    Command to select all on same layer?
    4 Posts 3 Posters 1.4k Views 3 Watching
      danbig
      This works great for ungrouped lines or faces. Is there a way to do this with groups and components?
        Not without Ruby...
        This one-liner will work, select ONE object on the required layer and then copy/paste this code into The Ruby Console +<enter> and the selection will expand to include everything in the "current context" that's on that same layer...
        m=Sketchup.active_model;s=m.selection;l=s[0].layer;s.clear;m.active_entities.each{|e|s.add e if e.layer==l}
        Here's a ' def' version of it - it's probably a little clearer - you can copy this code into a file in ../Plugins/ called "selectbylayer.rb"
        def selectbylayer()
          model=Sketchup.active_model
          ss=model.selection
          layer=ss[0].layer
          ss.clear
          model.active_entities.each{|e|ss.add e if e.layer==layer}
        end#def
        Then to run it you can type selectbylayer into the Ruby Console.
        To add a Plugins Menu item add this extra code to the end of the new .rb file [after the end#def]
        if not file_loaded?(File.basename(__FILE__))
          UI.menu("Plugins").add_item(("Select by Layer"){selectbylayer()})
        end#if
        file_loaded(File.basename(__FILE__))
        To run it you pick "Select by Layer" off the Plugins Menu.
        I'll leave the toolbar up to you... πŸ˜‰
          Selection Toys will let you do that:
          http://forums.sketchucation.com/viewtopic.php?f=323&t=14975
            danbig
            Thanks, all. Just when you think you've reviewed all the plugins out there...
