    How to add coordinate into SU api
    20 Posts 5 Posters 3.1k Views 5 Watching
      Jim
      If the model has previously been geo-located, look for a model-level attribute_dictionary named "GeoReference". It acts like a Ruby Hash and should contain the Lat and Lon for the model.
      dict = Sketchup.active_model.attribute_dictionary["GeoReference"] p dict.to_a
      There are a number of keys in the dictionary and I don't know exactly what they are used for, but I do believe this is where Google Earth and 3D Warehouse get the model's location data from.
      • Dan RathbunD
        Dan Rathbun
        What about ??
        Sketchup.active_model.shadow_info['Latitude'] Sketchup.active_model.shadow_info['Longitude']
        I believe these are set by the Model Info > Location feature.
        I'm not here much anymore.
          Jim
          Maybe you're right, Dan. I remember the GeoReference dictionary isn't created until a model has been Geo Located the first time, so I made the assumption that it was being used. But it may be more complicated than that. (See signature.)
            Do you mean x=10, y=10 etc... or do you mean real long/lat coordinates?
            If you simply want to move things to x/y/z I suggest you make your new geometry inside a group
            ents=model.active_entities grp=ents.add_group() ent=grp.entities
            your 'ent' now takes the geometry inside the group 'grp'.
            NOW we transform the group
            pt=Geom::point3d.new(10,10,0) tr=Geom::Transformation.new(pt) grp.transform!(tr)
            The 'grp' then moves from where it is to [10,10,0] or whatever coordinates you say in 'pt'
            if you don't want the geometry to remain grouped then add
            grp.explode
            • Z
              zps222
              grp.explode
              Thanks Tig. But I want to place my model into a real long/latitude coordinate. Not the default one.
                OK ❓ that's even easier... all you have to do is set the long/lat for the model to what you want them to be ?
                Sketchup.active_model.shadow_info['Latitude']=54.32 Sketchup.active_model.shadow_info['Longitude']=12.34
                πŸ€“
                • Z
                  zps222
                  πŸ€“
                  Yes, Tig!! It works !!
                  Thank you very very much~~
                  Have a good day~~
                  • Z
                    zps222
                    πŸ€“
                    Another question is, if I build a model, and want to set the bottom of the model at a centain depth in the ocean, how to manage it?
                    • Dan RathbunD
                      Dan Rathbun
                      FYI
                      • Positive Latitudes are North of the equator; Negative are South.
                      • Positive Longitudes are East of the Prime Meridian; Negative are West.
                      First, open your Preferences dialog. Go to the Extensions panel.
                      Check (turn ON,) the "Google Earth Ocean Modeling" extension.
                      Then browse to the Sketchup directory: "Plugins/Ocean" and read the ruby script 'ocean.rb'
                      It appears that you will need to move everything in your model, either:
                      • above the [0,0,0] origin, if you wish to place the model relative to the ocean floor, OR* below the [0,0,0] origin, if you wish to place the model relative to the ocean surface.
                        You will need to use the "Model on Ocean Floor" menu option that the Ocean extension adds to the Plugins menu.. BEFORE you upload the model to Google Earth.
                      • Dan RathbunD
                        Dan Rathbun
                        zps222, please wrap your code in a code block.
                        Edit your post. Hilite the entire ruby text, and click the code button on the Edit Toolbar.
                        • Dan RathbunD
                          Dan Rathbun
                          1. Wrap your script in a unique module. 1. Do NOT paste the entire 'ocean.rb' into your script. Instead, use require to make sure it's loaded.
                          module Zps222
                            module OceanTest
                              require('Ocean/ocean.rb')
                              # your code
                              # do this BEFORE exporting model for surface ref
                              # change the 'if' to 'unless' for bottom ref
                              toggle_ocean() if is_on_floor_bottom()
                              Sketchup.active_model.export("c;/2.kmz",false)
                              UI.openURL("c;/2.kmz")
                          Also you need to start using ( ) around your argument lists.
                          This can confuse Ruby:
                          face.pushpull -4000
                          Ruby may think you are trying to subtract integer 4000 from an object returned by the method on the left. Do this instead:
                          face.pushpull(-4000)
                          • Dan RathbunD
                            Dan Rathbun
                            By the way.. I've heard that Google Earth models have to be "approved".
                            Is this so? Does a user see his uploaded model right away, or is it invisible until it's approved?
                            Or is it only invisible to other users, until it's approved?
                            • Z
                              zps222
                              @dan rathbun said:
                              FYI
                              Thans Dan.
                              I still can't figure it out.
