    Public Beta for Obj, SolidWorks, STEP, and FBX importers
    76 Posts 19 Posters 24.0k Views 19 Watching
      ashraf
      try importing a large SkechUp file, and compare it to opening the same file.
      Open takes much less time for the same file.
      So we are planning to take a advantage of this in the next version of the importer.
        jsteacy
        Ashraf,
        I tried the .fbx importer with the same models from that website, it brings in the geometry but does not import the textures.
        jsteacy
          ashraf
          The problem with the obj file was already fixed, and it will be included in the release
            paulower
            Fantastic.
            You have not thought about making a plugin to import of *.max to SketchUp?
            I think there not is still an importe *.max to SU.
            Baú SketchUp
            Visite nosso blog.. Visit our blog Baú SketchUp
            • N Offline
              notareal
              @paulower said:
              Fantastic.
              For that you would need installed Max... just like Deep Explorer needs. For my understanding a stand alone converter (without Max installed) is impossible to create.
                ashraf
                Yes this is correct and I believe that this reduces the value of the solution, if you have MAX already installed, then you can convert the files to OBJ or FBX.
                  ashraf
                  SimLab team is really thankful for the great feedback and suggestions, for downloading and testing the importers.
                  We are working on finalizing the plugins based on this feedback. The beta period for the plugins will end by the end of the month, and we plan for a release early in September.
                  • FrederikF Offline
                    Frederik
                    I'm somehow surprised...
                    Does this mean that you're going to release the plugin with new features even before you've tested it in a second beta-test campaign...??
                    Can you please shed some lights about what new options you will have made with the final version...??
                    Thanks in advance...
                    Cheers
                    Kim Frederik
                      Yes - I'd like to know as well. I'm interested in the FBX plugins - been thinking of buying it, but thought I would have the chance to test another release with the feedback from this thread before I decided.
                        paulower
                        So this is the problem. I do not have MAX installed on my PC. Is there any way to import files *.max to *.skp without having installed the MAX?
                        Baú SketchUp
                        • N Offline
                          notareal
                          As far as I know, there is no way.
                            ashraf
                            With the public beta we were looking for two main things:
                            1- Problematic models that the importer fails to import
                            2- Enactment suggestions
                            In the release coming after the public beta we will only address the import problems which were reported, the percentage of the problematic models compared to the number of installations was really low, and we are working on fixing those importing problems before the release.
                            Regarding enchantments, most of the requested enhancements will be available in the next minor releases which will be available free for all users (usually we provide 2 minor releases)
                            It is understandable that some users will not want to use the plugins until it meets their own requirements, the plugins will always support a trial license.
                            Encasements coming in the next minor release will include:
                            Upgrading FBX to 2011 (current FBX version in the plugin is 2010.2).
                            A new unit system that automatically scales imported models to SketchUp units automatically.
                            Progress Bar, giving the user an indication about the progress of the import process
                            Best Regards,
                            Ashraf
                            • FrederikF Offline
                              Frederik
                              Thanks, for the heads up, Ashraf...
                              I assume you mean the units the user is currently using...
                              This is great news... 😄
                              I'm looking forward to see the new plugins...
                              Cheers
                              Kim Frederik
                                ashraf
                                Thanks for the great testing and feedback from all the beta testers, the plugins were released today, and the work on the first update release to incorporate the feedback and suggestions we received had already started.
                                In this release SimLab added progress bar to inform the user that importers are working, added support for OBJ files with negative index values, and updated the plugins to work with SketchUp 8.
                                The plugins are now supported to work with SketchUp 8, 7.1 and 7
                                • 3 Offline
                                  3dsketchupper
                                  FBX import to sketchup failed? fbx was exported from Revit.
                                  Revit to sketchup file size approx.20mg
                                  One thing that we are interested with this plugin is to import revit textures into sketchup.
                                  Just wondering if this will solve our problem. Any help will be appreciated.
                                    ashraf
                                    The current plugin is capable of importing FBX files from Revit 2010.
                                    Soon it will be update to included support for FBX files from Revit 2011.
                                    Autodesk starting from Revit 2011 switched the material types used in FBX files exported from Revit, so instead of usual FBX materials it is using Autodesk internal description.
                                    This is special for Revit 2011. We are investigating a solution for this.
                                      Mra
                                      Is there a possibility that there can be an FBX plugin that exports out of SketchUp and replace the current default exporter?
                                      The default FBX exporter by Google is actually a couple of years out of date and very old. I think current version is FBX 2011.3, wheraes SketchUP uses FBX 6.1! Thanks
                                        ashraf
                                        Sure we can do that,
                                        We can add a new FBX exporter for SketchUp, this should be available soon.
                                          Mra
                                          Sounds good ashraf, thank you.
                                            ashraf
                                            Your request was fulfilled.
                                            We have FBX 2011 and OBJ exporters ready for SketchUp 7, 7.1 and 8.
                                            The plugins should work on Windows with the free and pro versions.
                                            FBX exporter can be found at
                                            http://www.simlab-soft.com/3d-plugins/FBX_Exporter_From_Sketchup-main.aspx
                                            OBJ exporter can be found at
                                            http://www.simlab-soft.com/3d-plugins/OBJ_Exporter_From_Sketchup-main.aspx
                                            Cheers.
                                            Ashraf
                                            • 3 / 4
