    SketchUP 8
    345 Posts 101 Posters 138.0k Views 101 Watching
      Stu
      Thanks for that John.
      I still think you would be hard pressed to put forward a good case for upgrading.... to SketchUpers who dont use GE or Layout...[and these seem to be in the majority in this thread]
      The general consensus seems to be that there hasnt been a lot of signifigant development in 3D modeling....which is really the core of SketchUp.
      http://www.landesign.com.au
      • brodieB
        brodie
        We added a feature in SU8 that allows you to save and restore toolbar configurations. Was this not the error you wanted corrected?
        I sortof laughed a bit when I saw that feature actually. It's really more of a workaround than a fix isn't it? Fine for a point release but underdeveloped for a major verion release. For a version release, I'd expect to see a fix that would make "restore toolbar configurations" irrelevant. And perhaps an added feature in the Pro version so that you could toggle between, say, 3 different user defined toolbar configurations.
        If you are an architect, it may be interesting to know that we have just granted you convenient access to Google's complete collection of geo-spatial imagery for more or less the entire world.
        This is probably the most helpful tool(s) for this release to architects (less-so for those of us who do renderings as the details/quality is still to low). I think the real issue is that no one really seemed to be clamoring for this. As a matter of priorities there were features that were far more important.
        Many users prefer that the look of the UI not change dramatically from release to release.
        Strawman. No one said that it should change dramatically. Personally, I like the SU UI better than most programs, but it is nice to see a little aesthetic change with major releases.
        What benefit do you hope to gain from a 64-bit version of SketchUp? This is really this question that needs to be discussed.
        Speed (particularly with plugin routines) and the ability to carry higher poly counts without considerable slowing. SU can't handle more than 1 high poly tree or car for architectural renderings.
        We increment to a major version number when we think that we've made enough changes that users will want to keep both the new version and the old version installed side-by-side.
        This is an easy one. Users neverwant to have multiple versions of the same program installed. If I have multiple versions of the same program installed it's because there is something wrong (removed features I see as necessary or bugs). I think a better goal would be to wait to put out a new version until you've successfully made the old version redundant and inferior.
        What about this release made you think that users would still want to use the previous version? The only thing I can think of would be the DWG import. If that's the case then how about simply leaving dwg import in to solve the problem?
        I agree that Push/Pull operations from multiple pre-selections would be a neat thing to add. We might do something like that in the future, but it wasn't possible to do so for SU8.
        Not "possible" seems like pretty strong language, particularly considering someone already figured out how to incorporate it (Joint Push/Pull).
        -Brodie
        • jbacusJ
          jbacus
          What benefit do you hope to gain from a 64-bit version of SketchUp? This is really the question that needs to be discussed.
          64-bit processing will have no benefit to managing higher poly counts without considerably slowing. Performance in this area depends either on the capability of your GPU, or the clock speed of your CPU. Memory is not the bottleneck for these kinds of operations.
          "...exaggerate the essential and leave the obvious unclear." --Vincent Van Gogh
          John Bacus
          jbacus@sketchup.com
          • boofredlayB
            boofredlay
            This for me was huge and it works great. Thank you so much.
            @jbacus said:
            If you are an architect, it may be interesting to know that we have just granted you convenient access to Google's complete collection of geo-spatial imagery for more or less the entire world. In many parts of the world, you can now build a site model with accurate terrain, aerial and street-level photography and rough massing models for adjacent structures in minutes... without leaving your desk.
            Working for an architect I see this as a huge improvement as well. I was able to generate the entire site for a local airport we are working on in only minutes. Wow I say, wow.
            It may seem that this release has been geared more for Google Earth but all the added functionality I will be able to use in my workflow and I have never contributed to Google Earth.
            Although I might soon enough. πŸ˜‰
            • jbacusJ
              jbacus
              I think you misunderstood my point. I don't mean that it is impossible for someone to write a push/pull operation that operates on multiple pre-selections. Instead, I meant that it was impossible for us to do so in the time available before the release of SU8. Simply put, it wasn't something we wanted to work on instead of the other things we did work on.
              John Bacus
              jbacus@sketchup.com
              • KrisidiousK
                Krisidious
                @jbacus said:
                @krisidious said:
                I used the DWG Export in Layout3 and it seems to be kinda fake... it does export the layout lines to Auto-CAD and it converts text to actual Auto-CAD text, however the Sketchup model itself does not export out of layout as vector lines. it comes out as a referenced image in the dwg file.
