    How to add coordinate into SU api
    20 Posts 5 Posters 2.8k Views 5 Watching
    • Z Offline
      zps222
      @tig said:
      OK ❓ that's even easier... all you have to do is set the long/lat for the model to what you want them to be ?
      Sketchup.active_model.shadow_info['Latitude']=54.32 Sketchup.active_model.shadow_info['Longitude']=12.34
      πŸ€“
      Another question is, if I build a model, and want to set the bottom of the model at a centain depth in the ocean, how to manage it?
      • Dan RathbunD Offline
        Dan Rathbun
        FYI
        • Positive Latitudes are North of the equator; Negative are South.
        • Positive Longitudes are East of the Prime Meridian; Negative are West.
        First, open your Preferences dialog. Go to the Extensions panel.
        Check (turn ON,) the "Google Earth Ocean Modeling" extension.
        Then browse to the Sketchup directory: "Plugins/Ocean" and read the ruby script 'ocean.rb'
        It appears that you will need to move everything in your model, either:
        • above the [0,0,0] origin, if you wish to place the model relative to the ocean floor, OR* below the [0,0,0] origin, if you wish to place the model relative to the ocean surface.
          You will need to use the "Model on Ocean Floor" menu option that the Ocean extension adds to the Plugins menu.. BEFORE you upload the model to Google Earth.
        I'm not here much anymore.
          Dan Rathbun
          zps222, please wrap your code in a code block.
          Edit your post. Hilite the entire ruby text, and click the code button on the Edit Toolbar.
            Dan Rathbun
            1. Wrap your script in a unique module. 1. Do NOT paste the entire 'ocean.rb' into your script. Instead, use require to make sure it's loaded.
            module Zps222
              module OceanTest
                require('Ocean/ocean.rb')
                # your code
                # do this BEFORE exporting model for surface ref
                # change the 'if' to 'unless' for bottom ref
                toggle_ocean() if is_on_floor_bottom()
                Sketchup.active_model.export("c;/2.kmz",false)
                UI.openURL("c;/2.kmz")
            Also you need to start using ( ) around your argument lists.
            This can confuse Ruby:
            face.pushpull -4000
            Ruby may think you are trying to subtract integer 4000 from an object returned by the method on the left. Do this instead:
            face.pushpull(-4000)
              Dan Rathbun
              By the way.. I've heard that Google Earth models have to be "approved".
              Is this so? Does a user see his uploaded model right away, or is it invisible until it's approved?
              Or is it only invisible to other users, until it's approved?
              • Z Offline
                zps222
                @dan rathbun said:
                FYI
                Thans Dan.
                I still can't figure it out.
                For example, this is my example code:
                # Create the new material
                mats = Sketchup.active_model.materials
                ct_mat = mats.add "Color_Texture"
                ct_mat.color = "Red"
                # Draw a Face and set its material
                ents = Sketchup.active_model.entities
                face = ents.add_face [1000, -1000, -5000], [1000, 1000, -5000], [-1000, 1000, -5000], [-1000, -1000, -5000]
                face.material = ct_mat
                face.pushpull -4000
                Sketchup.active_model.shadow_info['Latitude']=29.060
                Sketchup.active_model.shadow_info['Longitude']=-88.090
                # Copyright 2005-2009, Google, Inc.
                # This script enables placing a model in Google Earth relative to the ocean floor,
                # instead of relative to ground (sea level).
                # Permission to use, copy, modify, and distribute this software for
                # any purpose and without fee is hereby granted, provided that the above
                # copyright notice appear in all copies.
                # THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
                # IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
                # WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
                def is_on_floor_bottom
                  return Sketchup.active_model.get_attribute("GeoReference", "onOceanFloor") == "true";
                def toggle_ocean
                  on_floor = !is_on_floor_bottom()
                  puts on_floor
                  if on_floor
                    Sketchup.active_model.set_attribute "GeoReference", "onOceanFloor", on_floor.to_s;
                  else
                    Sketchup.active_model.attribute_dictionary("GeoReference").delete_key "onOceanFloor";
                menu = UI;;menu("Plugins");
                menu.add_separator;
                item = menu.add_item($oceanStrings.GetString("Model on Ocean Floor")) { toggle_ocean }
                menu.set_validation_proc(item) {
                  is_on_floor_bottom() ? MF_CHECKED ; MF_UNCHECKED;
                • Z Offline
                  zps222
                  Thanks Dan. I will try your code soon.
                  For your question, I can instaneously see the model on google earth, but it's only confined in my laptop, not publiclly to the internet. If wanted to publicate it, as far as I know, there are 3 ways:
                  the most comon way is to upload the model into "google 3D warehouse" to let people download them into to "local" google earth. The sencond way is to embed the google earth into the website and the locate the KMZ into the server, then on the website, people can see it. The third way is to get the permission to publize it into official google earth.
                  • Z Offline
                    zps222
                    @dan rathbun said:
                    What about ??
                    Sketchup.active_model.shadow_info['Latitude'] Sketchup.active_model.shadow_info['Longitude']
                    I believe these are set by the Model Info > Location feature.
                    Thank you Dan and Jim.
                    Still, I can't figure it out.
                    Simply as an example,
                    # Access the Entities object
                    model = Sketchup.active_model
                    ent = model.entities
                    # Create the 2-D shape of the axis
                    axis = ent.add_face [0, -500, 0], [250, -433, 0],
                                          [433, -250, 0], [500, 0, 0],
                                          [433,250, 0], [250, 433, 0],
                                          [0, 500, 0], [-250, 433, 0],
                                          [-433, 250, 0], [-500, 0, 0],
                                          [-433, -250, 0], [-250, -433, 0], [0, -500, 0]
                    # Create the 3-D shape of the axis
                    total_depth = -2060
                    axis.pushpull total_depth
                    #creat one simple 3-d vector, North at the bottom
                    vector1 =ent.add_face [-500,0,0],[500,0,0],
                                       [500,1500,0],[750,1500,0],
                                       [0,2000,0],[-750,1500,0],
                                       [-500,1500,0]
                    vector_depth=-50
                    vector1.pushpull vector_depth
                    Here is my simple code, if I want to they located at lat= 10, lon=10, how to manege it?
                    Really appratiate.
                      Dan Rathbun
                      zps222,
                      The description of the Google Earth Ocean Modeling extension says,
                      "Adds the ability to model on the ocean floor after taking a snapshot from Google Earth."
                      So try taking a shapshot first.
                        Dan Rathbun
                        Here's some commands you can use at the console, for info:
                        dicts=Sketchup.active_model.attribute_dictionaries dicts['GeoReference'].each { |key,value| p key.to_s + '=' + value.to_s }
                          borg.stef
                          how can i put a simple model in the required location? i did the following coding
                          pt = Geom::point3d.new(0,0,0)
                          tr = Geom::Transformation.new(pt)
                          model.transform!(tr)
                          and it gives me this error:
                          #<NoMethodError: undefined method `point3d' for Geom:Module>
                          thankss
                            Dan Rathbun
                            @borg.stef said:
                            ... and it gives me this error:
                            #<NoMethodError: undefined methodpoint3d' for Geom:Module>`
                            Because methods begin with lower case identifiers.
                            Class (and Module,) indentifiers are titlecase.
                            @borg.stef said:
                            How can i put a simple model in the required location? I did the following coding:
                            model = Sketchup.active_model pt = Geom::point3d.new(0,0,0) tr = Geom::Transformation.new(pt) model.transform!(tr)
                            The model origin is already at [0,0,0], and there is a constant ORIGIN for it.
                            So your code above does nothing.
