    SketchUp Command Line: RubyStartup
    19 Posts 7 Posters 14.0k Views 7 Watching
    • C
      cjthompson
      there is also a "ShowOnStartup" key under the WelcomeDialog folder in the registry.
      EDIT: Nevermind, I should have read the full post. 😳
        Jim
        It might be useful if, for some reason, the user is unable to install scripts in the Plugins folder.
        I wonder if the specified script is loaded before other scripts, after other scripts, or neither.
          In that video @22:48 - that "Developer Console" ... internal Google tool, or one of the consoles made by people here?
          • Al HartA
            Al Hart
            @tig said:
            BUT a script in Plugins in the form
            ` def xxx()
            do some stuff
            xxx()`
            does exactly that ?
            We use a solution like this when we export a model from ARRIS CAD and import it into SketchUp. We create a temporary .rb file to load the saved geometry - (saved as a ruby file to draw the geometry desired) - and then delete the temporary file.
            However, running a ruby script from the command line would be a much better solution.
            Al Hart
            IRender nXt from Render Plus
            • Dan RathbunD
              Dan Rathbun
              @jim said:
              Apparently there is a command-line option to Sketchup that accepts the path to a ruby script and runs the script at start-up.
              Would be nice, I can see uses.
              Tried it on Windows. Does not work. Either it's a Mac only thing, or he had a "special/internal" compiled version.
              I'm not here much anymore.
                @al hart said:
                ` def xxx()
                do some stuff
                xxx()`
                does exactly that ?
                With appropriate premade file you can just type at the command line in the Ruby Console load'xxx.txt'
                The .txt file [which is inside the ../Plugins/ folder] is actually a Ruby script, but without the usual .rb file extension it won't auto-load - but it will load to order.
                Inside of the script you have the closing 'xxx()' [after the 'def..end'] so it will auto-run itself once loaded. 😕
                Rarely do you need a temporary .rb - a temporary .cmd/.command file [PC/MAC] is another matter...
                You could of course load a ruby-command at startup in the usual .rb way but have it take arguments, e.g.
                def xxx(a=nil,b=[],c=0) ###do stuff using a, b, c etc end
                Then you run it from inside another script with a line like
                xxx(selection[0], selection[0].faces, 2) say to process a selected entity [edge], its faces and an option '2'.
                If you don't pass an argument value it also does an action in the form if not a... etc
                OR it will run from the Ruby Console in the same form - perhaps after you've set 'a' as xxx a, a.faces, 2
                  Jim
                  It worked for me on SU7.1 and Win XP.
                  • Dan RathbunD
                    Dan Rathbun
                    OK.. may be a Pro ONLY feature then.
                      Jim
                      Dan, this worked fine on versions 6 Free and 7 Free.
                      • Dan RathbunD
                        Dan Rathbun
                        Well... then it appears to need an absolute path. I tried it by going to the SU folder I think.
                        When Sketchup loads it sets the cwd to HOME (%UserProfile%) so that defeats any change in the directory I made prior to the command.
                        • Dan RathbunD
                          Dan Rathbun
                          I looked at that Thom, it's simply a BASH shell window (or whatever system shell he's using.)
                          Ya know, Windows used to have a clone of that shell window, Win95 or Win98. I loved it! Then Win2000 (which is NT,) has nothing but a frame with a scrollbar, and that crummy system menu. It is a royal pain just to cut and paste !! Why didn't MS port the cmd window to NT ??
                            macumber
                            This is very interesting, thanks for sharing, are there other command line arguments to SketchUp? SketchUp.exe --help, /?, etc just launches the program...
                            Dan
                              Jim
                              After that video, I went looking and found a few:
                              -template "/path/to/template.skp" # startup template
                              -notemplate # use no template
                              -page "Scene 1" # set the staring scene
                              -timing # some sort of test?
                              There's more, if you search the .exe for these strings.