                LayOut is exporting the exactly what has been rendered in the model view. If you want vectors in the exported file, be sure that you have vector rendered the model view.
                Took me a while to find that Vector Option... Excellent Excellent Excellent. this alone may make 8 Pro worth the upgrade fee... not fake at all. this means the image export into dwg is just an extra feature not a substitution. very nice. and perhaps this vector option will help me with dimensioning precisely... very nice. thanks John.
                By: Kristoff Rand
                • brodieB
                  brodie
                  I understood your point but perhaps I didn't word myself well enough. From a user's perspective who makes the SU8 deadline? You. For that matter who decided that the next version would be 8 rather than 7.2? You. So when yousuggest that the deadline didn't allow for a much requested feature it comes off as ingenuine.
                  -Brodie
                    d12dozr
                    From what I understand, it will allow rendering larger models inside Sketchup without running out of RAM.
                    http://goo.gl/f7ooYh
                    • jbacusJ
                      jbacus
                      High resolution image export, especially when antialiased, does require a considerable quantity of memory. But a shift to 64-bit processing probably isn't required for improvement in this area. It would be useful to hear the actual image resolution you're trying to achieve so we can better study the problem.
                      John Bacus
                      jbacus@sketchup.com
                      • brodieB
                        brodie
                        Yet there are, in fact, other programs which can handle polygons in the order of magnitudes more than SU with a decent gaming GPU and multiprocessor (ie. low clock speed) processor. If the answer to that isn't 64-bit then so be it (there are 32 bit programs which handle many more polygons as well), but the issue can't be pawned off to GPU and clock speeds. All the empirical evidence points to a SU programming issue rather than a hardware one.
                        Your argument has remained the same for some time now (64 bit isn't needed and may even be bad for SU users). What would be more welcome is for you to improve the aspects which cause people to request 64-bit and point to THAT empirical evidence, showing that you can give them the speed and poly enhancements they desire without 64-bit support. So far it's just been an intellectual argument without any evidence that SU actually can make significant improvements within the 32-bit realm.
                        In fairness, v7 was a nice step up both speed and poly handling. However it's just still so far below where other programs are currently at (or have been at for years) that the frustration will remain until "significant" improvements have been made.
                        -Brodie
                          d12dozr
                          John,
                          I should have been more clear, I meant rendering with a plugin inside Sketchup. I use Twilight, I understand Vray and other render programs have similar trouble. Depending on model size, trouble can start at 2000 px.
                          Thanks for replying.
                            d12dozr
                            FWIW, Windows users can only export up to around 4000px wide images. I've never needed more that, but other users (recently Pixero) have mentioned needing larger exports than that.
                            • T
                              tim
                              I suspect many people are mis-using the whole '64 bit' thing.
                              Changing a program to use 64 bit sized pointers may well slow it down since you now have to move around twice as much data for every operation. Whether that is a noticeable effect depends a great deal on the exact operations involved and the precise details of the machine you are using. And what other programs are running and how much real memory they are holding on to and how much vmem thrashing that causes.
                              Changing a program to use the 64 bit instruction set available in the recent intel cpus is a different thing. Hidden under the ugly lump of crapulence that pretends to be a Pentium 17 or whatever it would be by now is a reasonably well thought out RISC machine with a lot of capabilities, many more registers than the stupid x86 instruction set and potentially better performance.
                              It's like the whole 'why isnt SU multicore' outcry. Not every algorithm is sensibly parallelisable, nor easily. A pity, since massive parallelism is the only way we are likely to be able to take advantage of future benefits of Moore's Law. It may even be that in order to use hundreds of cores we have to change to much less 'efficient' algorithms from the perspective of a single cpu.
                              • brodieB
                                brodie
                                @d12dozr said:
                                Personally I think a better fix, at least in the case of exporting images, would be to have the ability to determine the thickness of SU's linework. I find personally that because a line is always 1 pixel thick I end up having to export very large images even if (especially if) I don't need that much resolution. I'll end up exporting a very large image and then reducing the image size in photoshop. Other than this reason, I'm not sure why someone might need a SU image to export at more than 4,000 pixels (between poly counts being limited and texture resolution limits I can't imagine what benefit you'd get).
                                -Brodie
                                • T
                                  Thiago Luz
                                  We're not going anywhere. We are planning to continue developing SketchUp as "3D modeling for everyone." Exactly what we've been doing for the last ten years. Happily, SketchUp usage continues to increase at a respectable clip every month, and we're finding new users in all kinds of unexpected markets.
