    [Plugin] Torus 1.0
    25 Posts 18 Posters 20.0k Views 18 Watching
      Regular Polygon
      Thanks Box -- I really like your new avatar. πŸ‘
      My SketchUp Plugins
      • BoxB
        That is thanks to you, it's one of your Toruses/Tori/torum. πŸ˜’
        • H
          halim
          can anyone make setting for this examples
            Regular Polygon
            Hi halim,
            The top torus with 20 twists had these settings:
            The bottom six tori had these settings, except they each have a different twist parameter varying from 0-5.
            P.S. Welcome to the forum!
            My SketchUp Plugins
            • P
              putnik
              Thanks a bunch Regular Polygon! 3 twists setting produces geometry of the winning entry for Astana National Library by Bjarke Ingles Group (http://www.big.dk) 😲
              http://www.google.com.au/images?hl=en&source=imghp&q=Astana+National+Library&btnG=Search+Images&gbv=2&aq=f&aqi=&aql=&oq=&gs_rfai=
              http://keshas.info
              • T
                tomislavm
                • I
                  ivreich
                  Error Message
                  Hi RP
                  I downloaded this plugin but it gives me an error message when I try to run it:
                  I'm using the default torus parameters...
                  Joel
                  Torus error message
                    The error is related to Fredo's AdditionalFolder plugin. Are you running this from a folder other than the default plugins folder?
                    • I
                      ivreich
                      Not at all. I've installed the plugin directly into SU's default Plugins folder. Would it help if I removed Fredo's AdditionalFolder plugin?
                      Joel
                        I'd try it at least. Then we can identify a clash between plugins.
                        • 2 / 2
