    [Plugin] Eclate_Deplace (fragmentation-exploded view)
    161 Posts 51 Posters 253.1k Views 51 Watching
      With newest version 3.0.2
      is there any possibility of this plugin have crashed with other plugin?
      I don't believe that
      1. i create simple cube, and then group it
      2. when i right click on the group and choose eclate_deplace, no dialog box showed up and i got this messages
      Normal : a simple cube must be composed of a 6 faces themself a group!!!
      (so for a cube: 6 faces who are each a group) !
      in this image i have selected one face for you show that is a group
      (each face is a group)
      Select them then call the plug!
      If you want transform automatically each 6 faces of a simple cube on 6 groups maybe exist a plug ๐Ÿ˜‰
      (or any faces selected)
      Facegroup by Gavvy (seems there a little problem with this facegroup plugin) Thomthom is look it!
      And I have found another one who works ๐Ÿ˜‰
      Make_components by Matt666 at Crai Ruby depot! โ˜€
      Ps Menu of "Radial Move" or "Eclate_displace" Appear by Right Click on the selection of the groups or components!
      • Y
        yvan79
        How do you use the ChrisP_RadialMove_EN.rb plugin? can anyone show an example?
          No problem ๐Ÿ˜„
            I don't see your images ๐Ÿ˜ฎ
            Verify that your object is composed of groups or components!!!
            A simple cube grouped will not works if each face is not a group!!!
            • Y
              yvan79
              Hi pilou...thanks for the instructions but i have an error of saying 'No effective transformation - nothing has been created'.
              • Y
                yvan79
                sorry for the image error....it's there now....
                  Ok I see it now ๐Ÿ˜„
                  Your result is normal
                  you have Enter 0 as X,Y,Z Translation !!! ๐Ÿ˜‰
                  Try with 10 as X,Y,Z Translation
                  and make a Zoom extend if translation is biggest between groups for see result ๐Ÿ˜„
                    Ps : And better than an image, post your SKP file ๐Ÿ˜‰
                    • Y
                      yvan79
                      Ok...now i understand it. thank you very much, pilou....
                      • V
                        vidy
                        thanks pilou,
                        its work in sketchup 7.. ๐Ÿ˜„
                        somehow it can't on sketchup 6.. ๐Ÿ˜ž it even not showing the dialog box
                        on ruby console, it show this:
                        Error: #<ArgumentError: wrong number of arguments(2 for 1)>
                        C:/Program Files/Google/Google SketchUp 6/Plugins/Eclate_Deplace.rb:30:in start_operation' C:/Program Files/Google/Google SketchUp 6/Plugins/Eclate_Deplace.rb:30:in pilou_explose'
                        C:/Program Files/Google/Google SketchUp 6/Plugins/Eclate_Deplace.rb:132
                        C:/Program Files/Google/Google SketchUp 6/Plugins/Eclate_Deplace.rb:132:in `call'
                        still so much to learn..
                        • C
                          c.plassais
                          @vidy said:
                          thanks pilou,
                          Try this version => Test for SU 6.0
                          c.plassais
                          • V
                            vidy
                            awesome it working now.. its just kind of magic..
                            thanks a lot chris.. and.. pilou
                            regards,
                              Added to the first post ๐Ÿ˜‰
                                Beautรฉ plaรฎt sans rรฉflรฉchir!
                                Beauty pleases without thinking!
                                ๐Ÿ˜‰ Thanks...
                                  La beautรฉ plaรฎt naturellement! โ˜€
                                    Ou ๐Ÿ˜•
                                    Beauty pleases naturally!
                                    Beauty is naturally appealing!
                                    La beautรฉ est naturellement sรฉduisante!
                                    ou
                                    La beautรฉ est naturellement attrayante!
                                    Beauty is appealing without conceit!
                                    La beautรฉ est attrayante sans prรฉtention!
                                    ๐Ÿ˜•
                                    • CadFatherC
                                      CadFather
                                      "Is beautiful that please without concept!" ..i thought it was pure old Pilou Master! ๐Ÿ‘ ๐Ÿ˜†
                                        Why this little " ๐Ÿ˜• " โ“ ๐Ÿ˜„
                                        All that are possible perfect variations of the old Kant Master ! โ˜€
                                          Nothing can be created, all is just tricky transformation! ๐Ÿ˜†
                                          (And nothing is losted ๐Ÿ˜‰ Adaptation from old Lavoisier Master ๐Ÿ’š
                                          • CadFatherC
                                            CadFather
                                            couldn't agree more Pilou, as i'm savouring my ice cream from good Master Giovanni! ๐Ÿ˜Ž ๐Ÿ˜†
                                            • 4 / 9