                                  We don't have plans to shift our roadmap to more completely duplicate the capabilities of either the large DCC apps (like Max, Maya, Softimage, Cinema4d, or Lightwave) or the BIM apps (like Revit or Archicad). But this shouldn't really come as a surprise to any of you that have been with us for a while.
                                  Hello John how are you?
                                  John, a SIMPLE work I decided to use a bank that was a model of BB Italia ... the sketchup only took 18 HOURS to explode the bank ...
                                  I do not expect you to transform Sketchup a 3DMax, but what is the difficulty of making the program accessible to read easily and quickly many polygons? A simple database I ate 18 hours standby and worse, he exploded it became impossible to work, I just lost 18 hours of work.
                                  SketchUp 6 + 7 + 7.1 + 8 has nothing but text and 3D Boolean operation, as you can defend Sketchup for everyone if you mention all that you exclude those who want to work professionally with the program?
                                  Forgive my English, I use an online translator
                                    rv1974
                                    Mr. Bacus answers remind me the interviews the north korean coach gave on the last Mondial.
                                    The last 3+ years of SU development look exactly like 0:7 'Massacre of the Innocents' from Portugal.
                                    πŸ˜†
                                      Aidus
                                      I'm talking about simple things that I expected. When You need texture a lot of archs than sketchup is a big pain in one intresting place. When I need to export big size image ... again sketchup is dissapointment. When I need export large size model to renderer ... again ... And so on. And nothing is made since version 6!!! I don't ask sketchup to be as powerful as 3ds max but for gods sake do something for every day users not for that crap google earth!
                                      CPU: Intel Core i7 Extreme Edition 965
                                      RAM: OCZ Gold DDR3 1600MHz 12Gb
                                      Video: Asus Radeon HD4870 X2 2Gb
                                      Mobo: Asus P6T Deluxe 1366 Intel X58
                                      • C
                                        cadmunkey
                                        @jbacus said:
                                        @cadmunkey said:
                                        Jeez.. no 64 bit version in 2010? C'mon Google you've dropped the ball! You beta testers couldnt persuade them?
                                        John I hope you are joking. Obviously more memory space and the ability to render out complex models. You said:
                                        "If you are an architect, it may be interesting to know that we have just granted you convenient access to Google's complete collection of geo-spatial imagery for more or less the entire world. In many parts of the world, you can now build a site model with accurate terrain, aerial and street-level photography and rough massing models for adjacent structures in minutes... without leaving your desk."
                                        What use is all this if when I get to the point of wanting to render out my proposed building it crashes because SU has reached its memory limit?
                                        Dont mess around, its 2010 and you're saying 64bit isnt the way forward for SU? I guess what you are really saying is "tough luck, thats a render program problem, NOT a limitation of SU".
                                        • L
                                          l.frisken
                                          Hey John,
                                          Just want to say thanks for replying to some of these questions. I personally find the fact that you have bothered to take the time to reply to us much more satisfying than any new sketchup features. The fact that the sketchup team is willing to openly converse with its users is a big thing I guess, and not something I was really expecting given its track record of versions in the past few years (which is why many complain). Now I can be put to rest and just accept that sketchup will probably never do some of the things I would like it to do, and I mean that in the best way possible. I can plan ahead and make sure that I have other tools on hand to fill the gaps around sketchup. There are of course many simple core problems in sketchup, that, I'm sure will get solved given enough time, but I'm no longer left in the dark half hoping that they will get fixed soon.
                                          Thanks πŸ˜‰
                                            Kindof is... SU was designed as a sketching application. By the sound of it, more render apps are moving to studio solutions - to escape the 32bit limitation of SU.
                                            The thing is, people as for more performance at the same time they demand 64bit. As it's been mentioned before, 64bit mean more data to process and can just as easily hurt performance.
                                            However, I use render engines as well, I'd love to be able to use more memory, but I realise that 64bit is no magic bullet for SU it comes with its cons as well.
                                            But I'm curious if SketchUp can be made LargeAddressAware, which would mean under 64bit OS it could address 4GB ram instead of 2. And it's just a compiler flag - pretty much free - without the overhead of 64bit processing.
                                            http://msdn.microsoft.com/en-us/library/ee418798%28VS.85%29.aspx#The__LARGEADDRESSAWARE_flag
                                            Wouldn't give you as much memory available as 64bit - but 4GB is a whole lot better than 2GB.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 17
                                            • 18
                                            • 12 / 18
