    Animations with Alpha Channel
    13 Posts 7 Posters 1.8k Views 7 Watching
      Switch off ground/sky etc in your current Style and make your set of Scene tabs...
      Set your Style's background to a notable and easily pickable color - like 'green'.
      Render the animation as a set of image files [say png].
      Batch edit those image files in your preferred image-editor*** so that the 'green' is replaced by the transparent color. Assemble the images into an animated gif file and save...
      ***Here I used 'Animation Shop 3' to make this very quick example that has a fully transparent background...aGIF.gif
        mikeewilly
        Thanks to all for the suggestions. I was hoping to avoid the "frame-by-frame, port to another app" workflow. My fervent hope was someone would recommend a codec that did it for me. πŸ˜‰
        • BoxB
          Many gif applications will insert all files in one go, no need to do frame by frame.
          And select the background as transparent.
          And SU certainly exports multiple frames with a few clicks.
          • Chris FullmerC
            But png's don't export from windows with transparent backgrounds. The backgrouns is always white (or whatever other color is specified). So its not that simple. TIG's solution of coloring the background to something garish so it can easily be removed in s batch process is probably the best way.
            I could also see the possibility to make everythng black, and leave the background white and then export all the frames again that way and use those frames as an alpha channel to add to your movie. I have never tried that, but it seems like it should work? I guess one would need a movie editor that could take the 2 video streams and treat the black and white one as an alpha for the full color one.
            • BoxB
              No they don't, but most gif programs can find the green and make it transparent.
              My current Avatar has a transparent background.
                'Animation Shop 3' [and others] loads all of the images in one go - recognizing their order from their name. You then select a color to be 'ignored'/deleted to leave the back ground transparent [I used 'green' if you recall] - you also have options to apply that to all frames all at once, and you also set the 'range' to catch color-bleed at the edges where green might merge with red body or the edges/black etc, especially if there's anti-aliasing. Finally you optimize the gif and save it - it takes as long to describe and type it as it does to do it! Shucks - if you were to PM me a suitable zipped image set then I could post an animated gif just a few minutes later 😎 ... But I AM going to sleep right now though.... zzz πŸ˜‰
                PS: I gave my avatar gif a transparent background this afternoon too... β˜€
                EDIT: here's your face with a transparent backgroundface.gif
                  mikeewilly
                  Now THAT'S an interesting idea....
                  • Chris FullmerC
                    Ahh, gotcha. I thought you were saying that SU could somehow export the transparency. (well, on a Mac it can, just not on windows).
                    • BoxB
                      That I didn't know, I must try a Mac one day.
                      • GaieusG
                        There are some rendering applications that can export an alpha mask (white for the rendered objects and black for the background). Have a look at Kerkythea for instance (free). Then it's just a matter of multiply layering the images.
