    Vray animation problem - settings
    renderpluginsextensions
    11 Posts 3 Posters 2.8k Views 3 Watching
      Is that the actual size you render to?
      Have you tried increasing the IR map's min/max values?
        cupko
        Thanks for replying.
        Yes, that's actual size 1000x750. I've tried with -3 and 0, but no effect. Which values should I use (approximatly)? Is that problem with IR maps or something else is on?
          The - keys - are they textured materials?
          What I usually find helpful is to refer to the Examples in the V-Ray manual:
          http://www.spot3d.com/vray/help/150SP1/
          Possibly the Image Sampler will help you in this case: http://www.spot3d.com/vray/help/150SP1/examples_image_sampler.htm
            cupko
            No. Simple text tool is used. Exploded and moved 0,01cm from the face of keys.
              cupko
              Problem solved πŸ˜„ .
              In Image Sampler changed Min Subdivs from 1 to 3. That means 9 samples for each pixel. I will try with 2, because rendering time is doubled πŸ˜’ .
              Thanks again thomthom
                πŸ‘ πŸ˜„
                  Plasticbricks
                  Hi everyone,
                  For all those starting out with Vray and those who want a better grip of it and having trouble with the settings (as I frustratingly did for two days), here is a link to the ASGVIS.COM website that offers free downloads (once you sign up) of Render Options which you can just load and all the settings are there for you, ready to go.
                  For example: there's a preset for Default Sketchup, IrMap DMC Medium, Print Quality Studio etc. Once you see what settings can achieve a certain level of rendering, it's far easier to learn the nuances that it takes to execute a particular effect.
                  http://software.asgvis.com/index.php?option=com_content&view=article&id=57&Itemid=441&Ctitle=Render%20Options
                  ASGVIS.COM also have really cool materials and other freebies as well.
                  Thank God for this site, it's made my life so much easier.
                  I hope it saves some of you guys needless hours fiddling around and swearing at Vray or SU.
                  Enjoy!
                    The day I stop swearing at software is the day I surrender my mind. πŸ˜†
                      Plasticbricks
                      Thomthom...ha ha ha, funny comment! This is completely off topic but...What's up with the double name? Cuz I used to (and still do) listen to a band called Shotgun Messiah and their bassist/singer called himself Timtim during the first album and then changed it to Tim Skold after he replaced the lead singer and became the front man himself. I was curious since you are from Freddie Ljungberg's home country. Sharing is caring...
                        It short for my full name - Thomas Thomassen. (Oh yes it's true - and that name repeats itself down my history tree - names, as it turns out, are inheritable. Though they usually skips a couple of generations.)
                        Got the nick when I went to England - we where three Thomas' in the house. One was called Thom, the other by his last name, and I became ThomThom. No one used 'Thomas' in England - they like to shorten words there. Even ThomThom got shortened, but since Thom was already used, it became TT - then even that was shortened to just T. "What some more tea, TT? hihihi..." ugh....
                        So there!
                        What's your story? πŸ˜„
