation from Whaat regarding to the problem.. 😢
                      i hope this one could be really solved this issue. 🎉
                      regards,
                      still so much to learn..
                      • P
                        pdwyer
                        This looks like it's going to help me a lot, (THANKS) I'm wondering about what it's telling me. In this particular group its says I have a mess but I'm not 100% sure why. So Orange is a hole and Red is an error? what kind of error? Looking at the pic below, what should I be looking to fix?
                          Jim
                          Check for internal faces, for a start. They are usually easier to find than small holes.
                          Stray edges, also but they can be harder to find especially if small. Todd's StrayLines is an excellent tool for finding those.
                            By the looks of it I'm guessing it's internal faces.
                            I'm adding it to my todo list to update this so it gives more info to exactly what the highlight error is.
                            • GaieusG
                              How about a plugin that actually fixes these glitches instead?
                              (Yes, I know, I know, we discussed it back in August already...)
                                ...yea... it's there... somewhere on the list... ...the very long list... 😞
                                • GaieusG
                                  Guy posted it in its new topic here:
                                  http://forums.sketchucation.com/viewtopic.php?f=323&t=33471
                                  • G
                                    GWD
                                    This Plugin try to fix problems with groups that suppose to be solids but don't show up like a solid in SU.
                                    fixSolid fix the following problems:
                                    * remove single edges
                                    * remove separate faces
                                    * remove edges between coplanar faces
                                    * remove innerfaces
                                    * remove all edges with only 1 face connected (RISKY FIX)
                                    Usage: 1. Select solid
                                    2. Right-Click Context-Menu. If the solid is broken the option 'FIX SOLID'
                                    is present. If the option isn't present there are no problems with
                                    the solid.
                                    3. Select 'FIX SOLID'
                                    4. You get the option to do a risky fix. If you choose a risky fix
                                    it is possible that a part of the solid wil be deleted. This action can
                                    be undone with the normal SU undo function. The risky fix try to fix
                                    all problems, the normal fix only fixes problem with no risk.
                                    Download from: http://forums.sketchucation.com/viewtopic.php?f=323&t=33471
                                    • Chris FullmerC
                                      WHat about TIGs plugin that does this? I posted a link to it on the previous page. Has anyone tried it? Does it work well? Here's the link again:
                                        driven
                                        hi Thom,
                                        I've turned on 'BackEdges', coloured the enclosed faces and added a section plane to highlight 'enclosed faces', could this be added..... or maybe highlight enclosed edges, as deleting these is the remedy....
                                        just some thoughts while testing.
                                        btw, the return key as well as tab scrolls thru your views on the mac and getting back to the select tool doesn't work with the space bar when using...
                                        keep up the good work
                                        could this be auto generated within the script?
                                          I avoided using material as I didn't want to clutter people's models. Removing materials requires some akward workarounds and I didn't want to get into that. Section planes are the same, need to apply some silly hack to add them to the scene ... and I don't think one can even activate them via Ruby. 😞
                                          It should be highlighting the edges though, while the tool is active. you're not seeing that?
                                          Yes, Tab and Return allows you to navigate to the various areas (I want to make a UI for that.) though it should not be interfering with the Space key at all. I have no problems using it while I use the tool. ... ??
                                            driven
                                            fair point, but what about using a 'style' set,that's purged when your done?
                                            @thomthom said:
                                            Section planes....(edit) I don't think one can even activate them via Ruby. 😞
                                            it seems to me that the api lets you, but I'm no coder...
                                            sorry, it is highlighting the multi-face edges, it's the enclosed/internal (to volume) edges I was wondering about
                                            I'm just airing ideas 'for that', I've tested/used all the pre-existing repair-aid scripts (TIG's,VW,CadSpan,etc.) and currently use bits from each, in a rather untidy workflow.
                                            we stop for Xmas next week and I'll try and organise my thoughts a bit better,
                                            I like what you've done with this so far...
                                            • 15
                                            • 16
                                            • 2 / 16
