    [Plugin] Material Replacer
    79 Posts 42 Posters 94.6k Views 42 Watching
    • N
      nomeradona
      definitely a time saver. thanks thom2
        Don't yet tested but if I understand you are not obliged to pass with the bucket tool for have the eye dropper?
        here my Proust's madeleine 😉
        http://dd.img.v4.skyrock.net/ddc/lemonzrh/pics/2314562571_2.jpg
        • bagateloB
          bagatelo
          I thought about an additional function in this plugin that may be useful for a lot of people.
          The plugin would create several squares (or plans, or boxes) in the scene, in a separate place, maybe in separate tab.
          The of number of the squares (or plans, or boxes) it would be the same as the number of the materials in the scene.
          In each one of them it would be applied a material. The objective of this function would be the one of to join identical materials or to join similar materials in the scene, reducing the number of materials in the scene. That would aid a lot in the moment of preparing the materials for rendering.
          Another interesting function would be to erase all of the squares and to recreate all from materials purged.
          That would be very special for me. Please, think with love about this possibility.
          • bagateloB
            bagatelo
            Another interesting thing would be if it was possible to change materials just in the selected objects.
              Excellent ideas! 💭 👍
                rv1974
                Thomtom huge thank you!
                2 things that would make this script a dream come true:
                1. To be able to make the 'first eyedropper click' a multiple one (with control key)- to select a set of materials to be replaced.
                2. To insert material editor into the picture. I mean ability to select materials (to be replaced\replacement candidate) both in model and mateditor.
                  Almost forgot: 😄
                • McGyverM
                  McGyver
                  Very cool! Thank you!
                  Visit My ShareCG Freebie Gallery
                  • Bob JamesB
                    Bob James
                    I have a real need for something very similar to bagatelo's request.
                    I have a need that doesn't seem to fit "Select by Material" or "Material Replacer" or "Repaint" or "GlobalMaterialChange".
                    In the development of my major models I was not very consistent with color application. As I've learned more and have gotten much more involved with rendering (TwiLight originally and now Thea) the actual colors are very important.
                    What I would like to be able to do is select a material/color that is in the model from the materials dialog (or something like bagatelo's idea) and then be able to select all objects that have that color/material. Then I need to be able to isolate them so I can see what's been selected, and, finally, with all of these selected, I can change their color. But I need to know which objects, groups, components are that color so I don't accidentally change one that I don't want changed.
                    Does anyone have an idea of how to do this or even if it could be done?
                      One can select all entities that has material with the same colour.
                      However, this isolation - not quite sure what you mean there. You mean hide all other faces/edges?
                      Can't think of nay other way to isolate. You do have the Hide Rest of Model feature in SU, but then everything would need to be inside a group/component - and the API doesn't let us upen up groups etc...
                        Dragoonprogramming
                        someone buy thomthom a cookie at base camp and take a picture of it 😄
                        "...And if he says that one more time i'll punch him right in the throat" - Armstrong and Getty
                        My website http://dragoonprogramming.weebly.com/
                          I'm not going to Basecamp... 😞
                          • Bob JamesB
                            Bob James
                            Bummer 😢
                            • Bob JamesB
                              Bob James
                              That's what I don't know how to do: If I could select all the entities with the same color and then isolate only those entities I could see which ones had the "wrong" color so I could change it.
                              Very belated update:
                              Karen Walkerman has done just what I requested above.
                              http://forums.sketchucation.com/viewtopic.php?t=31378
                              Thanks again Karen 👍
                                dedmin
                                Is it possible to change just the material of the picked face?
                                  Can't you just paint it ??
                                    dedmin
                                    The beauty of this tool - You don't have to open a component to change the material of the faces.
                                    But it changes all the material in the whole model - not just the face You click on.
                                      BUT your question was to change the material of the picked face !
                                      You mean to change the material of the picked face INSIDE THE GROUP/INSTANCE !
                                      It couldbe done... but I must leave it to others......
                                        dedmin
                                        Yes, inside the group or component. And only of that picked fase.
                                        • L
                                          lcbrewer
                                          How do you install this plugin
                                            Open the zip file and drop the .rb file and the folder with it into the Plugins folder where SketchUp is installed.
                                            • 1 / 4
