    [Plugin] Torus 1.0
    25 Posts 18 Posters 19.0k Views 18 Watching
      Regular Polygon
      Thanks a lot everyone for all your positive feedback. πŸ˜„
      @d12dozr said:
      RP, how about a fractal generating plugin? ...you know, just for kicks πŸ˜›
      That's an idea. I can't think of anymore simple shapes to draw. Definitely would be just for fun.
      My SketchUp Plugins
      • simon le bonS Offline
        simon le bon
        Hi Regular!
        Are you going to join the happy few set list of the ruby masters ?
        I didn't know today this plugin was existing. It is a new member : Arc who have told us about it regarding to an exercise we try to soluce.
        Your Torus plugin make things too much easy (bad for the exercise πŸ˜‰ ). Thank you for sharing πŸ‘ πŸ‘ πŸ‘
        make and endless spiral:
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EndlessBowl_010_th.jpg
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EndlessBowl_011_th.jpg
        +++simon
        • BoxB Offline
          It's a wonderful plug-in, ten minutes to whip up this.
          http://i155.photobucket.com/albums/s296/storeben/SU/Speed28003.gif
            Regular Polygon
            What a coincidence that our separate lines of work would meet like that! 😲
            You are doing things I never imagined people would do with this plugin. πŸ‘
            My SketchUp Plugins
              Regular Polygon
              Thanks Box -- I really like your new avatar. πŸ‘
              My SketchUp Plugins
              • BoxB Offline
                That is thanks to you, it's one of your Toruses/Tori/torum. πŸ˜’
                • H Offline
                  halim
                  can anyone make setting for this examples
                    Regular Polygon
                    Hi halim,
                    The top torus with 20 twists had these settings:
                    The bottom six tori had these settings, except they each have a different twist parameter varying from 0-5.
                    P.S. Welcome to the forum!
                    My SketchUp Plugins
                      putnik
                      Thanks a bunch Regular Polygon! 3 twists setting produces geometry of the winning entry for Astana National Library by Bjarke Ingles Group (http://www.big.dk) 😲
                      http://www.google.com.au/images?hl=en&source=imghp&q=Astana+National+Library&btnG=Search+Images&gbv=2&aq=f&aqi=&aql=&oq=&gs_rfai=
                      http://keshas.info
                        tomislavm
                        • I Offline
                          ivreich
                          Error Message
                          Hi RP
                          I downloaded this plugin but it gives me an error message when I try to run it:
                          I'm using the default torus parameters...
                          Joel
                          Torus error message
                            The error is related to Fredo's AdditionalFolder plugin. Are you running this from a folder other than the default plugins folder?
                            • I Offline
                              ivreich
                              Not at all. I've installed the plugin directly into SU's default Plugins folder. Would it help if I removed Fredo's AdditionalFolder plugin?
                              Joel
                                I'd try it at least. Then we can identify a clash between plugins.
                                • 2 / 2