                              For example, this is my example code:
                              # Create the new material
                              mats = Sketchup.active_model.materials
                              ct_mat = mats.add "Color_Texture"
                              ct_mat.color = "Red"
                              # Draw a Face and set its material
                              ents = Sketchup.active_model.entities
                              face = ents.add_face [1000, -1000, -5000], [1000, 1000, -5000], [-1000, 1000, -5000], [-1000, -1000, -5000]
                              face.material = ct_mat
                              face.pushpull -4000
                              Sketchup.active_model.shadow_info['Latitude']=29.060
                              Sketchup.active_model.shadow_info['Longitude']=-88.090
                              # Copyright 2005-2009, Google, Inc.
                              # This script enables placing a model in Google Earth relative to the ocean floor,
                              # instead of relative to ground (sea level).
                              # Permission to use, copy, modify, and distribute this software for
                              # any purpose and without fee is hereby granted, provided that the above
                              # copyright notice appear in all copies.
                              # THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
                              # IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
                              # WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
                              def is_on_floor_bottom
                                return Sketchup.active_model.get_attribute("GeoReference", "onOceanFloor") == "true";
                              def toggle_ocean
                                on_floor = !is_on_floor_bottom()
                                puts on_floor
                                if on_floor
                                  Sketchup.active_model.set_attribute "GeoReference", "onOceanFloor", on_floor.to_s;
                                else
                                  Sketchup.active_model.attribute_dictionary("GeoReference").delete_key "onOceanFloor";
                              menu = UI;;menu("Plugins");
                              menu.add_separator;
                              item = menu.add_item($oceanStrings.GetString("Model on Ocean Floor")) { toggle_ocean }
                              menu.set_validation_proc(item) {
                                is_on_floor_bottom() ? MF_CHECKED ; MF_UNCHECKED;
                              • Z
                                zps222
                                Thanks Dan. I will try your code soon.
                                For your question, I can instaneously see the model on google earth, but it's only confined in my laptop, not publiclly to the internet. If wanted to publicate it, as far as I know, there are 3 ways:
                                the most comon way is to upload the model into "google 3D warehouse" to let people download them into to "local" google earth. The sencond way is to embed the google earth into the website and the locate the KMZ into the server, then on the website, people can see it. The third way is to get the permission to publize it into official google earth.
                                • Z
                                  zps222
                                  @dan rathbun said:
                                  What about ??
                                  Thank you Dan and Jim.
                                  Still, I can't figure it out.
                                  Simply as an example,
                                  # Access the Entities object
                                  model = Sketchup.active_model
                                  ent = model.entities
                                  # Create the 2-D shape of the axis
                                  axis = ent.add_face [0, -500, 0], [250, -433, 0],
                                                        [433, -250, 0], [500, 0, 0],
                                                        [433,250, 0], [250, 433, 0],
                                                        [0, 500, 0], [-250, 433, 0],
                                                        [-433, 250, 0], [-500, 0, 0],
                                                        [-433, -250, 0], [-250, -433, 0], [0, -500, 0]
                                  # Create the 3-D shape of the axis
                                  total_depth = -2060
                                  axis.pushpull total_depth
                                  #creat one simple 3-d vector, North at the bottom
                                  vector1 =ent.add_face [-500,0,0],[500,0,0],
                                                     [500,1500,0],[750,1500,0],
                                                     [0,2000,0],[-750,1500,0],
                                                     [-500,1500,0]
                                  vector_depth=-50
                                  vector1.pushpull vector_depth
                                  Here is my simple code, if I want to they located at lat= 10, lon=10, how to manege it?
                                  Really appratiate.
                                  • Dan RathbunD
                                    Dan Rathbun
                                    zps222,
                                    The description of the Google Earth Ocean Modeling extension says,
                                    "Adds the ability to model on the ocean floor after taking a snapshot from Google Earth."
                                    So try taking a shapshot first.
                                    • Dan RathbunD
                                      Dan Rathbun
                                      Here's some commands you can use at the console, for info:
                                      dicts=Sketchup.active_model.attribute_dictionaries dicts['GeoReference'].each { |key,value| p key.to_s + '=' + value.to_s }
                                      • B
                                        borg.stef
                                        how can i put a simple model in the required location? i did the following coding
                                        pt = Geom::point3d.new(0,0,0)
                                        tr = Geom::Transformation.new(pt)
                                        model.transform!(tr)
                                        and it gives me this error:
                                        #<NoMethodError: undefined method `point3d' for Geom:Module>
                                        thankss
                                        • Dan RathbunD
                                          Dan Rathbun
                                          @borg.stef said:
                                          ... and it gives me this error:
                                          #<NoMethodError: undefined methodpoint3d' for Geom:Module>`
                                          Because methods begin with lower case identifiers.
                                          Class (and Module,) indentifiers are titlecase.
                                          @borg.stef said:
                                          How can i put a simple model in the required location? I did the following coding:
                                          model = Sketchup.active_model pt = Geom::point3d.new(0,0,0) tr = Geom::Transformation.new(pt) model.transform!(tr)
                                          The model origin is already at [0,0,0], and there is a constant ORIGIN for it.
                                          So your code above does nothing.
