    [Plugin] SU2POV 3.5
    77 Posts 26 Posters 65.7k Views 26 Watching
    • Didier BurD
      Didier Bur
      Version 3.5 of SU2POV is out.
      New in this release:
      -HDRI lighting
      -Save/restore all settings by scene.
      HDRI lighting example
      Download it here:
      http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=425
      Have fun !
      DB
      • V
        vidy
        great mr.bur, waiting for this one
        but one question, is it available on SU 6, because the ver 3.4 wasn't able to export on SU 6, will try it though.. 😉
        regards,
        still so much to learn..
        • V
          vidy
          here we go, first problem:
          http://a.imageshack.us/img294/4840/38852015.jpg
          what i did, is delete all the first set of plugins, whic is ver 3.3 and copy the new one, and when i reestart i got that message and the povray toolbar is not loaded. 😞
          • Didier BurD
            Didier Bur
            Hi vidy,
            There's a bug in the Zip (wrong folders structure) 😳
            Please uninstall previous version completely, download and install the version 3.5 that has been updated on my site.
            Sorry for the inconvenience.
            Best regards,
            DB
            • V
              vidy
              ow.. thanks didier.. will try and give a report on it. thank you for your hard work 🎉
              oh please dont said sorry, it is us that always give you trouble for this and that haha.. 😒
              regards,
              • V
                vidy
                ok i've been try it, no problem when its loading now, but when i hit render, i got this message on ruby console:
                Error: #<LocalJumpError: unexpected break>
                (eval):3795:in ocr_query_exportas' (eval):3860:in ocr_pov'
                C:/Program Files/Google/Google SketchUp 6/Plugins/su2pov35Toolbar.rb:50
                C:/Program Files/Google/Google SketchUp 6/Plugins/su2pov35Toolbar.rb:50:in `call'
                FYI: im using SU 6 here, is it have to be installed on SU 7 and above? thanks didier
                regards,
                • Didier BurD
                  Didier Bur
                  Hi vidy,
                  The "unexpected break" occurs theorically when you hit the cancel button of the "Save as" dialog that should pop up when hitting "Render!". Did you see this dialog ? It asks for a pov file name to export. Thus you can save as many version of you model as you want.
                  Thanks for reporting bugs...
                  DB
                  • V
                    vidy
                    dear didier,
                    actually i didn't see any dialog box popped up, its just seems like there is nothing happen, until i check on ruby console dialog, and I've got those messages, that's why i'm asked about the version problem, since it running well at SU 7.
                    regards,
                    • Didier BurD
                      Didier Bur
                      I've installed it on SU6 and also got the bug.
                      The "UI.savepanel" method doesn't work the same way in SU7 API than in SU6 😢
                      So version 3.5 is for SU7 or higher...
                      Regards,
                      DB
                      • V
                        vidy
                        thanks for your confirmation didier. 😉
                        best regards,
                          solodown
                          Loading File su2pov35Toolbar.rb
                          private method `split' called for nil:NilClass
                          • pugz1983P
                            pugz1983
                            Hi Didier,
                            I realy like your plugins, but please excuse me for asking but what is the reason behind SU2POV? I mean, aren't there enough render app to render a SU scene/model. Or am I missing something. Is there a special reason for developing this app? Can SU2POW do something the others can't?
                            Greetz Twan
                            • K
                              Khai
                              @pugz1983 said:
                              Hi Didier,
                              Greetz Twan
                              POVRay is free, widely respected and hugely powerful.
                              and because you can never have enough render engines.
                              • Didier BurD
                                Didier Bur
                                su2pov is old, first version was published in 2005 and was one of the first exporter to a render app. There was not lots of them at that time (I mean free, and ascii format). Tomasz developed su2kt a year later, based on su2pov, and since then I've written su2sf among others. Su2pov was like a test program for me and made me learn lots of things about Ruby and SketchUp.
                                Yes there are plenty of render apps around, I'm not blind you know 😉 but for high quality renderings, you need a payware (Maxwell, Vray, Podium, etc). Su2pov is just for fun, although you can achieve decent results with it, IMHO.
                                Best regards,
                                DB
                                • V
                                  vidy
                                  dear didier,
                                  i have one request for the new plugin SU2POV 3.5, is it possible with the material preset, we still have the "old like" material editor? i mean, i feel much easier with slider bar to all parameter.. 😛
                                  or it is still there, but i don't how to access it 😳
                                  thanks
                                  regards,
                                    solodown
                                    Y a-t-il une solution à mon problème ?
                                    • Didier BurD
                                      Didier Bur
                                      @vidy: sorry, but the old material editor has been deleted... (it was windows-only).
                                      @solodown: il me faudrait le message d'erreur en entier (avec le numéro de ligne où ça plante). merci.
                                      DB
                                        solodown
                                        C'est la seule information qu'il me donne à l'ouverture de sketchup dans la fenêtre load error :
                                        Error Loading File su2pov35Toolbar.rb
                                        private method `split' called for nil;NilClass
                                        • V
                                          vidy
                                          Hi didier,
                                          with this new plug-in 3.5, is there a way i can attach bump image on the texture?
                                          thanks,
                                          vd
                                          • Didier BurD
                                            Didier Bur
                                            If you mean attach another image (than the one of the texture) for the bump effect, the answer is no, but you can do this editing the pov-ray material manually.
                                            regards
                                            DB
                                            • 1 / 4
