    Animated flames
    extensions
    26 Posts 17 Posters 5.7k Views 17 Watching
    • X Offline
      xrok1
      just checked out the lightup player. WOW!! 😲 best SU walkthrough software yet. 😍
      BTW, do animated textures work in the player?
      • tbdT Offline
        tbd
        Adam: yay, finally animated textures are back in Sketchup ! almost 3 years after my proof of concept and it works great without hacks.
        love LightUp player, can you make an iPad version as well ? ps. nice password on .luca files. πŸ’š
        http://plugins.ro
          @xrok1 said:
          ...BTW, do animated textures work in the player?
          That was exactly my very first thought!
          The other day I "discovered" the player and now finally (after so much time scratching my head), I really have to buy LU!
          • AdamBA Offline
            AdamB
            Gaieus: LightUp Player has exactly the same features and behavior as LightUp inside SketchUp.
            So, yes. Any animated Dynamic Components setup in LightUp, texture animation and color animation as well as SketchUp Scenes work inside LightUp Player. It also can run Fullscreen for presentations etc.
            dale. The light rigging + shader parameters should be able to be exported from LightUp. The texture animation also but in that case there isn't other packages that support that kind of thing.
            FYI The webpage for LightUp Player is here http://www.light-up.co.uk/player
            Adam
              Is there any way to enable SketchUp like navigation in LightUp Player?
              • AdamBA Offline
                AdamB
                What do you have in mind? Always interested in getting feedback.
                Currently, in LU Player, you can pivot around a point (Alt/Ctrl) as well as navigate around your model.
                  Ah - the pivot is nice.
                  Though I wish the mousewheel could be used. (or should it work? in any case - does nothing for me)
                  One thing I struggled with when navigation was to get the camera to stop. The inertia effect keep drifting the camera further away than I want.
                    Also, would there be a chance to "add speed"? (In some FPS style game engines you toggle a "running" mode with the shift key). With some bigger models this speed would be a bit slow if you want to wander all around...
                    And some basic localization? That short(ish) menu would not be a hard work to translate.
                    How about a web based viewer? (I know I ask too much and a web based viewer is something different than just add running mode and localization...) πŸ˜’
                      sepo
                      I find that moving about works best with arrows keys. If you want stop ineria you press arrow up and arrow down at the same time., or arrow lef and arrow right.
                      Also if you want to initiate running mode press arrow UP (or any arrow key) while pressing and holding scroll wheel. If you let go of the wheel it will slow down to normal speed.
                      • AdamBA Offline
                        AdamB
                        Mousewheel is currently not supported. We'll look into it.
                        The idea behind LU Player is to capture the setup the author chose using LightUp. So if you create the content to have a camera speed of X and no inertia and using a specific Skybox, this is what you'll get in LU Player. So if you don't want inertia, then export with inertia unchecked.
                        Hold Shift down before pressing direction keys for 5x speed increase. Also using Scenes (right mouse click) to get to a vicinity is handy too.
                        • EdsonE Offline
                          Edson
                          great feature, adam. I am dying to use it. πŸ‘ πŸ‘
                          http://www.mahfuz.arq.br
                            dylan
                            Well I have never tried Lightup before, but visiting the site and checking the software out a little further, I must give this a go. It looks really good.
                            Nice work Adam.
                            http://dmdarchitecture.co.uk/
                            • E Offline
                              Ecuadorian
                              πŸ‘ You and a lot of other people like this.
                              -Miguel Lescano
                              • O Offline
                                outofdate33
                                This is VERY great!
                                But what would be even greater is to have the choice from 1st and 3rd-person view like in Walkabout3D 😍
                                • 2 / 2
