    [Plugin] Selection Toys
    594 Posts 121 Posters 587.6k Views 121 Watching
      @cadfather said:
      thanks Thom, will check Fredo's ones out.
      If you haven't seen the thread, here's the explanation from Google to why it happens: http://forums.sketchucation.com/viewtopic.php?f=15&t=27941&start=0#p243583
      • CadFatherC
        CadFather
        wow, good stuff they're on the ball
          New in version 2.2
          • Select Quad-Face loop now accept mulitple start-edges
          • Added Selection filters for Border Edges
          • Added Selection filters for Selection Border
          • Fixed Select Instances by Layer bug
          • Updated some method names to reflect changes in TT_Lib 1.2
          I didn't add toolbar buttons for the new filter. In fact, this will probably be the last of v2. There's turning out to be all too many menus and toolbars. I'm planning out a whole new UI. Probably will be more tools that let you compile the selection type you will. Maybe let you save custom types you can assign to menus and add shortcuts to. Will see how it develops - need to try out some prototypes first.
            Always on the go! β˜€
              More to come! πŸ˜‰ πŸ˜„
              Soon - very soon.
              • CadFatherC
                CadFather
                ..i'll stay up late then.
                  Not that soon!
                    But not far from it...
                    • B
                      Ben Ritter
                      Thank you is not enough, but thank you.
                      • EarthMoverE
                        EarthMover
                        @thomthom said:
                        New in version 2.2
                        [list]
                        []Select Quad-Face loop now accept mulitple start-edges
                        ]Added Selection filters for Border Edges
                        [*]Added Selection filters for Selection Border
                        So happy you added the multiple quad face selection. I constantly wish for this! THANK YOU!!!
                        Content Creator at Skapeup
                          😲 I did? wow. completely forgotten about that. πŸ˜†
                          • EscapeArtistE
                            EscapeArtist
                            I think I did something wrong, I get an error that it's looking for TT_Lib2/core.rb when there is no TT_Lib2 directory. Did I miss something in a plugin update? I just downloaded the most recent TT_Lib file from the forum post...
                              hmm... it should not require TT_Lib2...
                              Did you by any chance install any of my other plugins, one of the ones I released yesterday.
                              Can you post any errors or messages so I can see the actual thing?
                                It does !errormsg.png SO they need 'TT_Lib2 - 2.0.0.zip'
                                  That is both Image Opacity and Plan Tools that require TT_Lib2. Nothing to do with Selection Toys.
                                    Yes, they do, but not Selection Toys. Selection Toys still require TT_Lib 1.2.0.
                                      That's the only way I can recreate the error is to move the Lib2 folder... Other tools load OK... We need a screen-shot of the error-message - our psychic powers are not that powerful... πŸ˜‰
                                      • EscapeArtistE
                                        EscapeArtist
                                        My error message:
                                          That is the same as what TIG showed - it's not Selection Toys, it's Guide Tools and Image Opacity that both require TT_Lib2. Note the 2 digit here.
                                          Selection Toys require TT_Lib 1.2.0
                                          The two other plugins require TT_Lib 2.0.0
                                            stonebreaker
                                            SU 8 issue:
                                            i put the required files in the plugin folder but it doesn't appear in the app.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 29
                                            • 30
                                            • 13 / 30
